[PATCH] covoar/Reports: Fix empty branch report
Alex White alex.white at oarcorp.com
Tue Mar 30 16:27:20 UTC 2021
ping
> -----Original Message-----
> From: Alex White <alex.white at oarcorp.com>
> Sent: Friday, March 12, 2021 11:16 AM
> To: devel at rtems.org
> Cc: Alex White <alex.white at oarcorp.com>
> Subject: [PATCH] covoar/Reports: Fix empty branch report
> This makes the branch report more consistent with the other reports when
> there is no branch information found.
>  tester/covoar/ReportsBase.cc | 12 ++----  tester/covoar/ReportsHtml.cc | 82
>  2 files changed, 39 insertions(+), 55 deletions(-)
> diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
> index 8252959..3eb546f 100644
> --- a/tester/covoar/ReportsBase.cc
> +++ b/tester/covoar/ReportsBase.cc
> @@ -291,15 +291,9 @@ void ReportsBase::WriteBranchReport(
>    if (!report)
>      return;
> -  // If no branches were found of branch coverage is not supported
> -  if ((SymbolsToAnalyze->getNumberBranchesFound() == 0) ||
> -      (BranchInfoAvailable == false) ) {
> -    PutNoBranchInfo(report);
> -    // If branches were found, ...
> -  } else {
> +  // If no branches were found then branch coverage is not supported
> + if ((SymbolsToAnalyze->getNumberBranchesFound() != 0) &&
> +      (BranchInfoAvailable == true) ) {
>      // Process uncovered branches for each symbol.
>      count = 0;
>      for (ditr = SymbolsToAnalyze->set.begin(); diff --git
> a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc index
> 3d20aec..6406a48 100644
> --- a/tester/covoar/ReportsHtml.cc
> +++ b/tester/covoar/ReportsHtml.cc
> @@ -172,45 +172,43 @@ namespace Coverage {
>      // Open the file
>      aFile = OpenFile(fileName);
> -    if ( hasBranches ) {
> -      // Put header information into the file
> -      fprintf(
> -        aFile,
> -        "<title>Branch Report</title>\n"
> -        "<div class=\"heading-title\">"
> -      if (projectName)
> -        fprintf(
> -          aFile,
> -          "%s<br>",
> -          projectName
> +    // Put header information into the file
> +    fprintf(
> +      aFile,
> +      "<title>Branch Report</title>\n"
> +      "<div class=\"heading-title\">"
> +    if (projectName)
>        fprintf(
>          aFile,
> -        "Branch Report</div>\n"
> -        "<div class =\"datetime\">%s</div>\n"
> -        "<body>\n"
> -        "<table class=\"covoar table-autosort:0 table-autofilter table-
> stripeclass:covoar-tr-odd"
> -           TABLE_HEADER_CLASS "\">\n"
> -        "<thead>\n"
> -        "<tr>\n"
> -        "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
> -        "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
> -        "<th class=\"table-filterable table-sortable:default\"
> align=\"left\">File</th>\n"
> -        "<th class=\"table-sortable:numeric\" align=\"left\">Size
> <br>Bytes</th>\n"
> -        "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
> align=\"left\">Taken</th>\n"
> align=\"left\">Not Taken</th>\n"
> align=\"left\">Classification</th>\n"
> align=\"left\">Explanation</th>\n"
> -        "</tr>\n"
> -        "</thead>\n"
> -        "<tbody>\n",
> -        asctime( localtime(&timestamp_m) )
> +        "%s<br>",
> +        projectName
> +    fprintf(
> +      aFile,
> +      "Branch Report</div>\n"
> +      "<div class =\"datetime\">%s</div>\n"
> +      "<body>\n"
> +      "<table class=\"covoar table-autosort:0 table-autofilter table-
> +          TABLE_HEADER_CLASS "\">\n"
> +      "<thead>\n"
> +      "<tr>\n"
> +      "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
> +      "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
> +      "<th class=\"table-filterable table-sortable:default\"
> +      "<th class=\"table-sortable:numeric\" align=\"left\">Size
> <br>Bytes</th>\n"
> +      "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
> +      "<th class=\"table-filterable table-sortable:default\" align=\"left\">Not
> Taken</th>\n"
> +      "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>\n"
> +      "</tr>\n"
> +      "</thead>\n"
> +      "<tbody>\n",
> +      asctime( localtime(&timestamp_m) )
>      return aFile;
> @@ -985,19 +983,11 @@ namespace Coverage {
>      bool   hasBranches
> -      fprintf(
> -        aFile,
> -        TABLE_FOOTER
> -        "</tbody>\n"
> -        "</table>\n"
>      fprintf(
>        aFile,
> -      "</pre>\n"
> -      "</body>\n"
> -      "</html>"
> +      TABLE_FOOTER
> +      "</tbody>\n"
> +      "</table>\n"
>      CloseFile(aFile);
> 2.27.0
