[PATCH] rtemstoolkit/mailer.py: Fix option ordering for add_arguments
Wed May 5 18:49:04 UTC 2021
On Wed, May 5, 2021 at 9:16 AM Alex White <alex.white at oarcorp.com> wrote:
> On Wed, May 5, 2021 at 9:47 AM Gedare Bloom <gedare at rtems.org> wrote:
> > Why?
> To prevent the '--mail' and '--use-gitconfig' options from being added more than once to the ArgumentParser in add_arguments.
How does that happen?
I'm not trying to be frustrating (just annoying). I want to be sure
we're using the right solution for the right problem, and not just
putting a bandaid over something so it works while we hide some
underlying concerns.
Gedare
> Alex
> > On Wed, May 5, 2021 at 8:08 AM Alex White <alex.white at oarcorp.com> wrote:
> > > The ordering of keys cannot be guaranteed in a dictionary. This changes
> > > the options dictionary to an OrderedDict to preserve key order. This
> > > also fixes the iteration start point in add_arguments.
> > > Closes #4402
> > >  rtemstoolkit/mailer.py | 24 +++++++++++++-----------
> > >  1 file changed, 13 insertions(+), 11 deletions(-)
> > > diff --git a/rtemstoolkit/mailer.py b/rtemstoolkit/mailer.py
> > > index ae51d78..ad832d5 100644
> > > --- a/rtemstoolkit/mailer.py
> > > +++ b/rtemstoolkit/mailer.py
> > > @@ -1,6 +1,7 @@
> > >  # RTEMS Tools Project (http://www.rtems.org/)
> > >  # Copyright 2013-2016 Chris Johns (chrisj at rtems.org)
> > > +# Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
> > >  # All rights reserved.
> > >  # This file is part of the RTEMS Tools package in 'rtems-tools'.
> > > @@ -33,6 +34,7 @@
> > >  from __future__ import print_function
> > > +from collections import OrderedDict
> > >  import os
> > >  import smtplib
> > > @@ -43,16 +45,16 @@ from rtemstoolkit import execute
> > >  from rtemstoolkit import options
> > >  from rtemstoolkit import path
> > > -_options = {
> > > -    '--mail'         : 'Send email report or results.',
> > > -    '--use-gitconfig': 'Use mail configuration from git config.',
> > > -    '--mail-to'      : 'Email address to send the email to.',
> > > -    '--mail-from'    : 'Email address the report is from.',
> > > -    '--smtp-host'    : 'SMTP host to send via.',
> > > -    '--smtp-port'    : 'SMTP port to send via.',
> > > -    '--smtp-user'    : 'User for SMTP authentication.',
> > > -    '--smtp-password': 'Password for SMTP authentication.'
> > > +_options = OrderedDict([
> > > +    ('--mail'         , 'Send email report or results.'),
> > > +    ('--use-gitconfig', 'Use mail configuration from git config.'),
> > > +    ('--mail-to'      , 'Email address to send the email to.'),
> > > +    ('--mail-from'    , 'Email address the report is from.'),
> > > +    ('--smtp-host'    , 'SMTP host to send via.'),
> > > +    ('--smtp-port'    , 'SMTP port to send via.'),
> > > +    ('--smtp-user'    , 'User for SMTP authentication.'),
> > > +    ('--smtp-password', 'Password for SMTP authentication.')
> > >  def append_options(opts):
> > >      for o in _options:
> > > @@ -61,7 +63,7 @@ def append_options(opts):
> > >  def add_arguments(argsp):
> > >      argsp.add_argument('--mail', help = _options['--mail'], action = 'store_true')
> > >      argsp.add_argument('--use-gitconfig', help = _options['--use-gitconfig'], action = 'store_true')
> > > -    for o in list(_options)[1:]:
> > > +    for o in list(_options)[2:]:
> > >          argsp.add_argument(o, help = _options[o], type = str)
> > >  class mail:
> > > 2.27.0
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
