[PATCH v2 5/5] Change filesystem utime_h handler to utimens_h
Ryan Long ryan.long at oarcorp.com
Thu May 6 19:50:49 UTC 2021
Also updated licenses.
Closes #4400
 bsps/arm/csb337/umon/tfsDriver.c            |  2 +-
 cpukit/Makefile.am                          |  4 +--
 cpukit/include/rtems/confdefs/libio.h       |  4 +--
 cpukit/include/rtems/imfs.h                 |  7 +++--
 cpukit/include/rtems/libio.h                | 21 +++++++--------
 cpukit/libcsupport/src/__usrenv.c           |  9 +++----
 cpukit/libfs/src/defaults/default_ops.c     |  2 +-
 cpukit/libfs/src/defaults/default_utime.c   | 32 ----------------------
 cpukit/libfs/src/defaults/default_utimens.c | 33 +++++++++++++++++++++++
 cpukit/libfs/src/dosfs/msdos_init.c         | 11 ++++----
 cpukit/libfs/src/ftpfs/ftpfs.c              |  2 +-
 cpukit/libfs/src/ftpfs/tftpDriver.c         |  2 +-
 cpukit/libfs/src/imfs/imfs_init.c           |  4 +--
 cpukit/libfs/src/imfs/imfs_utime.c          | 41 ----------------------------
 cpukit/libfs/src/imfs/imfs_utimens.c        | 42 +++++++++++++++++++++++++++++
 cpukit/libfs/src/jffs2/src/fs-rtems.c       | 11 ++++----
 cpukit/libfs/src/rfs/rtems-rfs-rtems.c      | 16 +++++------
 spec/build/cpukit/librtemscpu.yml           |  4 +--
 18 files changed, 120 insertions(+), 127 deletions(-)
 delete mode 100644 cpukit/libfs/src/defaults/default_utime.c
 create mode 100644 cpukit/libfs/src/defaults/default_utimens.c
 delete mode 100644 cpukit/libfs/src/imfs/imfs_utime.c
 create mode 100644 cpukit/libfs/src/imfs/imfs_utimens.c
diff --git a/bsps/arm/csb337/umon/tfsDriver.c b/bsps/arm/csb337/umon/tfsDriver.c
index 0195346..caf3a4b 100644
--- a/bsps/arm/csb337/umon/tfsDriver.c
+++ b/bsps/arm/csb337/umon/tfsDriver.c
@@ -657,7 +657,7 @@ static const rtems_filesystem_operations_table  rtems_tfs_ops = {
   .mount_h = rtems_filesystem_default_mount,
   .unmount_h = rtems_filesystem_default_unmount,
   .fsunmount_me_h = rtems_filesystem_default_fsunmount,
-  .utime_h = rtems_filesystem_default_utime,
+  .utimens_h = rtems_filesystem_default_utimens,
   .symlink_h = rtems_filesystem_default_symlink,
   .readlink_h = rtems_filesystem_default_readlink,
   .rename_h = rtems_filesystem_default_rename,
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 29b4207..c144773 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -377,7 +377,7 @@ librtemscpu_a_SOURCES += libfs/src/defaults/default_rmnod.c
 librtemscpu_a_SOURCES += libfs/src/defaults/default_statvfs.c
 librtemscpu_a_SOURCES += libfs/src/defaults/default_symlink.c
 librtemscpu_a_SOURCES += libfs/src/defaults/default_unmount.c
-librtemscpu_a_SOURCES += libfs/src/defaults/default_utime.c
+librtemscpu_a_SOURCES += libfs/src/defaults/default_utimens.c
 librtemscpu_a_SOURCES += libfs/src/defaults/default_write.c
 librtemscpu_a_SOURCES += libfs/src/defaults/default_writev.c
 librtemscpu_a_SOURCES += libfs/src/dosfs/fat.c
@@ -434,7 +434,7 @@ librtemscpu_a_SOURCES += libfs/src/imfs/imfs_stat.c
 librtemscpu_a_SOURCES += libfs/src/imfs/imfs_stat_file.c
