[PATCH] bsps/raspberrypi/console: Fix default console device
Gedare Bloom
gedare at rtems.org
Mon May 10 15:26:52 UTC 2021
On Thu, May 6, 2021 at 8:49 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> Hi Alan,
> On Thu, May 6, 2021 at 6:12 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
>> Hi Niteesh,
>> I was hoping to try this out as soon as I get some time. No later than weekend. So if nobody else is able to check it out, I will be able to provide some feedback soon.
>> I should be able to bring up the console on a RPi Zero W and RPi3, correct?
> the consoles should work on Zero W and Pi3 by default. They only fail to work when CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> this option is used. This is because when that option is used it calls console_initialize which checks if any boot options were present if none were
> given it defaults to pl011 which is the secondary UART in Zero w and Pi3 so we get no output. This patch defaults to the primary UART instead of
> pl011 depending on the board.
> Also, this patch should be applied on RTEMS 5 since we started supporting Pi3 and Zero w from RTEMS 5.
You'll need to provide a separate patch with a ticket to close on 5
for a backport. Wait until you get the approval for the master branch
though.
> Thanks,
> Niteesh.
>> Thanks,
>> Alan
>> From: Niteesh G. S.
>> Sent: Thursday, May 6, 2021 4:29 AM
>> To: Joel Sherrill; Christian Mauderer
>> Cc: rtems-devel at rtems.org
>> Subject: Re: [PATCH] bsps/raspberrypi/console: Fix default console device
>> ping.
>> On Sat, May 1, 2021 at 9:47 PM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>> On Sat, May 1, 2021 at 8:31 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Sat, May 1, 2021, 8:53 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>> Just to provide more context,
>> When the CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER option is used
>> and no --console option is provided, the console driver defaults to PL011.
>> In raspberry pi 3 and other models whose primary UART is not PL011, we get no output.
>> This patch fixes that by linking the primary UART to the console device.
>> Thanks,
>> Niteesh
>> On Sat, May 1, 2021 at 7:05 PM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
>> When no console argument is given, the driver defaults to pl011
>> this results in no output in case of Rpi3 whose primary uart is
>> miniuart.
>> This patch fixes that by defaulting to the primary uart when no
>> console option is provided.
>> Does the default need to vary by model?
>> Yes, the primary UART is different across models.
>> Rpi's have two UARTs PL011 and miniuart, on models which have Bluetooth
>> the PL011 is used to talk to the Bluetooth and miniuart acts as the primary UART.
>> Now we can change this by adding miniuart-bt to config.txt but the miniuart is
>> based on the VPU core and requires to add another option which sets the core to
>> a fixed freq.
>> bsps/arm/raspberrypi/console/console-config.c | 12 +++++++++---
>> 1 file changed, 9 insertions(+), 3 deletions(-)
>> diff --git a/bsps/arm/raspberrypi/console/console-config.c b/bsps/arm/raspberrypi/console/console-config.c
>> index 6b8eb80aa4..bd3a8d34c2 100644
>> --- a/bsps/arm/raspberrypi/console/console-config.c
>> +++ b/bsps/arm/raspberrypi/console/console-config.c
>> @@ -165,10 +165,16 @@ static void console_select( void )
>> }else {
>> - * If no command line option was given, default to PL011.
>> + * If no console option was given we default to the primary uarts.
>> + * The initialization of the uart's and BSP_output_char is already done
>> + * in the uart_probe function called before this. So now we can safely
>> + * compare BSP_output_char.
>> - BSP_output_char = output_char_pl011;
>> - link(PL011, CONSOLE_DEVICE_NAME);
>> + if (BSP_output_char == output_char_pl011) {
>> + link(PL011, CONSOLE_DEVICE_NAME);
>> + }else {
>> + link(MINIUART, CONSOLE_DEVICE_NAME);
>> 2.17.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
