[PATCH v2 5/5] Change filesystem utime_h handler to utimens_h
Mon May 10 17:48:39 UTC 2021
On Thu, May 6, 2021 at 1:51 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Also updated licenses.
> Closes #4400
>  bsps/arm/csb337/umon/tfsDriver.c            |  2 +-
>  cpukit/Makefile.am                          |  4 +--
>  cpukit/include/rtems/confdefs/libio.h       |  4 +--
>  cpukit/include/rtems/imfs.h                 |  7 +++--
>  cpukit/include/rtems/libio.h                | 21 +++++++--------
>  cpukit/libcsupport/src/__usrenv.c           |  9 +++----
>  cpukit/libfs/src/defaults/default_ops.c     |  2 +-
>  cpukit/libfs/src/defaults/default_utime.c   | 32 ----------------------
>  cpukit/libfs/src/defaults/default_utimens.c | 33 +++++++++++++++++++++++
>  cpukit/libfs/src/dosfs/msdos_init.c         | 11 ++++----
>  cpukit/libfs/src/ftpfs/ftpfs.c              |  2 +-
>  cpukit/libfs/src/ftpfs/tftpDriver.c         |  2 +-
>  cpukit/libfs/src/imfs/imfs_init.c           |  4 +--
>  cpukit/libfs/src/imfs/imfs_utime.c          | 41 ----------------------------
>  cpukit/libfs/src/imfs/imfs_utimens.c        | 42 +++++++++++++++++++++++++++++
>  cpukit/libfs/src/jffs2/src/fs-rtems.c       | 11 ++++----
>  cpukit/libfs/src/rfs/rtems-rfs-rtems.c      | 16 +++++------
>  spec/build/cpukit/librtemscpu.yml           |  4 +--
>  18 files changed, 120 insertions(+), 127 deletions(-)
>  delete mode 100644 cpukit/libfs/src/defaults/default_utime.c
>  create mode 100644 cpukit/libfs/src/defaults/default_utimens.c
>  delete mode 100644 cpukit/libfs/src/imfs/imfs_utime.c
>  create mode 100644 cpukit/libfs/src/imfs/imfs_utimens.c
> diff --git a/bsps/arm/csb337/umon/tfsDriver.c b/bsps/arm/csb337/umon/tfsDriver.c
> index 0195346..caf3a4b 100644
> --- a/bsps/arm/csb337/umon/tfsDriver.c
> +++ b/bsps/arm/csb337/umon/tfsDriver.c
> @@ -657,7 +657,7 @@ static const rtems_filesystem_operations_table  rtems_tfs_ops = {
>    .mount_h = rtems_filesystem_default_mount,
>    .unmount_h = rtems_filesystem_default_unmount,
>    .fsunmount_me_h = rtems_filesystem_default_fsunmount,
> -  .utime_h = rtems_filesystem_default_utime,
> +  .utimens_h = rtems_filesystem_default_utimens,
>    .symlink_h = rtems_filesystem_default_symlink,
>    .readlink_h = rtems_filesystem_default_readlink,
>    .rename_h = rtems_filesystem_default_rename,
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index 29b4207..c144773 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -377,7 +377,7 @@ librtemscpu_a_SOURCES += libfs/src/defaults/default_rmnod.c
>  librtemscpu_a_SOURCES += libfs/src/defaults/default_statvfs.c
>  librtemscpu_a_SOURCES += libfs/src/defaults/default_symlink.c
>  librtemscpu_a_SOURCES += libfs/src/defaults/default_unmount.c
> -librtemscpu_a_SOURCES += libfs/src/defaults/default_utime.c
> +librtemscpu_a_SOURCES += libfs/src/defaults/default_utimens.c
>  librtemscpu_a_SOURCES += libfs/src/defaults/default_write.c
>  librtemscpu_a_SOURCES += libfs/src/defaults/default_writev.c
>  librtemscpu_a_SOURCES += libfs/src/dosfs/fat.c
> @@ -434,7 +434,7 @@ librtemscpu_a_SOURCES += libfs/src/imfs/imfs_stat.c
>  librtemscpu_a_SOURCES += libfs/src/imfs/imfs_stat_file.c
>  librtemscpu_a_SOURCES += libfs/src/imfs/imfs_symlink.c
