[PATCH 1/3] gen_uuid.c: Ignore return values from fcntl()
Wed Mar 31 16:13:05 UTC 2021
On Wed, Mar 31, 2021 at 9:16 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> CID 1049146: Unchecked return value from library in get_clock().
> CID 1049147: Unchecked return value from library in get_random_fd().
> Closes #4280
>  cpukit/libmisc/uuid/gen_uuid.c | 8 ++++++++
>  1 file changed, 8 insertions(+)
> diff --git a/cpukit/libmisc/uuid/gen_uuid.c b/cpukit/libmisc/uuid/gen_uuid.c
> index 3ca75a0..9cd763d 100644
> --- a/cpukit/libmisc/uuid/gen_uuid.c
> +++ b/cpukit/libmisc/uuid/gen_uuid.c
> @@ -164,8 +164,13 @@ static int get_random_fd(void)
>                         fd = open("/dev/random", O_RDONLY | O_NONBLOCK);
>                 if (fd >= 0) {
>                         i = fcntl(fd, F_GETFD);
> +                       #ifdef __rtems__
> +                       if (i >= 0)
> +                               (void) fcntl(fd, F_SETFD, i | FD_CLOEXEC);
> +                       #else
>                         if (i >= 0)
> +                       #endif
You could do the same thing here as you did below, just put the #ifdef
after the if (i>=0)
The upstream is
https://github.com/karelzak/util-linux/blob/master/libuuid/src/gen_uuid.c
I wonder if we should update?
>  #endif
>                 srand((getpid() << ((sizeof(pid_t)*CHAR_BIT)>>1)) ^ getuid() ^ tv.tv_sec ^ tv.tv_usec);
> @@ -426,6 +431,9 @@ try_again:
>                 rewind(state_f);
>                 fl.l_type = F_UNLCK;
> +       #ifdef __rtems__
> +               (void)
> +       #endif
>                 fcntl(state_fd, F_SETLK, &fl);
> 1.8.3.1
> devel mailing list
> devel at rtems.org
