[PATCH 2/3] main_cp.c: Ignore return value from stat()
Wed Mar 31 16:16:41 UTC 2021
On Wed, Mar 31, 2021 at 9:16 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> CID 26051: Unchecked return value from library in main_cp().
> Closes #4365
>  cpukit/libmisc/shell/main_cp.c | 7 +++++++
>  1 file changed, 7 insertions(+)
> diff --git a/cpukit/libmisc/shell/main_cp.c b/cpukit/libmisc/shell/main_cp.c
> index cddbc95..bb31a35 100644
> --- a/cpukit/libmisc/shell/main_cp.c
> +++ b/cpukit/libmisc/shell/main_cp.c
> @@ -254,10 +254,17 @@ main_cp(rtems_shell_cp_globals* cp_globals, int argc, char *argv[])
>                  * the initial mkdir().
>                 if (r == -1) {
> +                       #ifdef __rtems__
> +                       if (Rflag && (Lflag || Hflag))
> +                               (void) stat(*argv, &tmp_stat);
> +                       else
> +                               (void) lstat(*argv, &tmp_stat);
> +                       #else
>                         else
> +                       #endif
Would it be better to keep each change localized? at first I didn't
really care for this approach that was taken in patch 1, but compared
to copy-pasting multiple lines of code, it might be simpler to deal
with fine-grained modifications, like this:
+                               #ifdef __rtems__
+                               (void)
+                               #endif
>                         if (S_ISDIR(tmp_stat.st_mode) && Rflag)
>                                 type = DIR_TO_DNE;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