>  librtemscpu_a_SOURCES += libfs/src/imfs/imfs_unmount.c
> -librtemscpu_a_SOURCES += libfs/src/imfs/imfs_utime.c
> +librtemscpu_a_SOURCES += libfs/src/imfs/imfs_utimens.c
>  librtemscpu_a_SOURCES += libfs/src/imfs/ioman.c
>  librtemscpu_a_SOURCES += libfs/src/pipe/fifo.c
>  librtemscpu_a_SOURCES += libfs/src/pipe/pipe.c
> diff --git a/cpukit/include/rtems/confdefs/libio.h b/cpukit/include/rtems/confdefs/libio.h
> index 16a4fb69..1b84f8c 100644
> --- a/cpukit/include/rtems/confdefs/libio.h
> +++ b/cpukit/include/rtems/confdefs/libio.h
> @@ -231,9 +231,9 @@ static const rtems_filesystem_operations_table IMFS_root_ops = {
>    #endif
>    #ifdef CONFIGURE_IMFS_DISABLE_UTIME
> -    rtems_filesystem_default_utime,
> +    rtems_filesystem_default_utimens,
>    #else
> -    IMFS_utime,
> +    IMFS_utimens,
>    #endif
>    #ifdef CONFIGURE_IMFS_DISABLE_SYMLINK
> diff --git a/cpukit/include/rtems/imfs.h b/cpukit/include/rtems/imfs.h
> index b2a9868..6e0d5d5 100644
> --- a/cpukit/include/rtems/imfs.h
> +++ b/cpukit/include/rtems/imfs.h
> @@ -5,7 +5,7 @@
> - *  COPYRIGHT (c) 1989-2011.
> + *  COPYRIGHT (c) 1989-2011, 2021.
>   *  On-Line Applications Research Corporation (OAR).
>   *  The license and distribution terms for this file may be
fix license?
> @@ -954,10 +954,9 @@ extern int device_ftruncate(
>   * This routine is the implementation of the utime() system
>   * call for the IMFS.
> -extern int IMFS_utime(
> +extern int IMFS_utimens(
>    const rtems_filesystem_location_info_t *loc,
> -  time_t actime,
> -  time_t modtime
> +  struct timespec times[2]
> diff --git a/cpukit/include/rtems/libio.h b/cpukit/include/rtems/libio.h
> index 519e797..99543ba 100644
> --- a/cpukit/include/rtems/libio.h
> +++ b/cpukit/include/rtems/libio.h
> @@ -11,7 +11,7 @@
> - *  COPYRIGHT (c) 1989-2008.
> + *  COPYRIGHT (c) 1989-2008, 2021.
>   *  Modifications to support reference counting in the file system are
> @@ -375,18 +375,16 @@ typedef int (*rtems_filesystem_rmnod_t)(
>   * @brief Set node access and modification times.
>   * @param[in] loc The location of the node.
> - * @param[in] actime Access time for the node.
> - * @param[in] modtime Modification for the node.
> + * @param[in] times Access and modification times for the node
>   * @retval 0 Successful operation.
>   * @retval -1 An error occurred.  The errno is set to indicate the error.
> - * @see rtems_filesystem_default_utime().
> + * @see rtems_filesystem_default_utimens().
> -typedef int (*rtems_filesystem_utime_t)(
> +typedef int (*rtems_filesystem_utimens_t)(
> -  time_t actime,
> -  time_t modtime
> @@ -484,7 +482,7 @@ struct _rtems_filesystem_operations_table {
>    rtems_filesystem_mount_t mount_h;
>    rtems_filesystem_unmount_t unmount_h;
>    rtems_filesystem_fsunmount_me_t fsunmount_me_h;
> -  rtems_filesystem_utime_t utime_h;
> +  rtems_filesystem_utimens_t utimens_h;
>    rtems_filesystem_symlink_t symlink_h;
>    rtems_filesystem_readlink_t readlink_h;
>    rtems_filesystem_rename_t rename_h;
> @@ -644,12 +642,11 @@ void rtems_filesystem_default_fsunmount(
>   * @retval -1 Always.  The errno is set to ENOTSUP.
> - * @see rtems_filesystem_utime_t.
> + * @see rtems_filesystem_utimens_t.
