[PATCH] nfs.c: Change filesystem utime_h handler to utimens_h
Tue May 4 07:00:01 UTC 2021
On Mon, May 3, 2021 at 12:34 PM Joel Sherrill <joel at rtems.org> wrote:
> Ryan.. these have the same subject/short message and are threading together as the same patch.
> Resubmit both as v2 with libbsd and net-legacy added to the commit message. Something like:
> legacy nfs.c: Change filesystem utime_h handler to utimens_h
> libbsd nfs.c: Change filesystem utime_h handler to utimens_h
> Weird edge case here.
Use the --subject-prefix next time
https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
We don't have rules quite enforced on that, but generally people will
add the repo name, e.g., --subject-prefix=rtems-net-legacy
thankx
> On Mon, May 3, 2021 at 1:14 PM Ryan Long <ryan.long at oarcorp.com> wrote:
>> Changed nfs_utime() to nfs_utimens(), changed the arguments to use
>> a timespec array instead of individual variables for access and
>> modified time.
>> Updates #4400
>>  nfsclient/src/nfs.c | 50 +++++++++++++++++++++++++-------------------------
>>  1 file changed, 25 insertions(+), 25 deletions(-)
>> diff --git a/nfsclient/src/nfs.c b/nfsclient/src/nfs.c
>> index bc9a2c6..72fefb9 100644
>> --- a/nfsclient/src/nfs.c
>> +++ b/nfsclient/src/nfs.c
>> @@ -2050,19 +2050,19 @@ static int nfs_rmnod(
>>         return rv;
>> -static int nfs_utime(
>> +static int nfs_utimens(
>>         const rtems_filesystem_location_info_t  *pathloc, /* IN */
>> -       time_t                                   actime,  /* IN */
>> -       time_t                                   modtime  /* IN */
>> +       struct timespec                          times[2] /* IN */
>>  sattr  arg;
>>         /* TODO: add rtems EPOCH - UNIX EPOCH seconds */
>> -       arg.atime.seconds  = actime;
>> -       arg.atime.useconds = 0;
>> -       arg.mtime.seconds  = modtime;
>> -       arg.mtime.useconds = 0;
>> +       arg.atime.seconds  = times[0].tv_sec;
>> +       arg.atime.useconds = times[0].tv_nsec / 1000;
>> +       arg.mtime.seconds  = times[1].tv_sec;
>> +       arg.mtime.useconds = times[1].tv_nsec / 1000;
>>         return nfs_sattr(pathloc->node_access, &arg, SATTR_ATIME | SATTR_MTIME);
>> @@ -2254,25 +2254,25 @@ sattr   arg;
>>  const struct _rtems_filesystem_operations_table nfs_fs_ops = {
>> -       .lock_h         = nfs_lock,
>> -       .unlock_h       = nfs_unlock,
>> -       .eval_path_h    = nfs_eval_path,
>> -       .link_h         = nfs_link,
>> +       .lock_h            = nfs_lock,
>> +       .unlock_h          = nfs_unlock,
>> +       .eval_path_h       = nfs_eval_path,
>> +       .link_h            = nfs_link,
>>         .are_nodes_equal_h = nfs_are_nodes_equal,
>> -       .mknod_h        = nfs_mknod,
>> -       .rmnod_h        = nfs_rmnod,
>> -       .fchmod_h       = nfs_fchmod,
>> -       .chown_h        = nfs_chown,
>> -       .clonenod_h     = nfs_clonenode,
>> -       .freenod_h      = nfs_freenode,
>> -       .mount_h        = rtems_filesystem_default_mount,
>> -       .unmount_h      = rtems_filesystem_default_unmount,
>> -       .fsunmount_me_h = nfs_fsunmount_me,
>> -       .utime_h        = nfs_utime,
>> -       .symlink_h      = nfs_symlink,
>> -       .readlink_h     = nfs_readlink,
>> -       .rename_h       = nfs_rename,
>> -       .statvfs_h      = rtems_filesystem_default_statvfs
>> +       .mknod_h           = nfs_mknod,
>> +       .rmnod_h           = nfs_rmnod,
>> +       .fchmod_h          = nfs_fchmod,
>> +       .chown_h           = nfs_chown,
>> +       .clonenod_h        = nfs_clonenode,
>> +       .freenod_h         = nfs_freenode,
>> +       .mount_h           = rtems_filesystem_default_mount,
>> +       .unmount_h         = rtems_filesystem_default_unmount,
>> +       .fsunmount_me_h    = nfs_fsunmount_me,
>> +       .utimens_h         = nfs_utimens,
>> +       .symlink_h         = nfs_symlink,
>> +       .readlink_h        = nfs_readlink,
>> +       .rename_h          = nfs_rename,
>> +       .statvfs_h         = rtems_filesystem_default_statvfs
>> 1.8.3.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
