[PATCH v1 2/5] libcsupport: Implement utime() in terms of utimensat()
Ryan Long
ryan.long at oarcorp.com
Mon May 3 13:40:24 UTC 2021
utime() now calls utimensat() to update file access
and modification timestamps.
Closes #4397
cpukit/libcsupport/src/utime.c | 74 +++++++++++++++++++++++-------------------
1 file changed, 41 insertions(+), 33 deletions(-)
diff --git a/cpukit/libcsupport/src/utime.c b/cpukit/libcsupport/src/utime.c
index e2d8883..610ce35 100644
--- a/cpukit/libcsupport/src/utime.c
+++ b/cpukit/libcsupport/src/utime.c
@@ -1,58 +1,66 @@
* @file
- * @brief Set File Access and Modification Times
* @ingroup libcsupport
+ * @brief Set file access and modification times in seconds.
- * COPYRIGHT (c) 1989-1999.
+ * COPYRIGHT (c) 1989-2009, 2021.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
-/* FIXME: This include is a workaround for a broken <utime.h> in Newlib */
-#include <sys/types.h>
+#include <sys/stat.h>
+#include <rtems/libio_.h>
+#include <fcntl.h>
#include <utime.h>
-#include <rtems/libio_.h>
- * POSIX 1003.1b 5.5.6 - Set File Access and Modification Times
+ * https://pubs.opengroup.org/onlinepubs/009604599/functions/utime.html
+ * Set file access and modification times
-int utime( const char *path, const struct utimbuf *times )
+int utime(
+ const char *path,
+ const struct utimbuf *times
- int rv = 0;
- rtems_filesystem_eval_path_context_t ctx;
- int eval_flags = RTEMS_FS_FOLLOW_LINK;
- const rtems_filesystem_location_info_t *currentloc =
- rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
- struct utimbuf now_times;
- if ( times == NULL ) {
- time_t now = time( NULL );
- now_times.actime = now;
- now_times.modtime = now;
- times = &now_times;
+ struct timespec new_times[2];
- rv = (*currentloc->mt_entry->ops->utime_h)(
- currentloc,
- times->actime,
- times->modtime
+ if( times == NULL )
+ return utimensat(AT_FDCWD, path, NULL, 0);
- rtems_filesystem_eval_path_cleanup( &ctx );
+ new_times[0].tv_sec = times->actime;
+ new_times[0].tv_nsec = 0;
+ new_times[1].tv_sec = times->modtime;
+ new_times[1].tv_nsec = 0;
- return rv;
+ return utimensat(AT_FDCWD, path, new_times, 0);
1.8.3.1