 librtemscpu_a_SOURCES += libfs/src/imfs/imfs_symlink.c
 librtemscpu_a_SOURCES += libfs/src/imfs/imfs_unmount.c
-librtemscpu_a_SOURCES += libfs/src/imfs/imfs_utime.c
+librtemscpu_a_SOURCES += libfs/src/imfs/imfs_utimens.c
 librtemscpu_a_SOURCES += libfs/src/imfs/ioman.c
 librtemscpu_a_SOURCES += libfs/src/pipe/fifo.c
 librtemscpu_a_SOURCES += libfs/src/pipe/pipe.c
diff --git a/cpukit/include/rtems/confdefs/libio.h b/cpukit/include/rtems/confdefs/libio.h
index 16a4fb69..1b84f8c 100644
--- a/cpukit/include/rtems/confdefs/libio.h
+++ b/cpukit/include/rtems/confdefs/libio.h
@@ -231,9 +231,9 @@ static const rtems_filesystem_operations_table IMFS_root_ops = {
   #endif
   #ifdef CONFIGURE_IMFS_DISABLE_UTIME
-    rtems_filesystem_default_utime,
+    rtems_filesystem_default_utimens,
   #else
-    IMFS_utime,
+    IMFS_utimens,
   #endif
   #ifdef CONFIGURE_IMFS_DISABLE_SYMLINK
diff --git a/cpukit/include/rtems/imfs.h b/cpukit/include/rtems/imfs.h
index b2a9868..6e0d5d5 100644
--- a/cpukit/include/rtems/imfs.h
+++ b/cpukit/include/rtems/imfs.h
@@ -5,7 +5,7 @@
- *  COPYRIGHT (c) 1989-2011.
+ *  COPYRIGHT (c) 1989-2011, 2021.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
@@ -954,10 +954,9 @@ extern int device_ftruncate(
  * This routine is the implementation of the utime() system
  * call for the IMFS.
-extern int IMFS_utime(
+extern int IMFS_utimens(
   const rtems_filesystem_location_info_t *loc,
-  time_t actime,
-  time_t modtime
+  struct timespec times[2]
diff --git a/cpukit/include/rtems/libio.h b/cpukit/include/rtems/libio.h
index 519e797..99543ba 100644
--- a/cpukit/include/rtems/libio.h
+++ b/cpukit/include/rtems/libio.h
@@ -11,7 +11,7 @@
- *  COPYRIGHT (c) 1989-2008.
+ *  COPYRIGHT (c) 1989-2008, 2021.
  *  Modifications to support reference counting in the file system are
@@ -375,18 +375,16 @@ typedef int (*rtems_filesystem_rmnod_t)(
  * @brief Set node access and modification times.
  * @param[in] loc The location of the node.
- * @param[in] actime Access time for the node.
- * @param[in] modtime Modification for the node.
+ * @param[in] times Access and modification times for the node
  * @retval 0 Successful operation.
  * @retval -1 An error occurred.  The errno is set to indicate the error.
- * @see rtems_filesystem_default_utime().
+ * @see rtems_filesystem_default_utimens().
-typedef int (*rtems_filesystem_utime_t)(
+typedef int (*rtems_filesystem_utimens_t)(
-  time_t actime,
-  time_t modtime
@@ -484,7 +482,7 @@ struct _rtems_filesystem_operations_table {
   rtems_filesystem_mount_t mount_h;
   rtems_filesystem_unmount_t unmount_h;
   rtems_filesystem_fsunmount_me_t fsunmount_me_h;
-  rtems_filesystem_utime_t utime_h;
+  rtems_filesystem_utimens_t utimens_h;
   rtems_filesystem_symlink_t symlink_h;
   rtems_filesystem_readlink_t readlink_h;
   rtems_filesystem_rename_t rename_h;
@@ -644,12 +642,11 @@ void rtems_filesystem_default_fsunmount(
  * @retval -1 Always.  The errno is set to ENOTSUP.
- * @see rtems_filesystem_utime_t.
