[PATCH] riscv/start: Startup sequence update.
Mon May 3 12:06:48 UTC 2021
On 03/05/2021 13:47, somesh deshmukh wrote:
> I performed the following sequence of instruction:
> ./waf clean
> ./waf configure
> ./waf
> Tried this couple of times but the same result always.
> I will try this again with fresh sources from rsb and rtems master
> branches.
Now it should work. I forgot to update the build specification file
which generates the linker command file.
Do you use
BSP_FDT_BLOB_READ_ONLY = False
BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA = False
in your config.ini?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
