[PATCH] riscv/start: Startup sequence update.
somesh deshmukh
someshdeshmukh07 at gmail.com
Mon May 3 12:11:58 UTC 2021
On Mon, May 3, 2021 at 5:36 PM Sebastian Huber <
> On 03/05/2021 13:47, somesh deshmukh wrote:
> > I performed the following sequence of instruction:
> > ./waf clean
> > ./waf configure
> > ./waf
> > Tried this couple of times but the same result always.
> > I will try this again with fresh sources from rsb and rtems master
> > branches.
> Now it should work. I forgot to update the build specification file
> which generates the linker command file.
> Is it available in master?
Do you use
> BSP_FDT_BLOB_READ_ONLY = False
> BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA = False
> in your config.ini?
This is my config.ini file
[riscv/rv64imafdc_medany]
BUILD_TESTS = False
RISCV_RAM_REGION_BEGIN = 0x80100000
RISCV_RAM_REGION_SIZE = 0x100000
RTEMS_SMP = False
RISCV_CONSOLE_MAX_NS16550_DEVICES = 1
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210503/2b116c74/attachment.html>
