[PATCH v1 1/2] rtemsbd: Remove machine dependent files and use the ones from freebsd
Jan Sommer jan.sommer at dlr.de
Mon May 10 14:29:07 UTC 2021
- Remove cpufunc.h, bus.h and _bus.h from rtemsbd. Otherwise the same
files will be installed for all target architectures which can lead to
incompatibilities
- Instead use the machine dependent header files from freebsd
 freebsd/sys/arm/include/machine/_bus.h        |  47 +
 freebsd/sys/arm/include/machine/bus.h         | 769 ++++++++++++++++
 freebsd/sys/arm64/include/machine/_bus.h      |  46 +
 freebsd/sys/arm64/include/machine/bus.h       | 469 ++++++++++
 freebsd/sys/powerpc/include/machine/_bus.h    |  50 +
 freebsd/sys/powerpc/include/machine/bus.h     | 467 ++++++++++
 freebsd/sys/riscv/include/machine/_bus.h      |  46 +
 freebsd/sys/riscv/include/machine/bus.h       | 469 ++++++++++
 freebsd/sys/riscv/include/machine/cpufunc.h   | 135 +++
 freebsd/sys/riscv/include/machine/riscvreg.h  | 246 +++++
 .../sys/sparc}/include/machine/_bus.h         |   0
 .../sys/sparc}/include/machine/bus.h          |   0
 freebsd/sys/sparc/include/machine/cpufunc.h   |   0
 freebsd/sys/sparc64/include/machine/_bus.h    |  41 +
 freebsd/sys/sparc64/include/machine/bus.h     | 852 ++++++++++++++++++
 rtemsbsd/include/machine/cpufunc.h            |   1 -
 16 files changed, 3637 insertions(+), 1 deletion(-)
 create mode 100644 freebsd/sys/arm/include/machine/_bus.h
 create mode 100644 freebsd/sys/arm/include/machine/bus.h
 create mode 100644 freebsd/sys/arm64/include/machine/_bus.h
 create mode 100644 freebsd/sys/arm64/include/machine/bus.h
 create mode 100644 freebsd/sys/powerpc/include/machine/_bus.h
 create mode 100644 freebsd/sys/powerpc/include/machine/bus.h
 create mode 100644 freebsd/sys/riscv/include/machine/_bus.h
 create mode 100644 freebsd/sys/riscv/include/machine/bus.h
 create mode 100644 freebsd/sys/riscv/include/machine/cpufunc.h
 create mode 100644 freebsd/sys/riscv/include/machine/riscvreg.h
 rename {rtemsbsd => freebsd/sys/sparc}/include/machine/_bus.h (100%)
 rename {rtemsbsd => freebsd/sys/sparc}/include/machine/bus.h (100%)
 create mode 100644 freebsd/sys/sparc/include/machine/cpufunc.h
 create mode 100644 freebsd/sys/sparc64/include/machine/_bus.h
 create mode 100644 freebsd/sys/sparc64/include/machine/bus.h
 delete mode 100644 rtemsbsd/include/machine/cpufunc.h
diff --git a/freebsd/sys/arm/include/machine/_bus.h b/freebsd/sys/arm/include/machine/_bus.h
new file mode 100644
index 00000000..9bb51e98
--- /dev/null
+++ b/freebsd/sys/arm/include/machine/_bus.h
@@ -0,0 +1,47 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2005 M. Warner Losh.
+ * are met:
+ *    notice, this list of conditions, and the following disclaimer,
+ *    without modification, immediately at the beginning of the file.
+ *    notice, this list of conditions and the following disclaimer in
+ *    the documentation and/or other materials provided with the
+ *    distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef ARM_INCLUDE__BUS_H
+#define ARM_INCLUDE__BUS_H
+ * Addresses (in bus space).
+typedef u_long bus_addr_t;
+typedef u_long bus_size_t;
+ * Access methods for bus space.
+typedef struct bus_space *bus_space_tag_t;
+typedef u_long bus_space_handle_t;
+#endif /* ARM_INCLUDE__BUS_H */
diff --git a/freebsd/sys/arm/include/machine/bus.h b/freebsd/sys/arm/include/machine/bus.h
index 00000000..37994f68
--- /dev/null
+++ b/freebsd/sys/arm/include/machine/bus.h
@@ -0,0 +1,769 @@
+/*	$NetBSD: bus.h,v 1.11 2003/07/28 17:35:54 thorpej Exp $	*/
+ * Copyright (c) 1996, 1997, 1998, 2001 The NetBSD Foundation, Inc.
+ * All rights reserved.
+ * This code is derived from software contributed to The NetBSD Foundation
+ * by Jason R. Thorpe of the Numerical Aerospace Simulation Facility,
+ * NASA Ames Research Center.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
+ * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+ * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+ * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
+ * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SPDX-License-Identifier: BSD-4-Clause
+ * Copyright (c) 1996 Charles M. Hannum.  All rights reserved.
+ * Copyright (c) 1996 Christopher G. Demetriou.  All rights reserved.
+ * are met:
+ * 3. All advertising materials mentioning features or use of this software
+ *    must display the following acknowledgement:
+ *      This product includes software developed by Christopher G. Demetriou
+ *	for the NetBSD Project.
+ * 4. The name of the author may not be used to endorse or promote products
+ *    derived from this software without specific prior written permission
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _MACHINE_BUS_H_
+#define _MACHINE_BUS_H_
+#include <machine/_bus.h>
+ *	int bus_space_map  (bus_space_tag_t t, bus_addr_t addr,
+ *	    bus_size_t size, int flags, bus_space_handle_t *bshp);
+ * Map a region of bus space.
+#define	BUS_SPACE_MAP_CACHEABLE		0x01
+#define	BUS_SPACE_MAP_LINEAR		0x02
+#define	BUS_SPACE_MAP_PREFETCHABLE     	0x04
+ * Bus space for ARM.
+ * The functions used most often are grouped together at the beginning to ensure
+ * that all the data fits into a single cache line.  The inline implementations
+ * of single read/write access these values a lot.
+struct bus_space {
+	/* Read/write single and barrier: the most commonly used functions. */
+	uint8_t	 (*bs_r_1)(bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	uint32_t (*bs_r_4)(bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	void	 (*bs_w_1)(bus_space_tag_t, bus_space_handle_t,
+			   bus_size_t, uint8_t);
+	void	 (*bs_w_4)(bus_space_tag_t, bus_space_handle_t,
+			   bus_size_t, uint32_t);
+	void	 (*bs_barrier)(bus_space_tag_t, bus_space_handle_t,
+			       bus_size_t, bus_size_t, int);
+	/* Backlink to parent (if copied), and implementation private data. */
+	struct bus_space *bs_parent;
+	void		 *bs_privdata;
+	/* mapping/unmapping */
+	int		(*bs_map) (bus_space_tag_t, bus_addr_t, bus_size_t,
+			    int, bus_space_handle_t *);
+	void		(*bs_unmap) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	int		(*bs_subregion) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, bus_size_t, bus_space_handle_t *);
+	/* allocation/deallocation */
+	int		(*bs_alloc) (bus_space_tag_t, bus_addr_t, bus_addr_t,
+			    bus_size_t, bus_size_t, bus_size_t, int,
+			    bus_addr_t *, bus_space_handle_t *);
+	void		(*bs_free) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t);
+	/* Read single, the less commonly used functions. */
+	uint16_t	(*bs_r_2) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	uint64_t	(*bs_r_8) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	/* read multiple */
+	void		(*bs_rm_1) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
+	    uint8_t *, bus_size_t);
+	void		(*bs_rm_2) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
+	    uint16_t *, bus_size_t);
+	void		(*bs_rm_4) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint32_t *, bus_size_t);
+	void		(*bs_rm_8) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint64_t *, bus_size_t);
+	/* read region */
+	void		(*bs_rr_1) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint8_t *, bus_size_t);
+	void		(*bs_rr_2) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint16_t *, bus_size_t);
+	void		(*bs_rr_4) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_rr_8) (bus_space_tag_t, bus_space_handle_t,
+	/* Write single, the less commonly used functions. */
+	void		(*bs_w_2) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint16_t);
+	void		(*bs_w_8) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint64_t);
+	/* write multiple */
+	void		(*bs_wm_1) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, const uint8_t *, bus_size_t);
+	void		(*bs_wm_2) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, const uint16_t *, bus_size_t);
+	void		(*bs_wm_4) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, const uint32_t *, bus_size_t);
+	void		(*bs_wm_8) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, const uint64_t *, bus_size_t);
+	/* write region */
+	void		(*bs_wr_1) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wr_2) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wr_4) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wr_8) (bus_space_tag_t, bus_space_handle_t,
+	/* set multiple */
+	void		(*bs_sm_1) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint8_t, bus_size_t);
+	void		(*bs_sm_2) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint16_t, bus_size_t);
+	void		(*bs_sm_4) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint32_t, bus_size_t);
+	void		(*bs_sm_8) (bus_space_tag_t, bus_space_handle_t,
+			    bus_size_t, uint64_t, bus_size_t);
+	/* set region */
+	void		(*bs_sr_1) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_sr_2) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_sr_4) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_sr_8) (bus_space_tag_t, bus_space_handle_t,
+	/* copy */
+	void		(*bs_c_1) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
+			    bus_space_handle_t, bus_size_t, bus_size_t);
+	void		(*bs_c_2) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
+	void		(*bs_c_4) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
+	void		(*bs_c_8) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
+	/* read stream (single) */
+	uint8_t	(*bs_r_1_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	uint16_t	(*bs_r_2_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	uint32_t	(*bs_r_4_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	uint64_t	(*bs_r_8_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
+	/* read multiple stream */
+	void		(*bs_rm_1_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
+	void		(*bs_rm_2_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
+	void		(*bs_rm_4_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_rm_8_s) (bus_space_tag_t, bus_space_handle_t,
+	/* read region stream */
+	void		(*bs_rr_1_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_rr_2_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_rr_4_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_rr_8_s) (bus_space_tag_t, bus_space_handle_t,
+	/* write stream (single) */
+	void		(*bs_w_1_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_w_2_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_w_4_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_w_8_s) (bus_space_tag_t, bus_space_handle_t,
+	/* write multiple stream */
+	void		(*bs_wm_1_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wm_2_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wm_4_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wm_8_s) (bus_space_tag_t, bus_space_handle_t,
+	/* write region stream */
+	void		(*bs_wr_1_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wr_2_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wr_4_s) (bus_space_tag_t, bus_space_handle_t,
+	void		(*bs_wr_8_s) (bus_space_tag_t, bus_space_handle_t,
+#if __ARM_ARCH < 6
+extern bus_space_tag_t arm_base_bs_tag;
+#endif
+ * Utility macros; INTERNAL USE ONLY.
