[PATCH 0/3] Add spidev driver for Xilinx AXI Quad SPI device
Tue Mar 30 14:11:33 UTC 2021
This is all xilinx-zynq/zynqmp stuff. It has sat for several weeks now
with no comment, go ahead and merge it.
The backport of the driver is probably fine, the shell command will
need review--they'll both need tickets for backport also.
Gedare
On Tue, Mar 30, 2021 at 2:01 AM <Jan.Sommer at dlr.de> wrote:
> Just a short bump for this patch.
> > -----Original Message-----
> > From: Sommer, Jan
> > Sent: Wednesday, March 10, 2021 9:15 PM
> > To: devel at rtems.org
> > Cc: Sommer, Jan <Jan.Sommer at dlr.de>
> > Subject: [PATCH 0/3] Add spidev driver for Xilinx AXI Quad SPI device
> > This patchset adds a spidev driver for the Xilinx AXI Quad SPI device.
> > It currently supports Standard SPI mode.
> > Thanks goes to Rick van der Wal for testing the driver with his SPI IMU.
> > Jan Sommer (3):
> >   bsps/xilinx_zynq: Add SPI driver for xilinx-axi-spi
> >   bsps/shared: Add Xilinx-AXI SPI driver to waf
> >   bsps/xilinx_zynq: Add Xilinx AXI SPI driver to autotools build
> >  bsps/headers.am                               |   2 +
> >  bsps/include/dev/spi/xilinx-axi-spi-regs.h    |  88 ++++
> >  bsps/include/dev/spi/xilinx-axi-spi.h         |  67 +++
> >  bsps/shared/dev/spi/xilinx-axi-spi.c          | 402 ++++++++++++++++++
> >  c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am  |   1 +
> >  .../lib/libbsp/arm/xilinx-zynqmp/Makefile.am  |   1 +
> >  spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml |   2 +
> >  spec/build/bsps/arm/xilinx-zynq/grp.yml       |   2 +
> >  .../arm/xilinx-zynqmp/bspxilinxzynqmp.yml     |   2 +
> >  spec/build/bsps/objdevspixil.yml              |  18 +
> >  10 files changed, 585 insertions(+)
> >  create mode 100644 bsps/include/dev/spi/xilinx-axi-spi-regs.h
> >  create mode 100644 bsps/include/dev/spi/xilinx-axi-spi.h
> >  create mode 100644 bsps/shared/dev/spi/xilinx-axi-spi.c
> >  create mode 100644 spec/build/bsps/objdevspixil.yml
> > 2.17.1
> devel mailing list
> devel at rtems.org
