[PATCH v5] rtems-debugger: Fixed 32bit pointers
Stephen Clark
stephen.clark at oarcorp.com
Fri May 7 20:13:07 UTC 2021
Using 32bit types like uint32_t for pointers creates issues on 64 bit
architectures like AArch64. Replaced occurrences of these with uintptr_t,
which will work for both 32 and 64 bit architectures. Added hex_decode_addr
function to rtems-debugger. Changed rtems_debugger_target_swbreak_control()
parameter to DB_ADDR.
.../rtems/debugger/rtems-debugger-server.h | 5 ++++
cpukit/libdebugger/rtems-debugger-server.c | 30 +++++++++++++++----
cpukit/libdebugger/rtems-debugger-target.c | 2 +-
cpukit/libdebugger/rtems-debugger-target.h | 2 +-
4 files changed, 32 insertions(+), 7 deletions(-)
diff --git a/cpukit/include/rtems/debugger/rtems-debugger-server.h b/cpukit/include/rtems/debugger/rtems-debugger-server.h
index 2189aac873..beff302641 100644
--- a/cpukit/include/rtems/debugger/rtems-debugger-server.h
+++ b/cpukit/include/rtems/debugger/rtems-debugger-server.h
@@ -50,6 +50,11 @@ extern "C" {
#define DB_UINT uint32_t
+ * Data type for addresses. Here for 64bit support.
+#define DB_ADDR uintptr_t
* Debugger signals.
diff --git a/cpukit/libdebugger/rtems-debugger-server.c b/cpukit/libdebugger/rtems-debugger-server.c
index 975ec23a30..2ada418a79 100644
--- a/cpukit/libdebugger/rtems-debugger-server.c
+++ b/cpukit/libdebugger/rtems-debugger-server.c
@@ -154,6 +154,26 @@ hex_encode(int val)
return "0123456789abcdef"[val & 0xf];
+static inline DB_ADDR
+hex_decode_addr(const uint8_t* data)
+ DB_ADDR ui = 0;
+ size_t i;
+ if (data[0] == '-') {
+ if (data[1] == '1')
+ ui = (DB_ADDR) -1;
+ else {
+ for (i = 0; i < (sizeof(ui) * 2); ++i) {
+ int v = hex_decode(data[i]);
+ if (v < 0)
+ break;
+ ui = (ui << 4) | v;
+ return ui;
static inline DB_UINT
hex_decode_uint(const uint8_t* data)
@@ -1438,10 +1458,10 @@ remote_read_memory(uint8_t* buffer, int size)
if (comma == NULL)
remote_packet_out_str(r_E01);
else {
- DB_UINT addr;
+ uintptr_t addr;
DB_UINT length;
int r;
- addr = hex_decode_uint(&buffer[1]);
+ addr = hex_decode_addr(&buffer[1]);
length = hex_decode_uint((const uint8_t*) comma + 1);
remote_packet_out_reset();
r = rtems_debugger_target_start_memory_access();
@@ -1468,10 +1488,10 @@ remote_write_memory(uint8_t* buffer, int size)
comma = strchr((const char*) buffer, ',');
colon = strchr((const char*) buffer, ':');
if (comma != NULL && colon != NULL) {
- DB_UINT addr;
+ uintptr_t addr;
DB_UINT length;
int r;
if (r == 0) {
@@ -1521,7 +1541,7 @@ remote_breakpoints(bool insert, uint8_t* buffer, int size)
uint32_t capabilities;
DB_UINT addr;
DB_UINT kind;
- addr = hex_decode_uint((const uint8_t*) comma1 + 1);
+ addr = hex_decode_addr((const uint8_t*) comma1 + 1);
kind = hex_decode_uint((const uint8_t*)comma2 + 1);
capabilities = rtems_debugger_target_capabilities();
switch (buffer[1]) {
diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
index bf7579700d..99da21921b 100644
--- a/cpukit/libdebugger/rtems-debugger-target.c
+++ b/cpukit/libdebugger/rtems-debugger-target.c
@@ -168,7 +168,7 @@ rtems_debugger_target_reg_table_size(void)
int
-rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr, DB_UINT kind)
+rtems_debugger_target_swbreak_control(bool insert, DB_ADDR addr, DB_UINT kind)
rtems_debugger_target* target = rtems_debugger->target;
rtems_debugger_target_swbreak* swbreaks;
diff --git a/cpukit/libdebugger/rtems-debugger-target.h b/cpukit/libdebugger/rtems-debugger-target.h
index f2abbe5fd3..db356e1f07 100644
--- a/cpukit/libdebugger/rtems-debugger-target.h
+++ b/cpukit/libdebugger/rtems-debugger-target.h
@@ -200,7 +200,7 @@ extern void rtems_debugger_target_exception_print(CPU_Exception_frame* frame);
* Software breakpoints. These are also referred to as memory breakpoints.
extern int rtems_debugger_target_swbreak_control(bool insert,
- DB_UINT addr,
+ uintptr_t addr,
DB_UINT kind);
2.27.0
