[PATCH v1 1/5] libcsupport: Added futimens() and utimensat()
Wed May 5 18:55:56 UTC 2021
On Wed, May 5, 2021 at 11:03 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> Reply is below.
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Tuesday, May 4, 2021 11:27 AM
> To: Ryan Long <ryan.long at oarcorp.com>
> Cc: Sebastian Huber <sebastian.huber at embedded-brains.de>; devel at rtems.org
> Subject: Re: [PATCH v1 1/5] libcsupport: Added futimens() and utimensat()
> On Tue, May 4, 2021 at 10:04 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> > From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> > Sent: Tuesday, May 4, 2021 12:04 AM
> > To: Ryan Long <ryan.long at oarcorp.com>; devel at rtems.org
> > utimensat()
> > On 03/05/2021 15:40, Ryan Long wrote:
> > > Created futimens.c and utimensat.c to add support for the POSIX
> > > methods futimens() and utimensat().
> > > utime() and utimes() are considered obsolote by POSIX, but RTEMS
> > > will continue to support them.
> > > Closes #4396
> > >   cpukit/Makefile.am                 |   2 +
> > >   cpukit/include/rtems/libio_.h      |  61 +++++++++-
> > >   cpukit/libcsupport/src/futimens.c  |  91 +++++++++++++++
> > >   cpukit/libcsupport/src/utimensat.c | 229 +++++++++++++++++++++++++++++++++++++
> > >   spec/build/cpukit/librtemscpu.yml  |   2 +
> > >   5 files changed, 384 insertions(+), 1 deletion(-)
> > >   create mode 100644 cpukit/libcsupport/src/futimens.c
> > >   create mode 100644 cpukit/libcsupport/src/utimensat.c
> > > diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am index
> > > b0df610..29b4207 100644
> > > --- a/cpukit/Makefile.am
> > > +++ b/cpukit/Makefile.am
> > > @@ -262,6 +262,8 @@ librtemscpu_a_SOURCES += libcsupport/src/unmount.c
> > >   librtemscpu_a_SOURCES += libcsupport/src/__usrenv.c
> > >   librtemscpu_a_SOURCES += libcsupport/src/utime.c
> > >   librtemscpu_a_SOURCES += libcsupport/src/utimes.c
> > > +librtemscpu_a_SOURCES += libcsupport/src/futimens.c
> > > +librtemscpu_a_SOURCES += libcsupport/src/utimensat.c
> > >   librtemscpu_a_SOURCES += libcsupport/src/utsname.c
> > >   librtemscpu_a_SOURCES += libcsupport/src/vprintk.c
> > >   librtemscpu_a_SOURCES += libcsupport/src/write.c diff --git
> > > a/cpukit/include/rtems/libio_.h b/cpukit/include/rtems/libio_.h
> > > index
> > > e9eb462..fc7a1e4 100644
> > > --- a/cpukit/include/rtems/libio_.h
> > > +++ b/cpukit/include/rtems/libio_.h
> > > @@ -7,7 +7,7 @@
> > > - *  COPYRIGHT (c) 1989-2011.
> > > + *  COPYRIGHT (c) 1989-2011, 2021.
> > >    *  On-Line Applications Research Corporation (OAR).
> > >    *  Modifications to support reference counting in the file system
> > > are @@ -357,6 +357,65 @@ static inline void rtems_filesystem_instance_unlock(
> > >     (*mt_entry->ops->unlock_h)( mt_entry );
> > > +/* Prototypes for functions used between utimensat() and futimens()
> > > + * @brief Checks the tv_sec member of a timespec struct
> > > + * @param[in] time The timespec struct to be validated
> > > + * Ensures that the value in the tv_sec member is non-negative.
> > > + * @retval true If the tv_sec member is a valid value
> > > + * @retval false If the tv_sec member is not a valid value  */ bool
> > > +rtems_filesystem_utime_tv_sec_valid( struct timespec time );
> > > + * @brief Checks the tv_nsec member of a timespec struct
> > > + * Ensures that the value in the tv_nsec member is equal to either
> > > + * UTIME_NOW, UTIME_OMIT, or a value greater-than or equal to zero
> > > + * and less than a billion.
> > > + * @retval true If the tv_nsec member is a valid value
> > > + * @retval false If the tv_nsec member is not a valid value  */
> > > +bool rtems_filesystem_utime_tv_nsec_valid( struct timespec time );
> > Are these two functions ever used individually? Do they modify the time?
