[rtems-tools commit] rld-process: Add named tempfile constructor
Alex White alex.white at oarcorp.com
Wed Mar 31 15:26:17 UTC 2021
On Tue, Mar 30, 2021 at 10:30 PM Chris Johns <chrisj at rtems.org> wrote:
> Hi,
> When I looked at this on vc@ I saw it is broken. I am sorry I did not pick this
> up in the review.
> On 31/3/21 5:20 am, Joel Sherrill wrote:
> > Module:    rtems-tools
> > Branch:    master
> > Commit:    420d7a13672991a1480d06ac02190f2976b9253b
> > Changeset: http://git.rtems.org/rtems-tools/commit/?id=420d7a13672991a1480d06ac02190f2976b9253b
> > Author:    Alex White <alex.white at oarcorp.com>
> > Date:      Wed Mar  3 09:48:00 2021 -0600
> > This adds a new tempfile constructor for creating a named tempfile
> > rather than generating the name.
> >  rtemstoolkit/rld-process.cpp | 11 +++++++++++
> >  rtemstoolkit/rld-process.h   |  7 +++++++
> >  2 files changed, 18 insertions(+)
> > diff --git a/rtemstoolkit/rld-process.cpp b/rtemstoolkit/rld-process.cpp
> > index 30e0605..4160759 100644
> > --- a/rtemstoolkit/rld-process.cpp
> > +++ b/rtemstoolkit/rld-process.cpp
> > @@ -169,6 +169,17 @@ namespace rld
> >        _name = temporaries.get (suffix, _keep);
> > +    tempfile::tempfile (const std::string& name,
> > +                        const std::string& suffix,
> > +                        bool               _keep)
> As a side issue this should be `keep` and not `_keep`. Could this please be
> fixed with fix that is needed.
> > +      : _name(name + suffix),
> > +        suffix(suffix),
> > +        overridden (false),
> > +        fd (-1),
> > +        level (0)
> This constructor is empty and so the file is not created in the temp path on
> Unix or Windows and it is not registered to be deleted. I am sorry I did not
> notice this before. How was this change tested?
> Now I think about this change I am not sure it is right. Why you are using this
> interface when the file is not in a temp directory and is not being deleted?
Hi Chris,
This patch set up the interfaces used in the "covoar: Add option to create named objdumps" patch that I sent.
We determined that patch was not needed given its hacked-togetherness along with future speedups that we had in mind which would make it obsolete anyway.
This patch should have been removed from the set to be committed, but I forgot to send out a notice to exclude it. Sorry for the confusion.
This commit should be reverted.
Alex
> I have created a ticket ...
>  https://devel.rtems.org/ticket/4368
> Chris
> devel mailing list
> devel at rtems.org