+#define	__bs_c(a,b)		__CONCAT(a,b)
+#define	__bs_opname(op,size)	__bs_c(__bs_c(__bs_c(bs_,op),_),size)
+#define	__bs_nonsingle(type, sz, t, h, o, a, c)				\
+	(*(t)->__bs_opname(type,sz))((t), h, o, a, c)
+#define	__bs_set(type, sz, t, h, o, v, c)				\
+	(*(t)->__bs_opname(type,sz))((t), h, o, v, c)
+#define	__bs_copy(sz, t, h1, o1, h2, o2, cnt)				\
+	(*(t)->__bs_opname(c,sz))((t), h1, o1, h2, o2, cnt)
+#define	__bs_opname_s(op,size)	__bs_c(__bs_c(__bs_c(__bs_c(bs_,op),_),size),_s)
+#define	__bs_rs_s(sz, t, h, o)						\
+	(*(t)->__bs_opname_s(r,sz))((t), h, o)
+#define	__bs_ws_s(sz, t, h, o, v)					\
+	(*(t)->__bs_opname_s(w,sz))((t), h, o, v)
+#define	__bs_nonsingle_s(type, sz, t, h, o, a, c)			\
+	(*(t)->__bs_opname_s(type,sz))((t), h, o, a, c)
+#define __generate_inline_bs_rs(IFN, MBR, TYP)					\
+	static inline TYP						\
+	IFN(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)	\
+		if (__predict_true(t->MBR == NULL))			\
+			return (*(volatile TYP *)(h + o));		\
+		else							\
+			return (t->MBR(t, h, o));		\
+#define __generate_inline_bs_ws(IFN, MBR, TYP)					\
+	static inline void						\
+	IFN(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o, TYP v)\
+			*(volatile TYP *)(h + o) = v;			\
+		else							\
+			t->MBR(t, h, o, v);			\
+ * Mapping and unmapping operations.
+#define	bus_space_map(t, a, s, c, hp)					\
+	(*(t)->bs_map)((t), (a), (s), (c), (hp))
+#define	bus_space_unmap(t, h, s)					\
+	(*(t)->bs_unmap)((t), (h), (s))
+#define	bus_space_subregion(t, h, o, s, hp)				\
+	(*(t)->bs_subregion)((t), (h), (o), (s), (hp))
+ * Allocation and deallocation operations.
+#define	bus_space_alloc(t, rs, re, s, a, b, c, ap, hp)			\
+	(*(t)->bs_alloc)((t), (rs), (re), (s), (a), (b),	\
+	    (c), (ap), (hp))
+#define	bus_space_free(t, h, s)						\
+	(*(t)->bs_free)((t), (h), (s))
+ * Bus barrier operations.
+#define	bus_space_barrier(t, h, o, l, f)				\
+	(*(t)->bs_barrier)((t), (h), (o), (l), (f))
+#define	BUS_SPACE_BARRIER_READ	0x01
+#define	BUS_SPACE_BARRIER_WRITE	0x02
+ * Bus read (single) operations.
+__generate_inline_bs_rs(bus_space_read_1, bs_r_1, uint8_t);
+__generate_inline_bs_rs(bus_space_read_2, bs_r_2, uint16_t);
+__generate_inline_bs_rs(bus_space_read_4, bs_r_4, uint32_t);
+__generate_inline_bs_rs(bus_space_read_8, bs_r_8, uint64_t);
+__generate_inline_bs_rs(bus_space_read_stream_1, bs_r_1_s, uint8_t);
+__generate_inline_bs_rs(bus_space_read_stream_2, bs_r_2_s, uint16_t);
+__generate_inline_bs_rs(bus_space_read_stream_4, bs_r_4_s, uint32_t);
+__generate_inline_bs_rs(bus_space_read_stream_8, bs_r_8_s, uint64_t);
+ * Bus read multiple operations.
+#define	bus_space_read_multi_1(t, h, o, a, c)				\
+	__bs_nonsingle(rm,1,(t),(h),(o),(a),(c))
+#define	bus_space_read_multi_2(t, h, o, a, c)				\
+	__bs_nonsingle(rm,2,(t),(h),(o),(a),(c))
+#define	bus_space_read_multi_4(t, h, o, a, c)				\
+	__bs_nonsingle(rm,4,(t),(h),(o),(a),(c))
+#define	bus_space_read_multi_8(t, h, o, a, c)				\
+	__bs_nonsingle(rm,8,(t),(h),(o),(a),(c))
+#define	bus_space_read_multi_stream_1(t, h, o, a, c)			\
+	__bs_nonsingle_s(rm,1,(t),(h),(o),(a),(c))
+#define	bus_space_read_multi_stream_2(t, h, o, a, c)			\
+	__bs_nonsingle_s(rm,2,(t),(h),(o),(a),(c))
+#define	bus_space_read_multi_stream_4(t, h, o, a, c)			\
+	__bs_nonsingle_s(rm,4,(t),(h),(o),(a),(c))
+#define	bus_space_read_multi_stream_8(t, h, o, a, c)			\
+	__bs_nonsingle_s(rm,8,(t),(h),(o),(a),(c))
+ * Bus read region operations.
+#define	bus_space_read_region_1(t, h, o, a, c)				\
+	__bs_nonsingle(rr,1,(t),(h),(o),(a),(c))
+#define	bus_space_read_region_2(t, h, o, a, c)				\
+	__bs_nonsingle(rr,2,(t),(h),(o),(a),(c))
+#define	bus_space_read_region_4(t, h, o, a, c)				\
+	__bs_nonsingle(rr,4,(t),(h),(o),(a),(c))
+#define	bus_space_read_region_8(t, h, o, a, c)				\
+	__bs_nonsingle(rr,8,(t),(h),(o),(a),(c))
+#define	bus_space_read_region_stream_1(t, h, o, a, c)			\
+	__bs_nonsingle_s(rr,1,(t),(h),(o),(a),(c))
+#define	bus_space_read_region_stream_2(t, h, o, a, c)			\
+	__bs_nonsingle_s(rr,2,(t),(h),(o),(a),(c))
+#define	bus_space_read_region_stream_4(t, h, o, a, c)			\
+	__bs_nonsingle_s(rr,4,(t),(h),(o),(a),(c))
+#define	bus_space_read_region_stream_8(t, h, o, a, c)			\
+	__bs_nonsingle_s(rr,8,(t),(h),(o),(a),(c))
+ * Bus write (single) operations.
+__generate_inline_bs_ws(bus_space_write_1, bs_w_1, uint8_t);
+__generate_inline_bs_ws(bus_space_write_2, bs_w_2, uint16_t);
+__generate_inline_bs_ws(bus_space_write_4, bs_w_4, uint32_t);
+__generate_inline_bs_ws(bus_space_write_8, bs_w_8, uint64_t);
+__generate_inline_bs_ws(bus_space_write_stream_1, bs_w_1_s, uint8_t);
+__generate_inline_bs_ws(bus_space_write_stream_2, bs_w_2_s, uint16_t);
+__generate_inline_bs_ws(bus_space_write_stream_4, bs_w_4_s, uint32_t);
+__generate_inline_bs_ws(bus_space_write_stream_8, bs_w_8_s, uint64_t);
+ * Bus write multiple operations.
