[PATCH 1/3] gen_uuid.c: Ignore return values from fcntl()
Joel Sherrill
joel at rtems.org
Wed Mar 31 16:35:17 UTC 2021
On Wed, Mar 31, 2021 at 11:13 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Mar 31, 2021 at 9:16 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> > CID 1049146: Unchecked return value from library in get_clock().
> > CID 1049147: Unchecked return value from library in get_random_fd().
> > Closes #4280
> > cpukit/libmisc/uuid/gen_uuid.c | 8 ++++++++
> > 1 file changed, 8 insertions(+)
> > diff --git a/cpukit/libmisc/uuid/gen_uuid.c
> b/cpukit/libmisc/uuid/gen_uuid.c
> > index 3ca75a0..9cd763d 100644
> > --- a/cpukit/libmisc/uuid/gen_uuid.c
> > +++ b/cpukit/libmisc/uuid/gen_uuid.c
> > @@ -164,8 +164,13 @@ static int get_random_fd(void)
> > fd = open("/dev/random", O_RDONLY | O_NONBLOCK);
> > if (fd >= 0) {
> > i = fcntl(fd, F_GETFD);
> > + #ifdef __rtems__
> > + if (i >= 0)
> > + (void) fcntl(fd, F_SETFD, i |
> FD_CLOEXEC);
> > + #else
> > if (i >= 0)
> > fcntl(fd, F_SETFD, i | FD_CLOEXEC);
> > + #endif
> You could do the same thing here as you did below, just put the #ifdef
> after the if (i>=0)
> The upstream is
> https://github.com/karelzak/util-linux/blob/master/libuuid/src/gen_uuid.c
> I wonder if we should update?
Are you sure that's the master? That's not what the README in the directory
says.
I'm not opposed to updating the code in the directory but I want to make
sure it
comes from the right place.
And do we have any tests to ensure it works if it builds? This wasn't
included
in the last coverage I uploaded but I can ask Alex to turn it on.
> > #endif
> > srand((getpid() << ((sizeof(pid_t)*CHAR_BIT)>>1)) ^
> getuid() ^ tv.tv_sec ^ tv.tv_usec);
> > @@ -426,6 +431,9 @@ try_again:
> > rewind(state_f);
> > fl.l_type = F_UNLCK;
> > + #ifdef __rtems__
> > + (void)
> > + #endif
> > fcntl(state_fd, F_SETLK, &fl);
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210331/8c2709e0/attachment.html>