+ * @see rtems_filesystem_utimens_t.
-int rtems_filesystem_default_utime(
+int rtems_filesystem_default_utimens(
-  time_t actime,
-  time_t modtime
diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
index 5c25eaa..13b5700 100644
--- a/cpukit/libcsupport/src/__usrenv.c
+++ b/cpukit/libcsupport/src/__usrenv.c
@@ -6,7 +6,7 @@
@@ -145,10 +145,9 @@ static void null_op_fsunmount_me(
   /* Do nothing */
-static int null_op_utime(
+static int null_op_utimens(
-  time_t actime,
-  time_t modtime
   return -1;
@@ -207,7 +206,7 @@ static const rtems_filesystem_operations_table null_ops = {
   .mount_h = null_op_mount,
   .unmount_h = null_op_unmount,
   .fsunmount_me_h = null_op_fsunmount_me,
-  .utime_h = null_op_utime,
+  .utimens_h = null_op_utimens,
   .symlink_h = null_op_symlink,
   .readlink_h = null_op_readlink,
   .rename_h = null_op_rename,
diff --git a/cpukit/libfs/src/defaults/default_ops.c b/cpukit/libfs/src/defaults/default_ops.c
index 63ad2ce..de317a2 100644
--- a/cpukit/libfs/src/defaults/default_ops.c
+++ b/cpukit/libfs/src/defaults/default_ops.c
@@ -36,7 +36,7 @@ const rtems_filesystem_operations_table rtems_filesystem_operations_default = {
diff --git a/cpukit/libfs/src/defaults/default_utime.c b/cpukit/libfs/src/defaults/default_utime.c
deleted file mode 100644
index aaf4e44..0000000
--- a/cpukit/libfs/src/defaults/default_utime.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * @file
- * @ingroup LibIOFSOps File System Operations
- * @brief RTEMS Default File System sets file access and modification times
- *  COPYRIGHT (c) 2010.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/libio_.h>
-#include <rtems/seterr.h>
-  const rtems_filesystem_location_info_t *loc,
-  time_t actime,
-  time_t modtime
-  rtems_set_errno_and_return_minus_one( ENOTSUP );
diff --git a/cpukit/libfs/src/defaults/default_utimens.c b/cpukit/libfs/src/defaults/default_utimens.c
new file mode 100644
index 0000000..f71c156
--- /dev/null
+++ b/cpukit/libfs/src/defaults/default_utimens.c
@@ -0,0 +1,33 @@
+ * @file
+ * @ingroup LibIOFSOps File System Operations
+ * @brief RTEMS Default File System sets file access and modification times
+ *  COPYRIGHT (c) 2010, 2021.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/libio_.h>
+#include <rtems/seterr.h>
+  const rtems_filesystem_location_info_t *loc,
+  rtems_set_errno_and_return_minus_one( ENOTSUP );
diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
index 67b16b6..a96b973 100644
--- a/cpukit/libfs/src/dosfs/msdos_init.c
+++ b/cpukit/libfs/src/dosfs/msdos_init.c
@@ -36,18 +36,17 @@ static int msdos_clone_node_info(rtems_filesystem_location_info_t *loc)
     return fat_file_reopen(fat_fd);
-static int msdos_utime(
+static int msdos_utimens(
-  time_t                                  actime,
-  time_t                                  modtime
     fat_file_fd_t *fat_fd = loc->node_access;
-    if (actime != modtime)
+    if (times[0].tv_sec != times[1].tv_sec)
-    fat_file_set_mtime(fat_fd, modtime);
+    fat_file_set_mtime(fat_fd, times[1].tv_sec);
     return RC_OK;
@@ -67,7 +66,7 @@ const rtems_filesystem_operations_table  msdos_ops = {
   .fsunmount_me_h =  msdos_shut_down,
-  .utime_h        =  msdos_utime,
+  .utimens_h      =  msdos_utimens,
   .rename_h       =  msdos_rename,
diff --git a/cpukit/libfs/src/ftpfs/ftpfs.c b/cpukit/libfs/src/ftpfs/ftpfs.c
index 5e0cb95..a0ee0fa 100644
--- a/cpukit/libfs/src/ftpfs/ftpfs.c
+++ b/cpukit/libfs/src/ftpfs/ftpfs.c