+#define	bus_space_write_multi_1(t, h, o, a, c)				\
+	__bs_nonsingle(wm,1,(t),(h),(o),(a),(c))
+#define	bus_space_write_multi_2(t, h, o, a, c)				\
+	__bs_nonsingle(wm,2,(t),(h),(o),(a),(c))
+#define	bus_space_write_multi_4(t, h, o, a, c)				\
+	__bs_nonsingle(wm,4,(t),(h),(o),(a),(c))
+#define	bus_space_write_multi_8(t, h, o, a, c)				\
+	__bs_nonsingle(wm,8,(t),(h),(o),(a),(c))
+#define	bus_space_write_multi_stream_1(t, h, o, a, c)			\
+	__bs_nonsingle_s(wm,1,(t),(h),(o),(a),(c))
+#define	bus_space_write_multi_stream_2(t, h, o, a, c)			\
+	__bs_nonsingle_s(wm,2,(t),(h),(o),(a),(c))
+#define	bus_space_write_multi_stream_4(t, h, o, a, c)			\
+	__bs_nonsingle_s(wm,4,(t),(h),(o),(a),(c))
+#define	bus_space_write_multi_stream_8(t, h, o, a, c)			\
+	__bs_nonsingle_s(wm,8,(t),(h),(o),(a),(c))
+ * Bus write region operations.
+#define	bus_space_write_region_1(t, h, o, a, c)				\
+	__bs_nonsingle(wr,1,(t),(h),(o),(a),(c))
+#define	bus_space_write_region_2(t, h, o, a, c)				\
+	__bs_nonsingle(wr,2,(t),(h),(o),(a),(c))
+#define	bus_space_write_region_4(t, h, o, a, c)				\
+	__bs_nonsingle(wr,4,(t),(h),(o),(a),(c))
+#define	bus_space_write_region_8(t, h, o, a, c)				\
+	__bs_nonsingle(wr,8,(t),(h),(o),(a),(c))
+#define	bus_space_write_region_stream_1(t, h, o, a, c)			\
+	__bs_nonsingle_s(wr,1,(t),(h),(o),(a),(c))
+#define	bus_space_write_region_stream_2(t, h, o, a, c)			\
+	__bs_nonsingle_s(wr,2,(t),(h),(o),(a),(c))
+#define	bus_space_write_region_stream_4(t, h, o, a, c)			\
+	__bs_nonsingle_s(wr,4,(t),(h),(o),(a),(c))
+#define	bus_space_write_region_stream_8(t, h, o, a, c)			\
+	__bs_nonsingle_s(wr,8,(t),(h),(o),(a),(c))
+ * Set multiple operations.
+#define	bus_space_set_multi_1(t, h, o, v, c)				\
+	__bs_set(sm,1,(t),(h),(o),(v),(c))
+#define	bus_space_set_multi_2(t, h, o, v, c)				\
+	__bs_set(sm,2,(t),(h),(o),(v),(c))
+#define	bus_space_set_multi_4(t, h, o, v, c)				\
+	__bs_set(sm,4,(t),(h),(o),(v),(c))
+#define	bus_space_set_multi_8(t, h, o, v, c)				\
+	__bs_set(sm,8,(t),(h),(o),(v),(c))
+ * Set region operations.
+#define	bus_space_set_region_1(t, h, o, v, c)				\
+	__bs_set(sr,1,(t),(h),(o),(v),(c))
+#define	bus_space_set_region_2(t, h, o, v, c)				\
+	__bs_set(sr,2,(t),(h),(o),(v),(c))
+#define	bus_space_set_region_4(t, h, o, v, c)				\
+	__bs_set(sr,4,(t),(h),(o),(v),(c))
+#define	bus_space_set_region_8(t, h, o, v, c)				\
+	__bs_set(sr,8,(t),(h),(o),(v),(c))
+ * Copy operations.
+#define	bus_space_copy_region_1(t, h1, o1, h2, o2, c)				\
+	__bs_copy(1, t, h1, o1, h2, o2, c)
+#define	bus_space_copy_region_2(t, h1, o1, h2, o2, c)				\
+	__bs_copy(2, t, h1, o1, h2, o2, c)
+#define	bus_space_copy_region_4(t, h1, o1, h2, o2, c)				\
+	__bs_copy(4, t, h1, o1, h2, o2, c)
+#define	bus_space_copy_region_8(t, h1, o1, h2, o2, c)				\
+	__bs_copy(8, t, h1, o1, h2, o2, c)
+ * Macros to provide prototypes for all the functions used in the
+ * bus_space structure
+#define bs_map_proto(f)							\
+int	__bs_c(f,_bs_map) (bus_space_tag_t t, bus_addr_t addr,		\
+	    bus_size_t size, int cacheable, bus_space_handle_t *bshp);
+#define bs_unmap_proto(f)						\
+void	__bs_c(f,_bs_unmap) (bus_space_tag_t t, bus_space_handle_t bsh,		\
+	    bus_size_t size);
+#define bs_subregion_proto(f)						\
+int	__bs_c(f,_bs_subregion) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, bus_size_t size, 			\
+	    bus_space_handle_t *nbshp);
+#define bs_alloc_proto(f)						\
+int	__bs_c(f,_bs_alloc) (bus_space_tag_t t, bus_addr_t rstart,		\
+	    bus_addr_t rend, bus_size_t size, bus_size_t align,		\
+	    bus_size_t boundary, int cacheable, bus_addr_t *addrp,	\
+	    bus_space_handle_t *bshp);
+#define bs_free_proto(f)						\
+void	__bs_c(f,_bs_free) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t size);
+#define bs_mmap_proto(f)						\
+int	__bs_c(f,_bs_mmap) (struct cdev *, vm_offset_t, vm_paddr_t *, int);
+#define bs_barrier_proto(f)						\
+void	__bs_c(f,_bs_barrier) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, bus_size_t len, int flags);
+#define	bs_r_1_proto(f)							\
+uint8_t	__bs_c(f,_bs_r_1) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+		    bus_size_t offset);
+#define	bs_r_2_proto(f)							\
+uint16_t	__bs_c(f,_bs_r_2) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_r_4_proto(f)							\
+uint32_t	__bs_c(f,_bs_r_4) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_r_8_proto(f)							\
+uint64_t	__bs_c(f,_bs_r_8) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_r_1_s_proto(f)						\
+uint8_t	__bs_c(f,_bs_r_1_s) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_r_2_s_proto(f)						\
+uint16_t	__bs_c(f,_bs_r_2_s) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_r_4_s_proto(f)						\
+uint32_t	__bs_c(f,_bs_r_4_s) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_w_1_proto(f)							\
+void	__bs_c(f,_bs_w_1) (bus_space_tag_t t, bus_space_handle_t bsh,		\
+	    bus_size_t offset, uint8_t value);
+#define	bs_w_2_proto(f)							\
+void	__bs_c(f,_bs_w_2) (bus_space_tag_t t, bus_space_handle_t bsh,		\
+	    bus_size_t offset, uint16_t value);
+#define	bs_w_4_proto(f)							\
+void	__bs_c(f,_bs_w_4) (bus_space_tag_t t, bus_space_handle_t bsh,		\
+	    bus_size_t offset, uint32_t value);
+#define	bs_w_8_proto(f)							\
+void	__bs_c(f,_bs_w_8) (bus_space_tag_t t, bus_space_handle_t bsh,		\
+	    bus_size_t offset, uint64_t value);
+#define	bs_w_1_s_proto(f)						\
+void	__bs_c(f,_bs_w_1_s) (bus_space_tag_t t, bus_space_handle_t bsh,		\
+#define	bs_w_2_s_proto(f)						\
+void	__bs_c(f,_bs_w_2_s) (bus_space_tag_t t, bus_space_handle_t bsh,		\
+#define	bs_w_4_s_proto(f)						\
+void	__bs_c(f,_bs_w_4_s) (bus_space_tag_t t, bus_space_handle_t bsh,		\