> -int rtems_filesystem_default_utime(
> +int rtems_filesystem_default_utimens(
> -  time_t actime,
> -  time_t modtime
> diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
> index 5c25eaa..13b5700 100644
> --- a/cpukit/libcsupport/src/__usrenv.c
> +++ b/cpukit/libcsupport/src/__usrenv.c
> @@ -6,7 +6,7 @@
> @@ -145,10 +145,9 @@ static void null_op_fsunmount_me(
>    /* Do nothing */
> -static int null_op_utime(
> +static int null_op_utimens(
> -  time_t actime,
> -  time_t modtime
>    return -1;
> @@ -207,7 +206,7 @@ static const rtems_filesystem_operations_table null_ops = {
>    .mount_h = null_op_mount,
>    .unmount_h = null_op_unmount,
>    .fsunmount_me_h = null_op_fsunmount_me,
> -  .utime_h = null_op_utime,
> +  .utimens_h = null_op_utimens,
>    .symlink_h = null_op_symlink,
>    .readlink_h = null_op_readlink,
>    .rename_h = null_op_rename,
> diff --git a/cpukit/libfs/src/defaults/default_ops.c b/cpukit/libfs/src/defaults/default_ops.c
> index 63ad2ce..de317a2 100644
> --- a/cpukit/libfs/src/defaults/default_ops.c
> +++ b/cpukit/libfs/src/defaults/default_ops.c
> @@ -36,7 +36,7 @@ const rtems_filesystem_operations_table rtems_filesystem_operations_default = {
> diff --git a/cpukit/libfs/src/defaults/default_utime.c b/cpukit/libfs/src/defaults/default_utime.c
> deleted file mode 100644
> index aaf4e44..0000000
> --- a/cpukit/libfs/src/defaults/default_utime.c
> +++ /dev/null
> @@ -1,32 +0,0 @@
> - * @file
> - * @ingroup LibIOFSOps File System Operations
> - * @brief RTEMS Default File System sets file access and modification times
> - *  COPYRIGHT (c) 2010.
> - *  On-Line Applications Research Corporation (OAR).
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <rtems/libio_.h>
> -#include <rtems/seterr.h>
> -  const rtems_filesystem_location_info_t *loc,
> -  time_t actime,
> -  time_t modtime
> -  rtems_set_errno_and_return_minus_one( ENOTSUP );
> diff --git a/cpukit/libfs/src/defaults/default_utimens.c b/cpukit/libfs/src/defaults/default_utimens.c
> new file mode 100644
> index 0000000..f71c156
> --- /dev/null
> +++ b/cpukit/libfs/src/defaults/default_utimens.c
> @@ -0,0 +1,33 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup LibIOFSOps File System Operations
> + * @brief RTEMS Default File System sets file access and modification times
> + *  COPYRIGHT (c) 2010, 2021.
> + *  On-Line Applications Research Corporation (OAR).
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/libio_.h>
> +#include <rtems/seterr.h>
> +  const rtems_filesystem_location_info_t *loc,
> +  rtems_set_errno_and_return_minus_one( ENOTSUP );
> diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
> index 67b16b6..a96b973 100644
> --- a/cpukit/libfs/src/dosfs/msdos_init.c
> +++ b/cpukit/libfs/src/dosfs/msdos_init.c
> @@ -36,18 +36,17 @@ static int msdos_clone_node_info(rtems_filesystem_location_info_t *loc)
>      return fat_file_reopen(fat_fd);
