[PATCH 0/3] Add spidev driver for Xilinx AXI Quad SPI device
Jan.Sommer at dlr.de
Tue Mar 30 15:05:59 UTC 2021
Thanks, pushed to master.
I will prepare the tickets and patches for backporting next.
Best regards,
Jan
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Tuesday, March 30, 2021 4:12 PM
> To: Sommer, Jan <Jan.Sommer at dlr.de>
> Cc: devel at rtems.org
> Subject: Re: [PATCH 0/3] Add spidev driver for Xilinx AXI Quad SPI device
> This is all xilinx-zynq/zynqmp stuff. It has sat for several weeks now with no
> comment, go ahead and merge it.
> The backport of the driver is probably fine, the shell command will need
> review--they'll both need tickets for backport also.
> Gedare
> On Tue, Mar 30, 2021 at 2:01 AM <Jan.Sommer at dlr.de> wrote:
> > Just a short bump for this patch.
> > > From: Sommer, Jan
> > > Sent: Wednesday, March 10, 2021 9:15 PM
> > > To: devel at rtems.org
> > > Cc: Sommer, Jan <Jan.Sommer at dlr.de>
> > > Subject: [PATCH 0/3] Add spidev driver for Xilinx AXI Quad SPI
> > > device
> > > This patchset adds a spidev driver for the Xilinx AXI Quad SPI device.
> > > It currently supports Standard SPI mode.
> > > Thanks goes to Rick van der Wal for testing the driver with his SPI IMU.
> > > Jan Sommer (3):
> > > bsps/xilinx_zynq: Add SPI driver for xilinx-axi-spi
> > > bsps/shared: Add Xilinx-AXI SPI driver to waf
> > > bsps/xilinx_zynq: Add Xilinx AXI SPI driver to autotools build
> > > bsps/headers.am | 2 +
> > > bsps/include/dev/spi/xilinx-axi-spi-regs.h | 88 ++++
> > > bsps/include/dev/spi/xilinx-axi-spi.h | 67 +++
> > > bsps/shared/dev/spi/xilinx-axi-spi.c | 402 ++++++++++++++++++
> > > c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 1 +
> > > .../lib/libbsp/arm/xilinx-zynqmp/Makefile.am | 1 +
> > > spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml | 2 +
> > > spec/build/bsps/arm/xilinx-zynq/grp.yml | 2 +
> > > .../arm/xilinx-zynqmp/bspxilinxzynqmp.yml | 2 +
> > > spec/build/bsps/objdevspixil.yml | 18 +
> > > 10 files changed, 585 insertions(+) create mode 100644
> > > create mode 100644 bsps/include/dev/spi/xilinx-axi-spi.h
> > > create mode 100644 bsps/shared/dev/spi/xilinx-axi-spi.c
> > > create mode 100644 spec/build/bsps/objdevspixil.yml
> > > 2.17.1
> > devel mailing list
> > devel at rtems.org