+#define	bs_rm_1_proto(f)						\
+void	__bs_c(f,_bs_rm_1) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, uint8_t *addr, bus_size_t count);
+#define	bs_rm_2_proto(f)						\
+void	__bs_c(f,_bs_rm_2) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, uint16_t *addr, bus_size_t count);
+#define	bs_rm_4_proto(f)						\
+void	__bs_c(f,_bs_rm_4) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, uint32_t *addr, bus_size_t count);
+#define	bs_rm_8_proto(f)						\
+void	__bs_c(f,_bs_rm_8) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, uint64_t *addr, bus_size_t count);
+#define	bs_wm_1_proto(f)						\
+void	__bs_c(f,_bs_wm_1) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, const uint8_t *addr, bus_size_t count);
+#define	bs_wm_2_proto(f)						\
+void	__bs_c(f,_bs_wm_2) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, const uint16_t *addr, bus_size_t count);
+#define	bs_wm_4_proto(f)						\
+void	__bs_c(f,_bs_wm_4) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, const uint32_t *addr, bus_size_t count);
+#define	bs_wm_8_proto(f)						\
+void	__bs_c(f,_bs_wm_8) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, const uint64_t *addr, bus_size_t count);
+#define	bs_rr_1_proto(f)						\
+void	__bs_c(f, _bs_rr_1) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_rr_2_proto(f)						\
+void	__bs_c(f, _bs_rr_2) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_rr_4_proto(f)						\
+void	__bs_c(f, _bs_rr_4) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_rr_8_proto(f)						\
+void	__bs_c(f, _bs_rr_8) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_wr_1_proto(f)						\
+void	__bs_c(f, _bs_wr_1) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_wr_2_proto(f)						\
+void	__bs_c(f, _bs_wr_2) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_wr_4_proto(f)						\
+void	__bs_c(f, _bs_wr_4) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_wr_8_proto(f)						\
+void	__bs_c(f, _bs_wr_8) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_sm_1_proto(f)						\
+void	__bs_c(f,_bs_sm_1) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, uint8_t value, bus_size_t count);
+#define	bs_sm_2_proto(f)						\
+void	__bs_c(f,_bs_sm_2) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, uint16_t value, bus_size_t count);
+#define	bs_sm_4_proto(f)						\
+void	__bs_c(f,_bs_sm_4) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, uint32_t value, bus_size_t count);
+#define	bs_sm_8_proto(f)						\
+void	__bs_c(f,_bs_sm_8) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+	    bus_size_t offset, uint64_t value, bus_size_t count);
+#define	bs_sr_1_proto(f)						\
+void	__bs_c(f,_bs_sr_1) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_sr_2_proto(f)						\
+void	__bs_c(f,_bs_sr_2) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_sr_4_proto(f)						\
+void	__bs_c(f,_bs_sr_4) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_sr_8_proto(f)						\
+void	__bs_c(f,_bs_sr_8) (bus_space_tag_t t, bus_space_handle_t bsh,	\
+#define	bs_c_1_proto(f)							\
+void	__bs_c(f,_bs_c_1) (bus_space_tag_t t, bus_space_handle_t bsh1,	\
+	    bus_size_t offset1, bus_space_handle_t bsh2,		\
+	    bus_size_t offset2, bus_size_t count);
+#define	bs_c_2_proto(f)							\
+void	__bs_c(f,_bs_c_2) (bus_space_tag_t t, bus_space_handle_t bsh1,	\
+#define	bs_c_4_proto(f)							\
+void	__bs_c(f,_bs_c_4) (bus_space_tag_t t, bus_space_handle_t bsh1,	\
+#define	bs_c_8_proto(f)							\
+void	__bs_c(f,_bs_c_8) (bus_space_tag_t t, bus_space_handle_t bsh1,	\
+#define bs_protos(f)		\
+bs_map_proto(f);		\
+bs_unmap_proto(f);		\
+bs_subregion_proto(f);		\
+bs_alloc_proto(f);		\
+bs_free_proto(f);		\
+bs_mmap_proto(f);		\
+bs_barrier_proto(f);		\
+bs_r_1_proto(f);		\
+bs_r_2_proto(f);		\
+bs_r_4_proto(f);		\
+bs_r_8_proto(f);		\
+bs_r_1_s_proto(f);		\
+bs_r_2_s_proto(f);		\
+bs_r_4_s_proto(f);		\
+bs_w_1_proto(f);		\
+bs_w_2_proto(f);		\
+bs_w_4_proto(f);		\
+bs_w_8_proto(f);		\
+bs_w_1_s_proto(f);		\
+bs_w_2_s_proto(f);		\
+bs_w_4_s_proto(f);		\
+bs_rm_1_proto(f);		\
+bs_rm_2_proto(f);		\
+bs_rm_4_proto(f);		\
+bs_rm_8_proto(f);		\
+bs_wm_1_proto(f);		\
+bs_wm_2_proto(f);		\
+bs_wm_4_proto(f);		\
+bs_wm_8_proto(f);		\
+bs_rr_1_proto(f);		\
+bs_rr_2_proto(f);		\
+bs_rr_4_proto(f);		\
+bs_rr_8_proto(f);		\
+bs_wr_1_proto(f);		\
+bs_wr_2_proto(f);		\
+bs_wr_4_proto(f);		\
+bs_wr_8_proto(f);		\
+bs_sm_1_proto(f);		\
+bs_sm_2_proto(f);		\
+bs_sm_4_proto(f);		\
+bs_sm_8_proto(f);		\
+bs_sr_1_proto(f);		\
+bs_sr_2_proto(f);		\
+bs_sr_4_proto(f);		\
+bs_sr_8_proto(f);		\
+bs_c_1_proto(f);		\
+bs_c_2_proto(f);		\
+bs_c_4_proto(f);		\
+bs_c_8_proto(f);
+void generic_bs_unimplemented(void);
+#define	BS_UNIMPLEMENTED	(void *)generic_bs_unimplemented
+#define BUS_SPACE_ALIGNED_POINTER(p, t) ALIGNED_POINTER(p, t)
+#define BUS_SPACE_MAXADDR_24BIT	0xFFFFFF
+#define BUS_SPACE_MAXADDR_32BIT 0xFFFFFFFF
+#define BUS_SPACE_MAXADDR 	0xFFFFFFFF
+#define BUS_SPACE_MAXSIZE_24BIT	0xFFFFFF
+#define BUS_SPACE_MAXSIZE_32BIT	0xFFFFFFFF
+#define BUS_SPACE_MAXSIZE 	0xFFFFFFFF
+#define BUS_SPACE_UNRESTRICTED	(~0)
+#include <machine/bus_dma.h>
+ * Get the physical address of a bus space memory-mapped resource.
+ * Doing this as a macro is a temporary solution until a more robust fix is
+ * designed.  It also serves to mark the locations needing that fix.
+#define BUS_SPACE_PHYSADDR(res, offs) \
+	((u_int)(rman_get_start(res)+(offs)))
+#endif /* _MACHINE_BUS_H_ */
diff --git a/freebsd/sys/arm64/include/machine/_bus.h b/freebsd/sys/arm64/include/machine/_bus.h
index 00000000..f11991f6
--- /dev/null
+++ b/freebsd/sys/arm64/include/machine/_bus.h
@@ -0,0 +1,46 @@
+ * are met:
+ *    distribution.