> -static int msdos_utime(
> +static int msdos_utimens(
> -  time_t                                  actime,
> -  time_t                                  modtime
>      fat_file_fd_t *fat_fd = loc->node_access;
> -    if (actime != modtime)
> +    if (times[0].tv_sec != times[1].tv_sec)
> -    fat_file_set_mtime(fat_fd, modtime);
> +    fat_file_set_mtime(fat_fd, times[1].tv_sec);
>      return RC_OK;
> @@ -67,7 +66,7 @@ const rtems_filesystem_operations_table  msdos_ops = {
>    .fsunmount_me_h =  msdos_shut_down,
> -  .utime_h        =  msdos_utime,
> +  .utimens_h      =  msdos_utimens,
>    .rename_h       =  msdos_rename,
> diff --git a/cpukit/libfs/src/ftpfs/ftpfs.c b/cpukit/libfs/src/ftpfs/ftpfs.c
> index 5e0cb95..a0ee0fa 100644
> --- a/cpukit/libfs/src/ftpfs/ftpfs.c
> +++ b/cpukit/libfs/src/ftpfs/ftpfs.c
> @@ -1384,7 +1384,7 @@ static const rtems_filesystem_operations_table rtems_ftpfs_ops = {
>    .fsunmount_me_h = rtems_ftpfs_unmount_me,
> diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c b/cpukit/libfs/src/ftpfs/tftpDriver.c
> index 7cbb402..bc0e74a 100644
> --- a/cpukit/libfs/src/ftpfs/tftpDriver.c
> +++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
> @@ -1039,7 +1039,7 @@ static const rtems_filesystem_operations_table  rtems_tftp_ops = {
>      .fsunmount_me_h = rtems_tftpfs_shutdown,
> diff --git a/cpukit/libfs/src/imfs/imfs_init.c b/cpukit/libfs/src/imfs/imfs_init.c
> index 1b9b769..5b8d3dd 100644
> --- a/cpukit/libfs/src/imfs/imfs_init.c
> +++ b/cpukit/libfs/src/imfs/imfs_init.c
> @@ -7,7 +7,7 @@
> - *  COPYRIGHT (c) 1989-1999.
> + *  COPYRIGHT (c) 1989-1999, 2021.
> @@ -40,7 +40,7 @@ static const rtems_filesystem_operations_table IMFS_ops = {
>    .mount_h = IMFS_mount,
>    .unmount_h = IMFS_unmount,
>    .fsunmount_me_h = IMFS_fsunmount,
> -  .utime_h = IMFS_utime,
> +  .utimens_h = IMFS_utimens,
>    .symlink_h = IMFS_symlink,
>    .readlink_h = IMFS_readlink,
>    .rename_h = IMFS_rename,
> diff --git a/cpukit/libfs/src/imfs/imfs_utime.c b/cpukit/libfs/src/imfs/imfs_utime.c
> index 21e5139..0000000
> --- a/cpukit/libfs/src/imfs/imfs_utime.c
> +++ /dev/null
> @@ -1,41 +0,0 @@
> - * @file
> - * @ingroup IMFS
> - * @brief Set IMFS File Access and Modification Times
> -#endif
> -#include <rtems/imfs.h>
> -#include <sys/time.h>
> -int IMFS_utime(
> -  time_t actime,
> -  time_t modtime
> -  IMFS_jnode_t *the_jnode;
> -  the_jnode = (IMFS_jnode_t *) loc->node_access;
> -  the_jnode->stat_atime = actime;
> -  the_jnode->stat_mtime = modtime;
> -  the_jnode->stat_ctime = time( NULL );
> -  return 0;
> diff --git a/cpukit/libfs/src/imfs/imfs_utimens.c b/cpukit/libfs/src/imfs/imfs_utimens.c
> index 0000000..92f2528
> --- /dev/null
> +++ b/cpukit/libfs/src/imfs/imfs_utimens.c
> @@ -0,0 +1,42 @@
> + * @file
> + * @ingroup IMFS
> + * @brief Set IMFS File Access and Modification Times
Update license? (This doesn't match the SPDX...)