@@ -1384,7 +1384,7 @@ static const rtems_filesystem_operations_table rtems_ftpfs_ops = {
   .fsunmount_me_h = rtems_ftpfs_unmount_me,
diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c b/cpukit/libfs/src/ftpfs/tftpDriver.c
index 7cbb402..bc0e74a 100644
--- a/cpukit/libfs/src/ftpfs/tftpDriver.c
+++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
@@ -1039,7 +1039,7 @@ static const rtems_filesystem_operations_table  rtems_tftp_ops = {
     .fsunmount_me_h = rtems_tftpfs_shutdown,
diff --git a/cpukit/libfs/src/imfs/imfs_init.c b/cpukit/libfs/src/imfs/imfs_init.c
index 1b9b769..5b8d3dd 100644
--- a/cpukit/libfs/src/imfs/imfs_init.c
+++ b/cpukit/libfs/src/imfs/imfs_init.c
@@ -7,7 +7,7 @@
- *  COPYRIGHT (c) 1989-1999.
+ *  COPYRIGHT (c) 1989-1999, 2021.
@@ -40,7 +40,7 @@ static const rtems_filesystem_operations_table IMFS_ops = {
   .mount_h = IMFS_mount,
   .unmount_h = IMFS_unmount,
   .fsunmount_me_h = IMFS_fsunmount,
-  .utime_h = IMFS_utime,
+  .utimens_h = IMFS_utimens,
   .symlink_h = IMFS_symlink,
   .readlink_h = IMFS_readlink,
   .rename_h = IMFS_rename,
diff --git a/cpukit/libfs/src/imfs/imfs_utime.c b/cpukit/libfs/src/imfs/imfs_utime.c
index 21e5139..0000000
--- a/cpukit/libfs/src/imfs/imfs_utime.c
+++ /dev/null
@@ -1,41 +0,0 @@
- * @file
- * @ingroup IMFS
- * @brief Set IMFS File Access and Modification Times
-#endif
-#include <rtems/imfs.h>
-#include <sys/time.h>
-int IMFS_utime(
-  time_t actime,
-  time_t modtime
-  IMFS_jnode_t *the_jnode;
-  the_jnode = (IMFS_jnode_t *) loc->node_access;
-  the_jnode->stat_atime = actime;
-  the_jnode->stat_mtime = modtime;
-  the_jnode->stat_ctime = time( NULL );
-  return 0;
diff --git a/cpukit/libfs/src/imfs/imfs_utimens.c b/cpukit/libfs/src/imfs/imfs_utimens.c
index 0000000..92f2528
--- /dev/null
+++ b/cpukit/libfs/src/imfs/imfs_utimens.c
@@ -0,0 +1,42 @@
+ * @file
+ * @ingroup IMFS
+ * @brief Set IMFS File Access and Modification Times
+#endif
+#include <rtems/imfs.h>
+#include <sys/time.h>
+int IMFS_utimens(
+  IMFS_jnode_t *the_jnode;
+  the_jnode = (IMFS_jnode_t *) loc->node_access;
+  the_jnode->stat_atime = times[0].tv_sec;
+  the_jnode->stat_mtime = times[1].tv_sec;
+  the_jnode->stat_ctime = time( NULL );
+  return 0;
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index aae208c..8bc3d85 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -1118,10 +1118,9 @@ static int rtems_jffs2_statvfs(
 	return 0;
-static int rtems_jffs2_utime(
+static int rtems_jffs2_utimens(
-	time_t actime,
-	time_t modtime
 	struct _inode *inode = rtems_jffs2_get_inode_by_location(loc);
@@ -1129,8 +1128,8 @@ static int rtems_jffs2_utime(
 	int eno;
 	iattr.ia_valid = ATTR_ATIME | ATTR_MTIME | ATTR_CTIME;
-	iattr.ia_atime = actime;
-	iattr.ia_mtime = modtime;
+	iattr.ia_atime = times[0].tv_sec;
+	iattr.ia_mtime = times[1].tv_sec;
 	iattr.ia_ctime = get_seconds();
 	eno = -jffs2_do_setattr(inode, &iattr);
@@ -1186,7 +1185,7 @@ static const rtems_filesystem_operations_table rtems_jffs2_ops = {
 	.fsunmount_me_h = rtems_jffs2_fsunmount,
-	.utime_h = rtems_jffs2_utime,
+	.utimens_h = rtems_jffs2_utimens,
 	.symlink_h = rtems_jffs2_symlink,
 	.readlink_h = rtems_jffs2_readlink,
 	.rename_h = rtems_jffs2_rename,
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
index 35db9ee..0efab2c 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
@@ -296,16 +296,14 @@ rtems_rfs_rtems_chown (const rtems_filesystem_location_info_t *pathloc,
  * This routine is the implementation of the utime() system call for the
  * RFS.