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _MACHINE__BUS_H_
+#define	_MACHINE__BUS_H_
+#endif /* !_MACHINE__BUS_H_ */
diff --git a/freebsd/sys/arm64/include/machine/bus.h b/freebsd/sys/arm64/include/machine/bus.h
index 00000000..8aaf1d3e
--- /dev/null
+++ b/freebsd/sys/arm64/include/machine/bus.h
@@ -0,0 +1,469 @@
+ * are met:
+ * are met:
+ * From: sys/arm/include/bus.h
+ * $FreeBSD$
+#define	BUS_SPACE_MAXADDR_24BIT	0xFFFFFFUL
+#define	BUS_SPACE_MAXADDR_32BIT 0xFFFFFFFFUL
+#define	BUS_SPACE_MAXSIZE_24BIT	0xFFFFFFUL
+#define	BUS_SPACE_MAXSIZE_32BIT	0xFFFFFFFFUL
+#define	BUS_SPACE_MAXADDR 	0xFFFFFFFFFFFFFFFFUL
+#define	BUS_SPACE_MAXSIZE 	0xFFFFFFFFFFFFFFFFUL
+struct bus_space {
+	/* cookie */
+	void		*bs_cookie;
+	int		(*bs_map) (void *, bus_addr_t, bus_size_t,
+	void		(*bs_unmap) (void *, bus_space_handle_t, bus_size_t);
+	int		(*bs_subregion) (void *, bus_space_handle_t,
+	int		(*bs_alloc) (void *, bus_addr_t, bus_addr_t,
+	void		(*bs_free) (void *, bus_space_handle_t,
+			    bus_size_t);
+	/* get kernel virtual address */
+	/* barrier */
+	void		(*bs_barrier) (void *, bus_space_handle_t,
+	/* read single */
+	u_int8_t	(*bs_r_1) (void *, bus_space_handle_t, bus_size_t);
+	u_int16_t	(*bs_r_2) (void *, bus_space_handle_t, bus_size_t);
+	u_int32_t	(*bs_r_4) (void *, bus_space_handle_t, bus_size_t);
+	u_int64_t	(*bs_r_8) (void *, bus_space_handle_t, bus_size_t);
+	void		(*bs_rm_1) (void *, bus_space_handle_t, bus_size_t,
+	    u_int8_t *, bus_size_t);
+	void		(*bs_rm_2) (void *, bus_space_handle_t, bus_size_t,
+	    u_int16_t *, bus_size_t);
+	void		(*bs_rm_4) (void *, bus_space_handle_t,
+			    bus_size_t, u_int32_t *, bus_size_t);
+	void		(*bs_rm_8) (void *, bus_space_handle_t,
+			    bus_size_t, u_int64_t *, bus_size_t);
+	/* read region */
+	void		(*bs_rr_1) (void *, bus_space_handle_t,
+			    bus_size_t, u_int8_t *, bus_size_t);
+	void		(*bs_rr_2) (void *, bus_space_handle_t,
+			    bus_size_t, u_int16_t *, bus_size_t);
+	void		(*bs_rr_4) (void *, bus_space_handle_t,
+	void		(*bs_rr_8) (void *, bus_space_handle_t,
+	/* write single */
+	void		(*bs_w_1) (void *, bus_space_handle_t,
+			    bus_size_t, u_int8_t);
+	void		(*bs_w_2) (void *, bus_space_handle_t,
+			    bus_size_t, u_int16_t);
+	void		(*bs_w_4) (void *, bus_space_handle_t,
+			    bus_size_t, u_int32_t);
+	void		(*bs_w_8) (void *, bus_space_handle_t,
+			    bus_size_t, u_int64_t);
+	void		(*bs_wm_1) (void *, bus_space_handle_t,
+			    bus_size_t, const u_int8_t *, bus_size_t);
+	void		(*bs_wm_2) (void *, bus_space_handle_t,
+			    bus_size_t, const u_int16_t *, bus_size_t);
+	void		(*bs_wm_4) (void *, bus_space_handle_t,
+			    bus_size_t, const u_int32_t *, bus_size_t);
+	void		(*bs_wm_8) (void *, bus_space_handle_t,
+			    bus_size_t, const u_int64_t *, bus_size_t);
+	void		(*bs_wr_1) (void *, bus_space_handle_t,
+	void		(*bs_wr_2) (void *, bus_space_handle_t,
+	void		(*bs_wr_4) (void *, bus_space_handle_t,
+	void		(*bs_wr_8) (void *, bus_space_handle_t,
+	void		(*bs_sm_1) (void *, bus_space_handle_t,
+			    bus_size_t, u_int8_t, bus_size_t);
+	void		(*bs_sm_2) (void *, bus_space_handle_t,
+			    bus_size_t, u_int16_t, bus_size_t);
+	void		(*bs_sm_4) (void *, bus_space_handle_t,
+			    bus_size_t, u_int32_t, bus_size_t);
+	void		(*bs_sm_8) (void *, bus_space_handle_t,
+			    bus_size_t, u_int64_t, bus_size_t);
+	/* set region */
+	void		(*bs_sr_1) (void *, bus_space_handle_t,
+	void		(*bs_sr_2) (void *, bus_space_handle_t,
+	void		(*bs_sr_4) (void *, bus_space_handle_t,
+	void		(*bs_sr_8) (void *, bus_space_handle_t,
+	/* copy */
+	void		(*bs_c_1) (void *, bus_space_handle_t, bus_size_t,
+	void		(*bs_c_2) (void *, bus_space_handle_t, bus_size_t,
+	void		(*bs_c_4) (void *, bus_space_handle_t, bus_size_t,
+	void		(*bs_c_8) (void *, bus_space_handle_t, bus_size_t,
+	/* read single stream */
+	u_int8_t	(*bs_r_1_s) (void *, bus_space_handle_t, bus_size_t);
+	u_int16_t	(*bs_r_2_s) (void *, bus_space_handle_t, bus_size_t);
+	u_int32_t	(*bs_r_4_s) (void *, bus_space_handle_t, bus_size_t);
+	u_int64_t	(*bs_r_8_s) (void *, bus_space_handle_t, bus_size_t);
+	void		(*bs_rm_1_s) (void *, bus_space_handle_t, bus_size_t,
+	void		(*bs_rm_2_s) (void *, bus_space_handle_t, bus_size_t,
+	void		(*bs_rm_4_s) (void *, bus_space_handle_t,
+	void		(*bs_rm_8_s) (void *, bus_space_handle_t,
+	void		(*bs_rr_1_s) (void *, bus_space_handle_t,
+	void		(*bs_rr_2_s) (void *, bus_space_handle_t,
+	void		(*bs_rr_4_s) (void *, bus_space_handle_t,
+	void		(*bs_rr_8_s) (void *, bus_space_handle_t,
+	/* write single stream */
+	void		(*bs_w_1_s) (void *, bus_space_handle_t,
+	void		(*bs_w_2_s) (void *, bus_space_handle_t,
+	void		(*bs_w_4_s) (void *, bus_space_handle_t,
+	void		(*bs_w_8_s) (void *, bus_space_handle_t,
+	void		(*bs_wm_1_s) (void *, bus_space_handle_t,
+	void		(*bs_wm_2_s) (void *, bus_space_handle_t,
+	void		(*bs_wm_4_s) (void *, bus_space_handle_t,
+	void		(*bs_wm_8_s) (void *, bus_space_handle_t,
+	void		(*bs_wr_1_s) (void *, bus_space_handle_t,
+	void		(*bs_wr_2_s) (void *, bus_space_handle_t,
+	void		(*bs_wr_4_s) (void *, bus_space_handle_t,
+	void		(*bs_wr_8_s) (void *, bus_space_handle_t,
+#define	__bs_rs(sz, t, h, o)						\
+	(*(t)->__bs_opname(r,sz))((t)->bs_cookie, h, o)
+#define	__bs_ws(sz, t, h, o, v)						\
+	(*(t)->__bs_opname(w,sz))((t)->bs_cookie, h, o, v)
+	(*(t)->__bs_opname(type,sz))((t)->bs_cookie, h, o, a, c)
+	(*(t)->__bs_opname(type,sz))((t)->bs_cookie, h, o, v, c)
+	(*(t)->__bs_opname(c,sz))((t)->bs_cookie, h1, o1, h2, o2, cnt)
+	(*(t)->__bs_opname_s(r,sz))((t)->bs_cookie, h, o)
+	(*(t)->__bs_opname_s(w,sz))((t)->bs_cookie, h, o, v)
+	(*(t)->__bs_opname_s(type,sz))((t)->bs_cookie, h, o, a, c)
+	(*(t)->bs_map)((t)->bs_cookie, (a), (s), (c), (hp))
+	(*(t)->bs_unmap)((t)->bs_cookie, (h), (s))
+	(*(t)->bs_subregion)((t)->bs_cookie, (h), (o), (s), (hp))
+	(*(t)->bs_alloc)((t)->bs_cookie, (rs), (re), (s), (a), (b),	\
+	    (c), (ap), (hp))
+	(*(t)->bs_free)((t)->bs_cookie, (h), (s))
+	(*(t)->bs_barrier)((t)->bs_cookie, (h), (o), (l), (f))
+#define	bus_space_read_1(t, h, o)	__bs_rs(1,(t),(h),(o))
+#define	bus_space_read_2(t, h, o)	__bs_rs(2,(t),(h),(o))
+#define	bus_space_read_4(t, h, o)	__bs_rs(4,(t),(h),(o))
+#define	bus_space_read_8(t, h, o)	__bs_rs(8,(t),(h),(o))
+#define	bus_space_read_stream_1(t, h, o)        __bs_rs_s(1,(t), (h), (o))
+#define	bus_space_read_stream_2(t, h, o)        __bs_rs_s(2,(t), (h), (o))
+#define	bus_space_read_stream_4(t, h, o)        __bs_rs_s(4,(t), (h), (o))
+#define	bus_space_read_stream_8(t, h, o)	__bs_rs_s(8,8,(t),(h),(o))
+#define	bus_space_write_1(t, h, o, v)	__bs_ws(1,(t),(h),(o),(v))
+#define	bus_space_write_2(t, h, o, v)	__bs_ws(2,(t),(h),(o),(v))
+#define	bus_space_write_4(t, h, o, v)	__bs_ws(4,(t),(h),(o),(v))
+#define	bus_space_write_8(t, h, o, v)	__bs_ws(8,(t),(h),(o),(v))
+#define	bus_space_write_stream_1(t, h, o, v)	__bs_ws_s(1,(t),(h),(o),(v))
+#define	bus_space_write_stream_2(t, h, o, v)	__bs_ws_s(2,(t),(h),(o),(v))
+#define	bus_space_write_stream_4(t, h, o, v)	__bs_ws_s(4,(t),(h),(o),(v))
+#define	bus_space_write_stream_8(t, h, o, v)	__bs_ws_s(8,(t),(h),(o),(v))
diff --git a/freebsd/sys/powerpc/include/machine/_bus.h b/freebsd/sys/powerpc/include/machine/_bus.h
index 00000000..d39fb003
--- /dev/null
+++ b/freebsd/sys/powerpc/include/machine/_bus.h
@@ -0,0 +1,50 @@
+ * are met:
+ *    distribution.