> +#endif
> +#include <rtems/imfs.h>
> +#include <sys/time.h>
> +int IMFS_utimens(
> +  IMFS_jnode_t *the_jnode;
> +  the_jnode = (IMFS_jnode_t *) loc->node_access;
> +  the_jnode->stat_atime = times[0].tv_sec;
> +  the_jnode->stat_mtime = times[1].tv_sec;
> +  the_jnode->stat_ctime = time( NULL );
> +  return 0;
> diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
> index aae208c..8bc3d85 100644
> --- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
> +++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
> @@ -1118,10 +1118,9 @@ static int rtems_jffs2_statvfs(
>         return 0;
> -static int rtems_jffs2_utime(
> +static int rtems_jffs2_utimens(
> -       time_t actime,
> -       time_t modtime
>         struct _inode *inode = rtems_jffs2_get_inode_by_location(loc);
> @@ -1129,8 +1128,8 @@ static int rtems_jffs2_utime(
>         int eno;
>         iattr.ia_valid = ATTR_ATIME | ATTR_MTIME | ATTR_CTIME;
> -       iattr.ia_atime = actime;
> -       iattr.ia_mtime = modtime;
> +       iattr.ia_atime = times[0].tv_sec;
> +       iattr.ia_mtime = times[1].tv_sec;
>         iattr.ia_ctime = get_seconds();
>         eno = -jffs2_do_setattr(inode, &iattr);
> @@ -1186,7 +1185,7 @@ static const rtems_filesystem_operations_table rtems_jffs2_ops = {
>         .fsunmount_me_h = rtems_jffs2_fsunmount,
> -       .utime_h = rtems_jffs2_utime,
> +       .utimens_h = rtems_jffs2_utimens,
>         .symlink_h = rtems_jffs2_symlink,
>         .readlink_h = rtems_jffs2_readlink,
>         .rename_h = rtems_jffs2_rename,
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> index 35db9ee..0efab2c 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> @@ -296,16 +296,14 @@ rtems_rfs_rtems_chown (const rtems_filesystem_location_info_t *pathloc,
>   * This routine is the implementation of the utime() system call for the
>   * RFS.
> - * @param pathloc
> - * @param atime
> - * @param mtime
> + * @param pathloc The path to the file to be modified
> + * @param times The times to update the file to
>   * return int
>  static int
> -rtems_rfs_rtems_utime(const rtems_filesystem_location_info_t* pathloc,
> -                      time_t                                  atime,
> -                      time_t                                  mtime)
> +rtems_rfs_rtems_utimens(const rtems_filesystem_location_info_t* pathloc,
> +                        struct timespec                         times[2])
>    rtems_rfs_file_system* fs = rtems_rfs_rtems_pathloc_dev (pathloc);
>    rtems_rfs_ino          ino = rtems_rfs_rtems_get_pathloc_ino (pathloc);
> @@ -318,8 +316,8 @@ rtems_rfs_rtems_utime(const rtems_filesystem_location_info_t* pathloc,
>      return rtems_rfs_rtems_error ("utime: read inode", rc);
> -  rtems_rfs_inode_set_atime (&inode, atime);
> -  rtems_rfs_inode_set_mtime (&inode, mtime);
> +  rtems_rfs_inode_set_atime (&inode, times[0].tv_sec);
> +  rtems_rfs_inode_set_mtime (&inode, times[1].tv_sec);
>    rc = rtems_rfs_inode_close (fs, &inode);
>    if (rc)
> @@ -735,7 +733,7 @@ const rtems_filesystem_operations_table rtems_rfs_ops =
>    .fsunmount_me_h = rtems_rfs_rtems_shutdown,
> -  .utime_h        = rtems_rfs_rtems_utime,
> +  .utimens_h      = rtems_rfs_rtems_utimens,
>    .symlink_h      = rtems_rfs_rtems_symlink,
>    .readlink_h     = rtems_rfs_rtems_readlink,
>    .rename_h       = rtems_rfs_rtems_rename,
Which filesystems have been tested with this change?
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index 9639051..6df98c9 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -804,7 +804,7 @@ source:
>  - cpukit/libfs/src/defaults/default_statvfs.c
>  - cpukit/libfs/src/defaults/default_symlink.c
>  - cpukit/libfs/src/defaults/default_unmount.c
> -- cpukit/libfs/src/defaults/default_utime.c
> +- cpukit/libfs/src/defaults/default_utimens.c
>  - cpukit/libfs/src/defaults/default_write.c
>  - cpukit/libfs/src/defaults/default_writev.c
>  - cpukit/libfs/src/dosfs/fat.c
> @@ -861,7 +861,7 @@ source:
>  - cpukit/libfs/src/imfs/imfs_stat_file.c
>  - cpukit/libfs/src/imfs/imfs_symlink.c
>  - cpukit/libfs/src/imfs/imfs_unmount.c
> -- cpukit/libfs/src/imfs/imfs_utime.c
> +- cpukit/libfs/src/imfs/imfs_utimens.c
>  - cpukit/libfs/src/imfs/ioman.c
>  - cpukit/libfs/src/pipe/fifo.c
>  - cpukit/libfs/src/pipe/pipe.c
> 1.8.3.1
> devel mailing list
> devel at rtems.org
