FVP_BaseR_Cortex-R52x1 not exist when testing arm/fvp_cortex_r52
Đức Anh
dauto98 at gmail.com
Sat May 8 09:39:02 UTC 2021
Hi All,
Did you mean I need to buy Fixed Virtual Platform from ARM in order to run
FVP BSP?
Duc Anh
Vào Th 6, 7 thg 5, 2021 vào lúc 20:20 Joel Sherrill <joel at rtems.org> đã
viết:
> On Fri, May 7, 2021 at 12:12 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 07/05/2021 19:07, Joel Sherrill wrote:
>> > On Fri, May 7, 2021 at 11:42 AM Sebastian Huber
>> > <sebastian.huber at embedded-brains.de
>> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> > On 07/05/2021 17:12, Đức Anh wrote:
>> > > Dear all,
>> > > I built arm/fvp_cortex_r52 on the master branch,
>> commit a1679af3805.
>> > > When I run rtems-test for this BSP, the program report
>> > > that FVP_BaseR_Cortex-R52x1 does not exist. So that all the tests
>> > failed.
>> > It works for me:
>> > [4329/4329] Linking
>> /tmp/sh/b-rtems/arm/fvp_cortex_r52/testsuites/validation/ts-validation-1.exe
>> > Waf: Leaving directory `/tmp/sh/b-rtems/arm/fvp_cortex_r52'
>> > 'build_arm/fvp_cortex_r52' finished successfully (12.065s)
>> > ~/src/rtems (master) > rtems-test --rtems-bsp=fvp_cortex_r52x4
>> > build/arm/fvp_cortex_r52
>> > Not sure why I missed the ini file but thanks for posting.
>> > What simulator does this run on? How do you get it? I would like to add
>> > it to my build sweeps.
>> This BSP is still work in progress. I had to switch to other projects.
>> The simulator needs a license from Arm:
>> https://developer.arm.com/tools-and-software/simulation-models/fixed-virtual-platforms
> Thanks for the info. Guess it will get a readme and short section in the
> users guide eventually. At least until then, this email thread should show
> up.
> --joel
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210508/983e4bdf/attachment-0001.html>
