FVP_BaseR_Cortex-R52x1 not exist when testing arm/fvp_cortex_r52
Fri May 7 17:12:05 UTC 2021
On 07/05/2021 19:07, Joel Sherrill wrote:
> On Fri, May 7, 2021 at 11:42 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 07/05/2021 17:12, Đức Anh wrote:
>      > Dear all,
>      > I built arm/fvp_cortex_r52 on the master branch, commit a1679af3805.
>      > When I run rtems-test for this BSP, the program report
>      > that FVP_BaseR_Cortex-R52x1 does not exist. So that all the tests
>     failed.
>     It works for me:
>     [4329/4329] Linking
>     /tmp/sh/b-rtems/arm/fvp_cortex_r52/testsuites/validation/ts-validation-1.exe
>     Waf: Leaving directory `/tmp/sh/b-rtems/arm/fvp_cortex_r52'
>     'build_arm/fvp_cortex_r52' finished successfully (12.065s)
>     ~/src/rtems (master) > rtems-test --rtems-bsp=fvp_cortex_r52x4
>     build/arm/fvp_cortex_r52
> Not sure why I missed the ini file but thanks for posting.
> What simulator does this run on? How do you get it? I would like to add
> it to my build sweeps.
This BSP is still work in progress. I had to switch to other projects.
The simulator needs a license from Arm:
https://developer.arm.com/tools-and-software/simulation-models/fixed-virtual-platforms
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