> > Maybe we should add a standard phase for boolean type returns:
> > @return Returns true, if the X is valid, otherwise false.
> > [Ryan Long] These functions are only used in rtems_filesystem_utime_check_times(). They don't modify the time, they just ensure that the members of the timespec struct are valid values. Should the arguments for those functions be changed to be a const since they're not being modified? And sure, I can consolidate the @retval statements like that.
> > > + * @brief Determines if the process has write permissions to a file
> > > + * Checks that the process has the same userID as the file and
> > > +whether the
> > > + * file has write permissions.
> > > + * @param[in] currentloc The current location to a file
> > > + * @param[in] fstat_h The file handler of @currentloc
> > Why is this an extra parameter?
> > [Ryan Long] This was Joel's suggestion, but I didn't think about just using the currentloc argument. I'll change that in V2.
> > > + * @retval 0 If the process has write permissions
> > > + * @retval -1 If the process does not have write permissions
> > Why 0 and -1, what about errno? Is it set by the function or not?
> > [Ryan Long] It's 0 and -1 because it uses the rtems_set_errno_and_return_minus_one() macro.
> > > +int rtems_filesystem_utime_check_permissions(
> > > +  const rtems_filesystem_location_info_t *currentloc,
> > > +  rtems_filesystem_fstat_t fstat_h
> > > + * @brief Checks @times and updates @new_times
> > > + * @param[in] times The timespec struct to be checked
> > > + * @param[in,out] new_times The timespec struct to contain the
> > > +updated time
> > > + * @retval 0 If the time was able to be updated
> > > + * @retval -1 If the time was not able to be updated  */ int
> > > +rtems_filesystem_utime_check_times(
> > > +  const struct timespec times[2],
> > > +  struct timespec new_times[2]
> > >    *  File Descriptor Routine Prototypes
> > > diff --git a/cpukit/libcsupport/src/futimens.c
> > > b/cpukit/libcsupport/src/futimens.c
> > > new file mode 100644
> > > index 0000000..33ae469
> > > --- /dev/null
> > > +++ b/cpukit/libcsupport/src/futimens.c
> > > @@ -0,0 +1,91 @@
> > > +/* SPDX-License-Identifier: BSD-2-Clause */
> > > + *  @file
> > > + *  @ingroup libcsupport
> > > + *  @brief Set file access and modification times based on file
> > > +descriptor in
> > > + *  nanoseconds.
> > > + *  COPYRIGHT (c) 1989-2009, 2021.
> > > + *  On-Line Applications Research Corporation (OAR).
> > > + * Redistribution and use in source and binary forms, with or
> > > +without
> > > + * modification, are permitted provided that the following
> > > +conditions
> > > + * are met:
> > > + * 1. Redistributions of source code must retain the above copyright
> > > + *    notice, this list of conditions and the following disclaimer.
> > > + * 2. Redistributions in binary form must reproduce the above copyright
> > > + *    notice, this list of conditions and the following disclaimer in the
> > > + *    documentation and/or other materials provided with the distribution.
> > > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> > > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> > > +LIMITED TO, THE
> > > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> > > +PARTICULAR PURPOSE
> > > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> > > +CONTRIBUTORS BE
> > > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> > > +OR
> > > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> > > +PROCUREMENT OF
> > > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> > > +BUSINESS
> > > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> > > +WHETHER IN
> > > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> > > +OTHERWISE)
> > > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> > > +ADVISED OF THE
> > > + * POSSIBILITY OF SUCH DAMAGE.
> > > +#ifdef HAVE_CONFIG_H
> > > +#include "config.h"
> > > +#endif
> > > +#include <sys/stat.h>
> > > +#include <rtems/libio_.h>
> > > +#include <fcntl.h>
> > > +#include <stdlib.h>
> > > +#include <string.h>
> > > +https://pubs.opengroup.org/onlinepubs/9699919799.2008edition/functi
> > > +on
> > > +s/futimens.html
> > > + *  Set file access and modification times  */ int futimens(
> > > +  int                    fd,
> > > +  int rv;
> > > +  rtems_libio_t *iop;
> > > +  struct timespec new_times[2];
> > > +  const rtems_filesystem_location_info_t *currentloc = NULL;
> > > +  LIBIO_GET_IOP_WITH_ACCESS( fd, iop, LIBIO_FLAGS_READ, EBADF );
> > > +  currentloc = &iop->pathinfo;
> > > +  rv = rtems_filesystem_utime_check_permissions(
> > > +    currentloc,
> > > +    (*currentloc->handlers->fstat_h)  );  if( rv == -1 ) {
> > Which coding style should this file and the other new files have?
