[PATCH] nfs.c: Change filesystem utime_h handler to utimens_h
Joel Sherrill
joel at rtems.org
Mon May 3 18:33:50 UTC 2021
Ryan.. these have the same subject/short message and are threading together
as the same patch.
Resubmit both as v2 with libbsd and net-legacy added to the commit message.
Something like:
legacy nfs.c: Change filesystem utime_h handler to utimens_h
libbsd nfs.c: Change filesystem utime_h handler to utimens_h
Weird edge case here.
On Mon, May 3, 2021 at 1:14 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Changed nfs_utime() to nfs_utimens(), changed the arguments to use
> a timespec array instead of individual variables for access and
> modified time.
> Updates #4400
> nfsclient/src/nfs.c | 50
> 1 file changed, 25 insertions(+), 25 deletions(-)
> diff --git a/nfsclient/src/nfs.c b/nfsclient/src/nfs.c
> index bc9a2c6..72fefb9 100644
> --- a/nfsclient/src/nfs.c
> +++ b/nfsclient/src/nfs.c
> @@ -2050,19 +2050,19 @@ static int nfs_rmnod(
> return rv;
> -static int nfs_utime(
> +static int nfs_utimens(
> const rtems_filesystem_location_info_t *pathloc, /* IN */
> - time_t actime, /* IN */
> - time_t modtime /* IN */
> + struct timespec times[2] /* IN */
> sattr arg;
> /* TODO: add rtems EPOCH - UNIX EPOCH seconds */
> - arg.atime.seconds = actime;
> - arg.atime.useconds = 0;
> - arg.mtime.seconds = modtime;
> - arg.mtime.useconds = 0;
> + arg.atime.seconds = times[0].tv_sec;
> + arg.atime.useconds = times[0].tv_nsec / 1000;
> + arg.mtime.seconds = times[1].tv_sec;
> + arg.mtime.useconds = times[1].tv_nsec / 1000;
> return nfs_sattr(pathloc->node_access, &arg, SATTR_ATIME |
> SATTR_MTIME);
> @@ -2254,25 +2254,25 @@ sattr arg;
> const struct _rtems_filesystem_operations_table nfs_fs_ops = {
> - .lock_h = nfs_lock,
> - .unlock_h = nfs_unlock,
> - .eval_path_h = nfs_eval_path,
> - .link_h = nfs_link,
> + .lock_h = nfs_lock,
> + .unlock_h = nfs_unlock,
> + .eval_path_h = nfs_eval_path,
> + .link_h = nfs_link,
> .are_nodes_equal_h = nfs_are_nodes_equal,
> - .mknod_h = nfs_mknod,
> - .rmnod_h = nfs_rmnod,
> - .fchmod_h = nfs_fchmod,
> - .chown_h = nfs_chown,
> - .clonenod_h = nfs_clonenode,
> - .freenod_h = nfs_freenode,
> - .mount_h = rtems_filesystem_default_mount,
> - .unmount_h = rtems_filesystem_default_unmount,
> - .fsunmount_me_h = nfs_fsunmount_me,
> - .utime_h = nfs_utime,
> - .symlink_h = nfs_symlink,
> - .readlink_h = nfs_readlink,
> - .rename_h = nfs_rename,
> - .statvfs_h = rtems_filesystem_default_statvfs
> + .mknod_h = nfs_mknod,
> + .rmnod_h = nfs_rmnod,
> + .fchmod_h = nfs_fchmod,
> + .chown_h = nfs_chown,
> + .clonenod_h = nfs_clonenode,
> + .freenod_h = nfs_freenode,
> + .mount_h = rtems_filesystem_default_mount,
> + .unmount_h = rtems_filesystem_default_unmount,
> + .fsunmount_me_h = nfs_fsunmount_me,
> + .utimens_h = nfs_utimens,
> + .symlink_h = nfs_symlink,
> + .readlink_h = nfs_readlink,
> + .rename_h = nfs_rename,
> + .statvfs_h = rtems_filesystem_default_statvfs
> 1.8.3.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210503/d2912bd5/attachment-0001.html>
