FVP_BaseR_Cortex-R52x1 not exist when testing arm/fvp_cortex_r52
Joel Sherrill
joel at rtems.org
Fri May 7 17:07:57 UTC 2021
On Fri, May 7, 2021 at 11:42 AM Sebastian Huber <
> On 07/05/2021 17:12, Đức Anh wrote:
> > Dear all,
> > I built arm/fvp_cortex_r52 on the master branch, commit a1679af3805.
> > When I run rtems-test for this BSP, the program report
> > that FVP_BaseR_Cortex-R52x1 does not exist. So that all the tests failed.
> It works for me:
> [4329/4329] Linking
> /tmp/sh/b-rtems/arm/fvp_cortex_r52/testsuites/validation/ts-validation-1.exe
> Waf: Leaving directory `/tmp/sh/b-rtems/arm/fvp_cortex_r52'
> 'build_arm/fvp_cortex_r52' finished successfully (12.065s)
> ~/src/rtems (master) > rtems-test --rtems-bsp=fvp_cortex_r52x4
> build/arm/fvp_cortex_r52
Not sure why I missed the ini file but thanks for posting.
What simulator does this run on? How do you get it? I would like to add
it to my build sweeps.
Thanks.
--joel
> 657/657] p:596 f:6 u:6 e:0 I:0 B:3 t:0 L:0 i:0 W:0 |
> arm/fvp_cortex_r52: ts-validation-1.exe
> Passed: 641
> Failed: 6
> User Input: 6
> Expected Fail: 0
> Indeterminate: 0
> Benchmark: 3
> Timeout: 0
> Test too long: 1
> Invalid: 0
> Wrong Version: 0
> Wrong Build: 0
> Wrong Tools: 0
> Total: 657
> Failures:
> dl06.exe
> dl09.exe
> ttest02.exe
> minimum.exe
> smpmutex02.exe
> sptimecounter02.exe
> User Input:
> dl10.exe
> monitor.exe
> termios.exe
> top.exe
> fileio.exe
> capture.exe
> Benchmark:
> dhrystone.exe
> whetstone.exe
> linpack.exe
> Test too long:
> smplock01.exe
> Average test time: 0:00:00.547722
> Testing time : 0:05:59.853078
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210507/e9bcd9b0/attachment-0001.html>
