[PATCH] bsps/raspberrypi/console: Fix default console device
Niteesh G. S. niteesh.gs at gmail.com
Mon May 10 19:36:11 UTC 2021
Hello Alan,
On Mon, May 10, 2021 at 8:04 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Hi Niteesh,
> I was able to build the current RTEMS master (raspberrypi BSP) and I
> was also able to successfully apply your patch and rebuild.
> However, I am having trouble getting RTEMS running on the Raspberry Pis I
> have.
> I tried it with and without the patch and I cannot get it to work. I
> tried a Raspberry Pi Zero, B+, and Zero W ( with the patch).
> I used these instructions for the firmware on SD card:
> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#raspberrypi
> I tried:
> - RTEMS master "arm/raspberrypi" BSP with and without the patch
> - RTEMS 5 branch "arm/raspberrypi" BSP
> - latest version of the RPI firmware files
> - an older version of the RPI firmware (from June 2016)
> I used the config.txt file that is recommended, but I did not have any
> command line options. I did not have my raspberry Pis connected to
> HDMI, only serial.
> Can you describe your setup?
> I know I have been through this before.
https://github.com/gs-niteesh/rpi3_RTEMS
These are the files I have in my boot partition. Usually, I use u-boot so
that
I can have a tftp server setup. But I am also able to load the images with
RPi loader using the same files.
I have some doco on how I create the images for the respective bootloader
type in the INFO.txt in the repo.
Also please make sure that you are up to date with the master branch. One
commit broke Rpi BSP but it was later fixed.
I was able to get the Hello example running using both Rpi bootloader and
uboot with the latest master branch.
For loading using u-boot I use the following commands
fatload mmc 0 0x1000 bcm2710-rpi-3-b.dtb
fatload mmc 0 0x200000 rtems.img
bootm 0x200000 - 0x1000
Thanks,
Niteesh
> Thanks,
> Alan
> On Thu, May 6, 2021 at 10:48 AM Niteesh G. S. <niteesh.gs at gmail.com>
> wrote:
> > Hi Alan,
> > On Thu, May 6, 2021 at 6:12 PM Alan Cudmore <alan.cudmore at gmail.com>
> wrote:
> >> Hi Niteesh,
> >> I was hoping to try this out as soon as I get some time. No later than
> weekend. So if nobody else is able to check it out, I will be able to
> provide some feedback soon.
> >> I should be able to bring up the console on a RPi Zero W and RPi3,
> correct?
> > the consoles should work on Zero W and Pi3 by default. They only fail to
> work when  CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > this option is used. This is because when that option is used it calls
> console_initialize which checks if any boot options were present if none
> were
> > given it defaults to pl011 which is the secondary UART in Zero w and Pi3
> so we get no output. This patch defaults to the primary UART instead of
> > pl011 depending on the board.
> > Also, this patch should be applied on RTEMS 5 since we started
> supporting Pi3 and Zero w from RTEMS 5.
> > Thanks,
> > Niteesh.
> >> Thanks,
> >> Alan
> >> From: Niteesh G. S.
> >> Sent: Thursday, May 6, 2021 4:29 AM
> >> To: Joel Sherrill; Christian Mauderer
> >> Cc: rtems-devel at rtems.org
> >> Subject: Re: [PATCH] bsps/raspberrypi/console: Fix default console
> device
> >> ping.
> >> On Sat, May 1, 2021 at 9:47 PM Niteesh G. S. <niteesh.gs at gmail.com>
> wrote:
> >> On Sat, May 1, 2021 at 8:31 PM Joel Sherrill <joel at rtems.org> wrote:
> >> On Sat, May 1, 2021, 8:53 AM Niteesh G. S. <niteesh.gs at gmail.com>
> wrote:
> >> Just to provide more context,
> >> When the CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER option is used
> >> and no --console option is provided, the console driver defaults to
> PL011.
> >> In raspberry pi 3 and other models whose primary UART is not PL011, we
> get no output.
> >> This patch fixes that by linking the primary UART to the console device.
> >> Thanks,
> >> Niteesh
> >> On Sat, May 1, 2021 at 7:05 PM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
> >> When no console argument is given, the driver defaults to pl011
> >> this results in no output in case of Rpi3 whose primary uart is
> >> miniuart.
> >> This patch fixes that by defaulting to the primary uart when no
> >> console option is provided.
> >> Does the default need to vary by model?
> >> Yes, the primary UART is different across models.
> >> Rpi's have two UARTs PL011 and miniuart, on models which have Bluetooth
> >> the PL011 is used to talk to the Bluetooth and miniuart acts as the
> primary UART.
> >> Now we can change this by adding miniuart-bt to config.txt but the
> miniuart is
> >> based on the VPU core and requires to add another option which sets the
> core to
> >> a fixed freq.
> >>  bsps/arm/raspberrypi/console/console-config.c | 12 +++++++++---
> >>  1 file changed, 9 insertions(+), 3 deletions(-)
> >> diff --git a/bsps/arm/raspberrypi/console/console-config.c
> b/bsps/arm/raspberrypi/console/console-config.c
> >> index 6b8eb80aa4..bd3a8d34c2 100644
> >> --- a/bsps/arm/raspberrypi/console/console-config.c
> >> +++ b/bsps/arm/raspberrypi/console/console-config.c
> >> @@ -165,10 +165,16 @@ static void console_select( void )
> >>    }else {
> >> -     * If no command line option was given, default to PL011.
> >> +     * If no console option was given we default to the primary uarts.
> >> +     * The initialization of the uart's and BSP_output_char is already
> done
> >> +     * in the uart_probe function called before this. So now we can
> safely
> >> +     * compare BSP_output_char.
> >> -    BSP_output_char = output_char_pl011;
> >> -    link(PL011, CONSOLE_DEVICE_NAME);
> >> +    if (BSP_output_char == output_char_pl011) {
> >> +      link(PL011, CONSOLE_DEVICE_NAME);
> >> +    }else {
> >> +      link(MINIUART, CONSOLE_DEVICE_NAME);
> >> 2.17.1
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210511/128f6156/attachment.html>
