[PATCH] user/bld/index.rst: removed references to legacy network config options
Vijay Kumar Banerjee
vijay at rtems.org
Sat May 8 04:14:17 UTC 2021
Hi Harrison,
It's very close, just one little change....
On Fri, May 7, 2021 at 5:02 PM Harrison Gerber <gerberhe11 at gmail.com> wrote:
> From: Harrison <hgerber at uccs.edu>
As it was mentioned in your last review. Please use your full legal
name in the patches for attribution purposes.
Thank you for the patch.
Best regards,
Vijay
> user/bld/index.rst | 7 -------
> 1 file changed, 7 deletions(-)
> diff --git a/user/bld/index.rst b/user/bld/index.rst
> index ebedf5a..411b3a2 100644
> --- a/user/bld/index.rst
> +++ b/user/bld/index.rst
> @@ -309,10 +309,6 @@ in the configuration file.
> Set ``RTEMS_MULTIPROCESSING`` to ``True`` or ``False`` in the BSP
> section of the configuration file.
> -``--enable-networking`` | ``--disable-networking``
> - Set ``RTEMS_NETWORKING`` to ``True`` or ``False`` in the BSP section of
> - the configuration file.
> ``--enable-paravirt`` | ``--disable-paravirt``
> Set ``RTEMS_PARAVIRT`` to ``True`` or ``False`` in the BSP section of
> @@ -354,9 +350,6 @@ Please have a look at the following example configuration file.
> # --enable-multiprocessing
> RTEMS_MULTIPROCESSING = False
> - # --enable-networking
> - RTEMS_NETWORKING = True
> # --disable-paravirt
> RTEMS_PARAVIRT = False
> 2.25.1
> devel mailing list
> devel at rtems.org