- * @param pathloc
- * @param atime
- * @param mtime
+ * @param pathloc The path to the file to be modified
+ * @param times The times to update the file to
  * return int
 static int
-rtems_rfs_rtems_utime(const rtems_filesystem_location_info_t* pathloc,
-                      time_t                                  atime,
-                      time_t                                  mtime)
+rtems_rfs_rtems_utimens(const rtems_filesystem_location_info_t* pathloc,
+                        struct timespec                         times[2])
   rtems_rfs_file_system* fs = rtems_rfs_rtems_pathloc_dev (pathloc);
   rtems_rfs_ino          ino = rtems_rfs_rtems_get_pathloc_ino (pathloc);
@@ -318,8 +316,8 @@ rtems_rfs_rtems_utime(const rtems_filesystem_location_info_t* pathloc,
     return rtems_rfs_rtems_error ("utime: read inode", rc);
-  rtems_rfs_inode_set_atime (&inode, atime);
-  rtems_rfs_inode_set_mtime (&inode, mtime);
+  rtems_rfs_inode_set_atime (&inode, times[0].tv_sec);
+  rtems_rfs_inode_set_mtime (&inode, times[1].tv_sec);
   rc = rtems_rfs_inode_close (fs, &inode);
   if (rc)
@@ -735,7 +733,7 @@ const rtems_filesystem_operations_table rtems_rfs_ops =
   .fsunmount_me_h = rtems_rfs_rtems_shutdown,
-  .utime_h        = rtems_rfs_rtems_utime,
+  .utimens_h      = rtems_rfs_rtems_utimens,
   .symlink_h      = rtems_rfs_rtems_symlink,
   .readlink_h     = rtems_rfs_rtems_readlink,
   .rename_h       = rtems_rfs_rtems_rename,
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 9639051..6df98c9 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -804,7 +804,7 @@ source:
 - cpukit/libfs/src/defaults/default_statvfs.c
 - cpukit/libfs/src/defaults/default_symlink.c
 - cpukit/libfs/src/defaults/default_unmount.c
-- cpukit/libfs/src/defaults/default_utime.c
+- cpukit/libfs/src/defaults/default_utimens.c
 - cpukit/libfs/src/defaults/default_write.c
 - cpukit/libfs/src/defaults/default_writev.c
 - cpukit/libfs/src/dosfs/fat.c
@@ -861,7 +861,7 @@ source:
 - cpukit/libfs/src/imfs/imfs_stat_file.c
 - cpukit/libfs/src/imfs/imfs_symlink.c
 - cpukit/libfs/src/imfs/imfs_unmount.c
-- cpukit/libfs/src/imfs/imfs_utime.c
+- cpukit/libfs/src/imfs/imfs_utimens.c
 - cpukit/libfs/src/imfs/ioman.c
 - cpukit/libfs/src/pipe/fifo.c
 - cpukit/libfs/src/pipe/pipe.c
1.8.3.1
