[PATCH 2/3] main_cp.c: Ignore return value from stat()
Ryan Long
ryan.long at oarcorp.com
Wed Mar 31 16:21:12 UTC 2021
I'm assuming you accidentally left the (void) in after that #endif, but that's the approach that Joel and I did first. After Joel saw it implemented, he said it made the code look too messy to him because of the if statements.
-----Original Message-----
Sent: Wednesday, March 31, 2021 11:17 AM
To: Ryan Long <ryan.long at oarcorp.com>
Cc: devel at rtems.org
Subject: Re: [PATCH 2/3] main_cp.c: Ignore return value from stat()
On Wed, Mar 31, 2021 at 9:16 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> CID 26051: Unchecked return value from library in main_cp().
> Closes #4365
> cpukit/libmisc/shell/main_cp.c | 7 +++++++
> 1 file changed, 7 insertions(+)
> diff --git a/cpukit/libmisc/shell/main_cp.c
> b/cpukit/libmisc/shell/main_cp.c index cddbc95..bb31a35 100644
> --- a/cpukit/libmisc/shell/main_cp.c
> +++ b/cpukit/libmisc/shell/main_cp.c
> @@ -254,10 +254,17 @@ main_cp(rtems_shell_cp_globals* cp_globals, int argc, char *argv[])
> * the initial mkdir().
> if (r == -1) {
> + #ifdef __rtems__
> + if (Rflag && (Lflag || Hflag))
> + (void) stat(*argv, &tmp_stat);
> + else
> + (void) lstat(*argv, &tmp_stat);
> + #else
> else
> + #endif
Would it be better to keep each change localized? at first I didn't really care for this approach that was taken in patch 1, but compared to copy-pasting multiple lines of code, it might be simpler to deal with fine-grained modifications, like this:
+ #ifdef __rtems__
+ (void)
+ #endif
> if (S_ISDIR(tmp_stat.st_mode) && Rflag)
> type = DIR_TO_DNE;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