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef POWERPC_INCLUDE__BUS_H
+#define POWERPC_INCLUDE__BUS_H
+#include <vm/vm_param.h>
+ * Bus address and size types
+typedef vm_paddr_t bus_addr_t;
+typedef vm_size_t bus_size_t;
+ * Access methods for bus resources and address space.
+typedef vm_offset_t bus_space_handle_t;
+#endif /* POWERPC_INCLUDE__BUS_H */
diff --git a/freebsd/sys/powerpc/include/machine/bus.h b/freebsd/sys/powerpc/include/machine/bus.h
index 00000000..f45678f6
--- /dev/null
+++ b/freebsd/sys/powerpc/include/machine/bus.h
@@ -0,0 +1,467 @@
+ * SPDX-License-Identifier: BSD-2-Clause-NetBSD AND BSD-4-Clause
+ * are met:
+ * are met:
+ * $FreeBSD$
+#ifdef __powerpc64__
+#else
+#ifdef BOOKE
+#define BUS_SPACE_MAXADDR 	0xFFFFFFFFFULL
+#define BUS_SPACE_MAXSIZE 	0xFFFFFFFFUL
+#else
+#define BUS_SPACE_MAXADDR 	0xFFFFFFFFUL
+#endif
+#endif
+struct bus_space_access;
+struct bus_space {
+	int	(*bs_map)(bus_addr_t, bus_size_t, int,
+	    bus_space_handle_t *);
+	void	(*bs_unmap)(bus_size_t);
+	int	(*bs_subregion)(bus_space_handle_t, bus_size_t,
+	    bus_size_t, bus_space_handle_t *);
+	int	(*bs_alloc)(bus_addr_t, bus_addr_t, bus_size_t,
+	    bus_size_t, bus_size_t, int, bus_addr_t *, bus_space_handle_t *);
+	void	(*bs_free)(bus_space_handle_t, bus_size_t);
+	void	(*bs_barrier)(bus_space_handle_t, bus_size_t,
+	    bus_size_t, int);
+	/* Read single. */
+	uint8_t (*bs_r_1)(bus_space_handle_t, bus_size_t);
+	uint16_t (*bs_r_2)(bus_space_handle_t, bus_size_t);
+	uint32_t (*bs_r_4)(bus_space_handle_t, bus_size_t);
+	uint64_t (*bs_r_8)(bus_space_handle_t, bus_size_t);
+	uint16_t (*bs_r_s_2)(bus_space_handle_t, bus_size_t);
+	uint32_t (*bs_r_s_4)(bus_space_handle_t, bus_size_t);
+	uint64_t (*bs_r_s_8)(bus_space_handle_t, bus_size_t);
+	void	(*bs_rm_1)(bus_space_handle_t, bus_size_t, uint8_t *,
+	    bus_size_t);
+	void	(*bs_rm_2)(bus_space_handle_t, bus_size_t, uint16_t *,
+	    bus_size_t);
+	void	(*bs_rm_4)(bus_space_handle_t, bus_size_t, uint32_t *,
+	    bus_size_t);
+	void	(*bs_rm_8)(bus_space_handle_t, bus_size_t, uint64_t *,
+	    bus_size_t);
+	void	(*bs_rm_s_2)(bus_space_handle_t, bus_size_t, uint16_t *,
+	    bus_size_t);
+	void	(*bs_rm_s_4)(bus_space_handle_t, bus_size_t, uint32_t *,
+	    bus_size_t);
+	void	(*bs_rm_s_8)(bus_space_handle_t, bus_size_t, uint64_t *,
+	    bus_size_t);
+	/* read region */
+	void	(*bs_rr_1)(bus_space_handle_t, bus_size_t, uint8_t *,
+	    bus_size_t);
+	void	(*bs_rr_2)(bus_space_handle_t, bus_size_t, uint16_t *,
+	    bus_size_t);
+	void	(*bs_rr_4)(bus_space_handle_t, bus_size_t, uint32_t *,
+	    bus_size_t);
+	void	(*bs_rr_8)(bus_space_handle_t, bus_size_t, uint64_t *,
+	    bus_size_t);
+	void	(*bs_rr_s_2)(bus_space_handle_t, bus_size_t, uint16_t *,
+	    bus_size_t);
+	void	(*bs_rr_s_4)(bus_space_handle_t, bus_size_t, uint32_t *,
+	    bus_size_t);
+	void	(*bs_rr_s_8)(bus_space_handle_t, bus_size_t, uint64_t *,
+	    bus_size_t);
+	/* write */
+	void	(*bs_w_1)(bus_space_handle_t, bus_size_t, uint8_t);
+	void	(*bs_w_2)(bus_space_handle_t, bus_size_t, uint16_t);
+	void	(*bs_w_4)(bus_space_handle_t, bus_size_t, uint32_t);
+	void	(*bs_w_8)(bus_space_handle_t, bus_size_t, uint64_t);
+	void	(*bs_w_s_2)(bus_space_handle_t, bus_size_t, uint16_t);
+	void	(*bs_w_s_4)(bus_space_handle_t, bus_size_t, uint32_t);
+	void	(*bs_w_s_8)(bus_space_handle_t, bus_size_t, uint64_t);
+	void	(*bs_wm_1)(bus_space_handle_t, bus_size_t,
+	    const uint8_t *, bus_size_t);
+	void	(*bs_wm_2)(bus_space_handle_t, bus_size_t,
+	    const uint16_t *, bus_size_t);
+	void	(*bs_wm_4)(bus_space_handle_t, bus_size_t,
+	    const uint32_t *, bus_size_t);
+	void	(*bs_wm_8)(bus_space_handle_t, bus_size_t,
+	    const uint64_t *, bus_size_t);
+	void	(*bs_wm_s_2)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wm_s_4)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wm_s_8)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wr_1)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wr_2)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wr_4)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wr_8)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wr_s_2)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wr_s_4)(bus_space_handle_t, bus_size_t,
+	void	(*bs_wr_s_8)(bus_space_handle_t, bus_size_t,
+	void	(*bs_sm_1)(bus_space_handle_t, bus_size_t, uint8_t,
+	    bus_size_t);
+	void	(*bs_sm_2)(bus_space_handle_t, bus_size_t, uint16_t,
+	    bus_size_t);
+	void	(*bs_sm_4)(bus_space_handle_t, bus_size_t, uint32_t,
+	    bus_size_t);
+	void	(*bs_sm_8)(bus_space_handle_t, bus_size_t, uint64_t,
+	    bus_size_t);
+	void	(*bs_sm_s_2)(bus_space_handle_t, bus_size_t, uint16_t,
+	    bus_size_t);
+	void	(*bs_sm_s_4)(bus_space_handle_t, bus_size_t, uint32_t,
+	    bus_size_t);
+	void	(*bs_sm_s_8)(bus_space_handle_t, bus_size_t, uint64_t,
+	    bus_size_t);
+	/* set region */
+	void	(*bs_sr_1)(bus_space_handle_t, bus_size_t, uint8_t,
+	    bus_size_t);
+	void	(*bs_sr_2)(bus_space_handle_t, bus_size_t, uint16_t,
+	    bus_size_t);
+	void	(*bs_sr_4)(bus_space_handle_t, bus_size_t, uint32_t,
+	    bus_size_t);
+	void	(*bs_sr_8)(bus_space_handle_t, bus_size_t, uint64_t,
+	    bus_size_t);
