FVP_BaseR_Cortex-R52x1 not exist when testing arm/fvp_cortex_r52
Joel Sherrill
joel at rtems.org
Fri May 7 18:20:14 UTC 2021
On Fri, May 7, 2021 at 12:12 PM Sebastian Huber <
> On 07/05/2021 19:07, Joel Sherrill wrote:
> > On Fri, May 7, 2021 at 11:42 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 07/05/2021 17:12, Đức Anh wrote:
> > > Dear all,
> > > I built arm/fvp_cortex_r52 on the master branch,
> commit a1679af3805.
> > > When I run rtems-test for this BSP, the program report
> > > that FVP_BaseR_Cortex-R52x1 does not exist. So that all the tests
> > failed.
> > It works for me:
> > [4329/4329] Linking
> /tmp/sh/b-rtems/arm/fvp_cortex_r52/testsuites/validation/ts-validation-1.exe
> > Waf: Leaving directory `/tmp/sh/b-rtems/arm/fvp_cortex_r52'
> > 'build_arm/fvp_cortex_r52' finished successfully (12.065s)
> > ~/src/rtems (master) > rtems-test --rtems-bsp=fvp_cortex_r52x4
> > build/arm/fvp_cortex_r52
> > Not sure why I missed the ini file but thanks for posting.
> > What simulator does this run on? How do you get it? I would like to add
> > it to my build sweeps.
> This BSP is still work in progress. I had to switch to other projects.
> The simulator needs a license from Arm:
> https://developer.arm.com/tools-and-software/simulation-models/fixed-virtual-platforms
Thanks for the info. Guess it will get a readme and short section in the
users guide eventually. At least until then, this email thread should show
up.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210507/c1647c5a/attachment-0001.html>
