[rtems-tools commit] rld-process: Add named tempfile constructor
Chris Johns
chrisj at rtems.org
Wed Mar 31 03:30:16 UTC 2021
Hi,
When I looked at this on vc@ I saw it is broken. I am sorry I did not pick this
up in the review.
On 31/3/21 5:20 am, Joel Sherrill wrote:
> Module: rtems-tools
> Branch: master
> Commit: 420d7a13672991a1480d06ac02190f2976b9253b
> Changeset: http://git.rtems.org/rtems-tools/commit/?id=420d7a13672991a1480d06ac02190f2976b9253b
> Author: Alex White <alex.white at oarcorp.com>
> Date: Wed Mar 3 09:48:00 2021 -0600
> This adds a new tempfile constructor for creating a named tempfile
> rather than generating the name.
> rtemstoolkit/rld-process.cpp | 11 +++++++++++
> rtemstoolkit/rld-process.h | 7 +++++++
> 2 files changed, 18 insertions(+)
> diff --git a/rtemstoolkit/rld-process.cpp b/rtemstoolkit/rld-process.cpp
> index 30e0605..4160759 100644
> --- a/rtemstoolkit/rld-process.cpp
> +++ b/rtemstoolkit/rld-process.cpp
> @@ -169,6 +169,17 @@ namespace rld
> _name = temporaries.get (suffix, _keep);
> + tempfile::tempfile (const std::string& name,
> + const std::string& suffix,
> + bool _keep)
As a side issue this should be `keep` and not `_keep`. Could this please be
fixed with fix that is needed.
> + : _name(name + suffix),
> + suffix(suffix),
> + overridden (false),
> + fd (-1),
> + level (0)
This constructor is empty and so the file is not created in the temp path on
Unix or Windows and it is not registered to be deleted. I am sorry I did not
notice this before. How was this change tested?
Now I think about this change I am not sure it is right. Why you are using this
interface when the file is not in a temp directory and is not being deleted?
I have created a ticket ...
https://devel.rtems.org/ticket/4368