+	void	(*bs_sr_s_2)(bus_space_handle_t, bus_size_t, uint16_t,
+	    bus_size_t);
+	void	(*bs_sr_s_4)(bus_space_handle_t, bus_size_t, uint32_t,
+	    bus_size_t);
+	void	(*bs_sr_s_8)(bus_space_handle_t, bus_size_t, uint64_t,
+	    bus_size_t);
+	/* copy region */
+	void	(*bs_cr_1)(bus_space_handle_t, bus_size_t,
+	void	(*bs_cr_2)(bus_space_handle_t, bus_size_t,
+	void	(*bs_cr_4)(bus_space_handle_t, bus_size_t,
+	void	(*bs_cr_8)(bus_space_handle_t, bus_size_t,
+	void	(*bs_cr_s_2)(bus_space_handle_t, bus_size_t,
+	void	(*bs_cr_s_4)(bus_space_handle_t, bus_size_t,
+	void	(*bs_cr_s_8)(bus_space_handle_t, bus_size_t,
+extern struct bus_space bs_be_tag;
+extern struct bus_space bs_le_tag;
+	(*(t)->__bs_opname(r,sz))(h, o)
+	(*(t)->__bs_opname(w,sz))(h, o, v)
+	(*(t)->__bs_opname(type,sz))(h, o, a, c)
+	(*(t)->__bs_opname(type,sz))(h, o, v, c)
+	(*(t)->__bs_opname(c,sz))(h1, o1, h2, o2, cnt)
+#define bus_space_map(t, a, s, c, hp) (*(t)->bs_map)(a, s, c, hp)
+#define bus_space_unmap(t, h, s)	(*(t)->bs_unmap)(h, s)
+#define	bus_space_subregion(t, h, o, s, hp)	(*(t)->bs_subregion)(h, o, s, hp)
+	(*(t)->bs_alloc)(rs, re, s, a, b, c, ap, hp)
+	(*(t)->bs_free)(h, s)
+#define	bus_space_barrier(t, h, o, l, f)	(*(t)->bs_barrier)(h, o, l, f)
+#define	bus_space_read_1(t, h, o)	__bs_rs(1,t,h,o)
+#define	bus_space_read_2(t, h, o)	__bs_rs(2,t,h,o)
+#define	bus_space_read_4(t, h, o)	__bs_rs(4,t,h,o)
+#define	bus_space_read_8(t, h, o)	__bs_rs(8,t,h,o)
+#define bus_space_read_stream_1 bus_space_read_1
+#define	bus_space_read_stream_2(t, h, o)	__bs_rs(s_2,t,h,o)
+#define	bus_space_read_stream_4(t, h, o)	__bs_rs(s_4,t,h,o)
+#define	bus_space_read_stream_8(t, h, o)	__bs_rs(s_8,t,h,o)
+#define bus_space_read_multi_stream_1 bus_space_read_multi_1
+	__bs_nonsingle(rm,s_2,(t),(h),(o),(a),(c))
+	__bs_nonsingle(rm,s_4,(t),(h),(o),(a),(c))
+	__bs_nonsingle(rm,s_8,(t),(h),(o),(a),(c))
+#define bus_space_read_region_stream_1 bus_space_read_region_1
+	__bs_nonsingle(rr,s_2,(t),(h),(o),(a),(c))
+	__bs_nonsingle(rr,s_4,(t),(h),(o),(a),(c))
+	__bs_nonsingle(rr,s_8,(t),(h),(o),(a),(c))
+#define bus_space_write_stream_1 bus_space_write_1
+#define	bus_space_write_stream_2(t, h, o, v)	__bs_ws(s_2,(t),(h),(o),(v))
+#define	bus_space_write_stream_4(t, h, o, v)	__bs_ws(s_4,(t),(h),(o),(v))
+#define	bus_space_write_stream_8(t, h, o, v)	__bs_ws(s_8,(t),(h),(o),(v))
+#define bus_space_write_multi_stream_1 bus_space_write_multi_1
+	__bs_nonsingle(wm,s_2,(t),(h),(o),(a),(c))
+	__bs_nonsingle(wm,s_4,(t),(h),(o),(a),(c))
+	__bs_nonsingle(wm,s_8,(t),(h),(o),(a),(c))
+#define bus_space_write_region_stream_1 bus_space_write_region_1
+	__bs_nonsingle(wr,s_2,(t),(h),(o),(a),(c))
+	__bs_nonsingle(wr,s_4,(t),(h),(o),(a),(c))
+	__bs_nonsingle(wr,s_8,(t),(h),(o),(a),(c))
+#define bus_space_set_multi_stream_1 bus_space_set_multi_1
+#define	bus_space_set_multi_stream_2(t, h, o, v, c)			\
+	__bs_set(sm,s_2,(t),(h),(o),(v),(c))
+#define	bus_space_set_multi_stream_4(t, h, o, v, c)			\
+	__bs_set(sm,s_4,(t),(h),(o),(v),(c))
+#define	bus_space_set_multi_stream_8(t, h, o, v, c)			\
+	__bs_set(sm,s_8,(t),(h),(o),(v),(c))
+#define bus_space_set_region_stream_1 bus_space_set_region_1
+#define	bus_space_set_region_stream_2(t, h, o, v, c)			\
+	__bs_set(sr,s_2,(t),(h),(o),(v),(c))
+#define	bus_space_set_region_stream_4(t, h, o, v, c)			\
+	__bs_set(sr,s_4,(t),(h),(o),(v),(c))
+#define	bus_space_set_region_stream_8(t, h, o, v, c)			\
+	__bs_set(sr,s_8,(t),(h),(o),(v),(c))
+#if 0
+#define bus_space_copy_region_stream_1 bus_space_copy_region_1
+#define	bus_space_copy_region_stream_2(t, h1, o1, h2, o2, c)			\
+	__bs_copy(s_2, t, h1, o1, h2, o2, c)
+#define	bus_space_copy_region_stream_4(t, h1, o1, h2, o2, c)			\
+	__bs_copy(s_4, t, h1, o1, h2, o2, c)
+#define	bus_space_copy_region_stream_8(t, h1, o1, h2, o2, c)			\
+	__bs_copy(s_8, t, h1, o1, h2, o2, c)
+#endif
diff --git a/freebsd/sys/riscv/include/machine/_bus.h b/freebsd/sys/riscv/include/machine/_bus.h
--- /dev/null
+++ b/freebsd/sys/riscv/include/machine/_bus.h
@@ -0,0 +1,46 @@
+ * are met:
+ *    distribution.
+ * SUCH DAMAGE.
+ * $FreeBSD$
diff --git a/freebsd/sys/riscv/include/machine/bus.h b/freebsd/sys/riscv/include/machine/bus.h
--- /dev/null
+++ b/freebsd/sys/riscv/include/machine/bus.h
@@ -0,0 +1,469 @@
+ * are met:
+ * are met:
+ * $FreeBSD$
+struct bus_space {
+	/* cookie */
+	void		*bs_cookie;
+			    bus_size_t);
+	/* barrier */
+	/* read single */
+	/* read region */
+	/* set region */
+	/* copy */
+	    (c), (ap), (hp))
diff --git a/freebsd/sys/riscv/include/machine/cpufunc.h b/freebsd/sys/riscv/include/machine/cpufunc.h
index 00000000..0f27fc45
--- /dev/null
+++ b/freebsd/sys/riscv/include/machine/cpufunc.h
@@ -0,0 +1,135 @@
+ * Copyright (c) 2015-2016 Ruslan Bukin <br at bsdpad.com>
+ * Portions of this software were developed by SRI International and the
+ * University of Cambridge Computer Laboratory under DARPA/AFRL contract
+ * FA8750-10-C-0237 ("CTSRD"), as part of the DARPA CRASH research programme.
+ * Portions of this software were developed by the University of Cambridge
+ * Computer Laboratory as part of the CTSRD Project, with support from the
+ * UK Higher Education Innovation Fund (HEIF).
