[PATCH] covoar/Reports: Fix empty branch report
Tue Mar 30 16:50:28 UTC 2021
seems alright.
On Tue, Mar 30, 2021 at 10:27 AM Alex White <alex.white at oarcorp.com> wrote:
> ping
> > -----Original Message-----
> > From: Alex White <alex.white at oarcorp.com>
> > Sent: Friday, March 12, 2021 11:16 AM
> > To: devel at rtems.org
> > Cc: Alex White <alex.white at oarcorp.com>
> > Subject: [PATCH] covoar/Reports: Fix empty branch report
> > This makes the branch report more consistent with the other reports when
> > there is no branch information found.
> >  tester/covoar/ReportsBase.cc | 12 ++----  tester/covoar/ReportsHtml.cc | 82
> >  2 files changed, 39 insertions(+), 55 deletions(-)
> > diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
> > index 8252959..3eb546f 100644
> > --- a/tester/covoar/ReportsBase.cc
> > +++ b/tester/covoar/ReportsBase.cc
> > @@ -291,15 +291,9 @@ void ReportsBase::WriteBranchReport(
> >    if (!report)
> >      return;
> > -  // If no branches were found of branch coverage is not supported
> > -  if ((SymbolsToAnalyze->getNumberBranchesFound() == 0) ||
> > -      (BranchInfoAvailable == false) ) {
> > -    PutNoBranchInfo(report);
> > -    // If branches were found, ...
> > -  } else {
> > +  // If no branches were found then branch coverage is not supported
> > + if ((SymbolsToAnalyze->getNumberBranchesFound() != 0) &&
> > +      (BranchInfoAvailable == true) ) {
> >      // Process uncovered branches for each symbol.
> >      count = 0;
> >      for (ditr = SymbolsToAnalyze->set.begin(); diff --git
> > a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc index
> > 3d20aec..6406a48 100644
> > --- a/tester/covoar/ReportsHtml.cc
> > +++ b/tester/covoar/ReportsHtml.cc
> > @@ -172,45 +172,43 @@ namespace Coverage {
> >      // Open the file
> >      aFile = OpenFile(fileName);
> > -    if ( hasBranches ) {
> > -      // Put header information into the file
> > -      fprintf(
> > -        aFile,
> > -        "<title>Branch Report</title>\n"
> > -        "<div class=\"heading-title\">"
> > -      if (projectName)
> > -        fprintf(
> > -          aFile,
> > -          "%s<br>",
> > -          projectName
> > +    // Put header information into the file
> > +    fprintf(
> > +      aFile,
> > +      "<title>Branch Report</title>\n"
> > +      "<div class=\"heading-title\">"
> > +    if (projectName)
> >        fprintf(
> >          aFile,
> > -        "Branch Report</div>\n"
> > -        "<div class =\"datetime\">%s</div>\n"
> > -        "<body>\n"
> > -        "<table class=\"covoar table-autosort:0 table-autofilter table-
> > stripeclass:covoar-tr-odd"
> > -           TABLE_HEADER_CLASS "\">\n"
> > -        "<thead>\n"
> > -        "<tr>\n"
> > -        "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
> > -        "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
> > -        "<th class=\"table-filterable table-sortable:default\"
> > align=\"left\">File</th>\n"
> > -        "<th class=\"table-sortable:numeric\" align=\"left\">Size
> > <br>Bytes</th>\n"
> > -        "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
> > align=\"left\">Taken</th>\n"
> > align=\"left\">Not Taken</th>\n"
> > align=\"left\">Classification</th>\n"
> > align=\"left\">Explanation</th>\n"
> > -        "</tr>\n"
> > -        "</thead>\n"
> > -        "<tbody>\n",
> > -        asctime( localtime(&timestamp_m) )
> > +        "%s<br>",
> > +        projectName
> > +    fprintf(
> > +      aFile,
> > +      "Branch Report</div>\n"
> > +      "<div class =\"datetime\">%s</div>\n"
> > +      "<body>\n"
> > +      "<table class=\"covoar table-autosort:0 table-autofilter table-
> > +          TABLE_HEADER_CLASS "\">\n"
> > +      "<thead>\n"
> > +      "<tr>\n"
> > +      "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
> > +      "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
> > +      "<th class=\"table-filterable table-sortable:default\"
> > +      "<th class=\"table-sortable:numeric\" align=\"left\">Size
> > <br>Bytes</th>\n"
> > +      "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
> > +      "<th class=\"table-filterable table-sortable:default\" align=\"left\">Not
> > Taken</th>\n"
> > +      "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>\n"
> > +      "</tr>\n"
> > +      "</thead>\n"
> > +      "<tbody>\n",
> > +      asctime( localtime(&timestamp_m) )
> >      return aFile;
> > @@ -985,19 +983,11 @@ namespace Coverage {
> >      bool   hasBranches
> > -      fprintf(
> > -        aFile,
> > -        TABLE_FOOTER
> > -        "</tbody>\n"
> > -        "</table>\n"
> >      fprintf(
> >        aFile,
> > -      "</pre>\n"
> > -      "</body>\n"
> > -      "</html>"
> > +      TABLE_FOOTER
> > +      "</tbody>\n"
> > +      "</table>\n"
> >      CloseFile(aFile);
> > 2.27.0
> devel mailing list
> devel at rtems.org