> > > +/* Determine whether the access and modified timestamps can be
> > > +updated */ int rtems_filesystem_utime_check_permissions(
> > > +  const rtems_filesystem_location_info_t * currentloc,
> > > +  struct stat st;
> > > +  volatile int rv;
> > volatile?
> > [Ryan Long] Forgot to take this out after debugging. Will be removed in V2.
> > > +  bool write_access;
> > > +  memset( &st, 0, sizeof(st) );
> > > +  rv = (*fstat_h)( currentloc, &st );  if( rv != 0 ) {
> > > +    rtems_set_errno_and_return_minus_one( ENOENT );  }
> > > +   * Check that the user ID and the user ID of the file match
> > > +  if( geteuid() != st.st_uid ) {
> > > +    rtems_set_errno_and_return_minus_one( EACCES );  }
> > Is this really what POSIX specified?
> > [Ryan Long] Yes, on https://pubs.opengroup.org/onlinepubs/9699919799.2008edition/functions/futimens.html they said return this if 'the effective user ID of the process does not match the owner of the file and write access is denied.'
> But you haven't checked write access yet. I think you haven't parsed the specification correctly.
> [Ryan Long] So I should move the assignment of write_access above this check, and change the check to be this?
yep. Other cases might be missing or conflicting though, so you'll
need to check through all the logic, e.g., EPERM.
> if( geteuid() != st.st_uid) {
>   if( !write_access) {
> > > +  write_access = rtems_filesystem_check_access(
> > > +    RTEMS_FS_PERMS_WRITE,
> > > +    st.st_mode,
> > > +    st.st_uid,
> > > +    st.st_gid
> > > +  if( !write_access ) {
> > > +  return 0;
> > > +ons/futimens.html
> > > + *  Set file access and modification times  */ int utimensat(
> > > +  int                    fd,
> > > +  const char            *path,
> > > +  int                    flag
> > > +  int rv = 0;
> > > +  rtems_filesystem_eval_path_context_t ctx;
> > > +  int eval_flags = RTEMS_FS_FOLLOW_LINK;
> > > +   * RTEMS does not currently support operating on a real file descriptor
> > > +  if( fd != AT_FDCWD ) {
> > > +    rtems_set_errno_and_return_minus_one( ENOSYS );  }
> > > +   * RTEMS does not currently support AT_SYMLINK_NOFOLLOW
> > > +  if( flag != 0 ) {
> > > +  currentloc = rtems_filesystem_eval_path_start( &ctx, path,
> > > + eval_flags );
> > > +    currentloc,
> > Better use the success code, for example rv != 0.
> > > +    rtems_filesystem_eval_path_cleanup( &ctx );
> > > +    return rv;
> > > +  rv = rtems_filesystem_utime_check_times( times, new_times);  if(
> > > + rv == -1 ) {
> > > +    return rv;
> > > +  rv = (*currentloc->mt_entry->ops->utimens_h)(
> > > +    currentloc,
> > > +    new_times
> > > +  return rv;
> > > diff --git a/spec/build/cpukit/librtemscpu.yml
> > > b/spec/build/cpukit/librtemscpu.yml
> > > index a3a9ee4..9639051 100644
> > > --- a/spec/build/cpukit/librtemscpu.yml
> > > +++ b/spec/build/cpukit/librtemscpu.yml
> > > @@ -761,6 +761,8 @@ source:
> > >   - cpukit/libcsupport/src/unmount.c
> > >   - cpukit/libcsupport/src/utime.c
> > >   - cpukit/libcsupport/src/utimes.c
> > > +- cpukit/libcsupport/src/futimens.c
> > > +- cpukit/libcsupport/src/utimensat.c
> > >   - cpukit/libcsupport/src/utsname.c
> > >   - cpukit/libcsupport/src/vprintk.c
> > >   - cpukit/libcsupport/src/write.c
> > embedded brains GmbH
> > Herr Sebastian HUBER
> > Dornierstr. 4
> > 82178 Puchheim
> > Germany
> > email: sebastian.huber at embedded-brains.de
> > phone: +49-89-18 94 741 - 16
> > fax:   +49-89-18 94 741 - 08
> > Registergericht: Amtsgericht München
> > Registernummer: HRB 157899
> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> > Dörfler Unsere Datenschutzerklärung finden Sie hier:
> > https://embedded-brains.de/datenschutzerklaerung/
> > devel mailing list
> > devel at rtems.org
