[PATCH] user/bld/index.rst: removed references to legacy network config options
Harrison Gerber
gerberhe11 at gmail.com
Fri May 7 23:02:31 UTC 2021
user/bld/index.rst | 7 -------
1 file changed, 7 deletions(-)
diff --git a/user/bld/index.rst b/user/bld/index.rst
index ebedf5a..411b3a2 100644
--- a/user/bld/index.rst
+++ b/user/bld/index.rst
@@ -309,10 +309,6 @@ in the configuration file.
Set ``RTEMS_MULTIPROCESSING`` to ``True`` or ``False`` in the BSP
section of the configuration file.
-``--enable-networking`` | ``--disable-networking``
- Set ``RTEMS_NETWORKING`` to ``True`` or ``False`` in the BSP section of
- the configuration file.
``--enable-paravirt`` | ``--disable-paravirt``
Set ``RTEMS_PARAVIRT`` to ``True`` or ``False`` in the BSP section of
@@ -354,9 +350,6 @@ Please have a look at the following example configuration file.
# --enable-multiprocessing
RTEMS_MULTIPROCESSING = False
- # --enable-networking
- RTEMS_NETWORKING = True
# --disable-paravirt
RTEMS_PARAVIRT = False
2.25.1