+ * are met:
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _MACHINE_CPUFUNC_H_
+#define	_MACHINE_CPUFUNC_H_
+static __inline void
+breakpoint(void)
+	__asm("ebreak");
+#ifdef _KERNEL
+#include <machine/riscvreg.h>
+static __inline register_t
+intr_disable(void)
+	uint64_t ret;
+	__asm __volatile(
+		"csrrci %0, sstatus, %1"
+		: "=&r" (ret) : "i" (SSTATUS_SIE)
+	return (ret & (SSTATUS_SIE));
+intr_restore(register_t s)
+	__asm __volatile(
+		"csrs sstatus, %0"
+		:: "r" (s)
+intr_enable(void)
+	__asm __volatile(
+		"csrsi sstatus, %0"
+		:: "i" (SSTATUS_SIE)
+/* NB: fence() is defined as a macro in <machine/atomic.h>. */
+fence_i(void)
+	__asm __volatile("fence.i" ::: "memory");
+sfence_vma(void)
+	__asm __volatile("sfence.vma" ::: "memory");
+sfence_vma_page(uintptr_t addr)
+	__asm __volatile("sfence.vma %0" :: "r" (addr) : "memory");
+#define	rdcycle()			csr_read64(cycle)
+#define	rdtime()			csr_read64(time)
+#define	rdinstret()			csr_read64(instret)
+#define	rdhpmcounter(n)			csr_read64(hpmcounter##n)
+extern int64_t dcache_line_size;
+extern int64_t icache_line_size;
+#define	cpu_dcache_wbinv_range(a, s)
+#define	cpu_dcache_inv_range(a, s)
+#define	cpu_dcache_wb_range(a, s)
+#define	cpu_idcache_wbinv_range(a, s)
+#define	cpu_icache_sync_range(a, s)
+#define	cpu_icache_sync_range_checked(a, s)
+load_satp(uint64_t val)
+	__asm __volatile("csrw satp, %0" :: "r"(val));
+#define	cpufunc_nullop()		riscv_nullop()
+void riscv_nullop(void);
+#endif	/* _KERNEL */
+#endif	/* _MACHINE_CPUFUNC_H_ */
diff --git a/freebsd/sys/riscv/include/machine/riscvreg.h b/freebsd/sys/riscv/include/machine/riscvreg.h
index 00000000..ab99ed8a
--- /dev/null
+++ b/freebsd/sys/riscv/include/machine/riscvreg.h
@@ -0,0 +1,246 @@
+ * Copyright (c) 2015-2017 Ruslan Bukin <br at bsdpad.com>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _MACHINE_RISCVREG_H_
+#define	_MACHINE_RISCVREG_H_
+#define	EXCP_SHIFT			0
+#define	EXCP_MASK			(0xf << EXCP_SHIFT)
+#define	EXCP_MISALIGNED_FETCH		0
+#define	EXCP_FAULT_FETCH		1
+#define	EXCP_ILLEGAL_INSTRUCTION	2
+#define	EXCP_BREAKPOINT			3
+#define	EXCP_MISALIGNED_LOAD		4
+#define	EXCP_FAULT_LOAD			5
+#define	EXCP_MISALIGNED_STORE		6
+#define	EXCP_FAULT_STORE		7
+#define	EXCP_USER_ECALL			8
+#define	EXCP_SUPERVISOR_ECALL		9
+#define	EXCP_HYPERVISOR_ECALL		10
+#define	EXCP_MACHINE_ECALL		11
+#define	EXCP_INST_PAGE_FAULT		12
+#define	EXCP_LOAD_PAGE_FAULT		13
+#define	EXCP_STORE_PAGE_FAULT		15
+#define	EXCP_INTR			(1ul << 63)
+#define	SSTATUS_UIE			(1 << 0)
+#define	SSTATUS_SIE			(1 << 1)
+#define	SSTATUS_UPIE			(1 << 4)
+#define	SSTATUS_SPIE			(1 << 5)
+#define	SSTATUS_SPIE_SHIFT		5
+#define	SSTATUS_SPP			(1 << 8)
+#define	SSTATUS_SPP_SHIFT		8
+#define	SSTATUS_FS_SHIFT		13
+#define	SSTATUS_FS_OFF			(0x0 << SSTATUS_FS_SHIFT)
+#define	SSTATUS_FS_INITIAL		(0x1 << SSTATUS_FS_SHIFT)
+#define	SSTATUS_FS_CLEAN		(0x2 << SSTATUS_FS_SHIFT)
+#define	SSTATUS_FS_DIRTY		(0x3 << SSTATUS_FS_SHIFT)
+#define	SSTATUS_FS_MASK			(0x3 << SSTATUS_FS_SHIFT)
+#define	SSTATUS_XS_SHIFT		15
+#define	SSTATUS_XS_MASK			(0x3 << SSTATUS_XS_SHIFT)
+#define	SSTATUS_SUM			(1 << 18)
+#define	SSTATUS32_SD			(1 << 63)
+#define	SSTATUS64_SD			(1 << 31)
+#define	MSTATUS_UIE			(1 << 0)
+#define	MSTATUS_SIE			(1 << 1)
+#define	MSTATUS_HIE			(1 << 2)
+#define	MSTATUS_MIE			(1 << 3)
+#define	MSTATUS_UPIE			(1 << 4)
+#define	MSTATUS_SPIE			(1 << 5)
+#define	MSTATUS_SPIE_SHIFT		5
+#define	MSTATUS_HPIE			(1 << 6)
+#define	MSTATUS_MPIE			(1 << 7)
+#define	MSTATUS_MPIE_SHIFT		7
+#define	MSTATUS_SPP			(1 << 8)
+#define	MSTATUS_SPP_SHIFT		8
+#define	MSTATUS_HPP_MASK		0x3
+#define	MSTATUS_HPP_SHIFT		9
+#define	MSTATUS_MPP_MASK		0x3
+#define	MSTATUS_MPP_SHIFT		11
+#define	MSTATUS_FS_MASK			0x3
+#define	MSTATUS_FS_SHIFT		13
+#define	MSTATUS_XS_MASK			0x3
+#define	MSTATUS_XS_SHIFT		15
+#define	MSTATUS_MPRV			(1 << 17)
+#define	MSTATUS_PUM			(1 << 18)
+#define	MSTATUS_VM_MASK			0x1f
+#define	MSTATUS_VM_SHIFT		24
+#define	 MSTATUS_VM_MBARE		0
+#define	 MSTATUS_VM_MBB			1
+#define	 MSTATUS_VM_MBBID		2
+#define	 MSTATUS_VM_SV32		8
+#define	 MSTATUS_VM_SV39		9
+#define	 MSTATUS_VM_SV48		10
+#define	 MSTATUS_VM_SV57		11
+#define	 MSTATUS_VM_SV64		12
+#define	MSTATUS32_SD			(1 << 63)
+#define	MSTATUS64_SD			(1 << 31)
+#define	MSTATUS_PRV_U			0	/* user */
+#define	MSTATUS_PRV_S			1	/* supervisor */
+#define	MSTATUS_PRV_H			2	/* hypervisor */
+#define	MSTATUS_PRV_M			3	/* machine */
+#define	MIE_USIE	(1 << 0)
+#define	MIE_SSIE	(1 << 1)
+#define	MIE_HSIE	(1 << 2)
+#define	MIE_MSIE	(1 << 3)
+#define	MIE_UTIE	(1 << 4)
+#define	MIE_STIE	(1 << 5)
+#define	MIE_HTIE	(1 << 6)
+#define	MIE_MTIE	(1 << 7)
+#define	MIP_USIP	(1 << 0)
+#define	MIP_SSIP	(1 << 1)
+#define	MIP_HSIP	(1 << 2)
+#define	MIP_MSIP	(1 << 3)
+#define	MIP_UTIP	(1 << 4)
+#define	MIP_STIP	(1 << 5)
+#define	MIP_HTIP	(1 << 6)
+#define	MIP_MTIP	(1 << 7)
+#define	SIE_USIE	(1 << 0)
+#define	SIE_SSIE	(1 << 1)
+#define	SIE_UTIE	(1 << 4)
+#define	SIE_STIE	(1 << 5)
+#define	SIE_UEIE	(1 << 8)
+#define	SIE_SEIE	(1 << 9)
+#define	MIP_SEIP	(1 << 9)
+/* Note: sip register has no SIP_STIP bit in Spike simulator */
+#define	SIP_SSIP	(1 << 1)
+#define	SIP_STIP	(1 << 5)
+#define	SATP_PPN_S	0
+#define	SATP_PPN_M	(0xfffffffffff << SATP_PPN_S)
+#define	SATP_ASID_S	44
+#define	SATP_ASID_M	(0xffff << SATP_ASID_S)
+#define	SATP_MODE_S	60
+#define	SATP_MODE_M	(0xf << SATP_MODE_S)
+#define	SATP_MODE_SV39	(8ULL << SATP_MODE_S)
+#define	SATP_MODE_SV48	(9ULL << SATP_MODE_S)
+#define	XLEN		__riscv_xlen
+#define	XLEN_BYTES	(XLEN / 8)
+#define	INSN_SIZE	4
+#define	INSN_C_SIZE	2
+#define	X_RA	1
+#define	X_SP	2
+#define	X_GP	3
+#define	X_TP	4
+#define	X_T0	5
+#define	X_T1	6
+#define	X_T2	7
+#define	X_T3	28
+#define	RD_SHIFT	7
+#define	RD_MASK		(0x1f << RD_SHIFT)
+#define	RS1_SHIFT	15
+#define	RS1_MASK	(0x1f << RS1_SHIFT)
+#define	RS1_SP		(X_SP << RS1_SHIFT)
+#define	RS2_SHIFT	20
+#define	RS2_MASK	(0x1f << RS2_SHIFT)
+#define	RS2_RA		(X_RA << RS2_SHIFT)
+#define	IMM_SHIFT	20
+#define	IMM_MASK	(0xfff << IMM_SHIFT)
+#define	RS2_C_SHIFT	2
+#define	RS2_C_MASK	(0x1f << RS2_C_SHIFT)
+#define	RS2_C_RA	(X_RA << RS2_C_SHIFT)
+#define	CSR_ZIMM(val)							\
+	(__builtin_constant_p(val) && ((u_long)(val) < 32))
+#define	csr_swap(csr, val)						\
+({	if (CSR_ZIMM(val))  						\
+		__asm __volatile("csrrwi %0, " #csr ", %1"		\
+				: "=r" (val) : "i" (val));		\
+	else 								\
+		__asm __volatile("csrrw %0, " #csr ", %1"		\
+				: "=r" (val) : "r" (val));		\
+	val;								\
+#define	csr_write(csr, val)						\
+		__asm __volatile("csrwi " #csr ", %0" :: "i" (val));	\
+	else 								\
+		__asm __volatile("csrw " #csr ", %0" ::  "r" (val));	\
+#define	csr_set(csr, val)						\
+		__asm __volatile("csrsi " #csr ", %0" :: "i" (val));	\
+	else								\
+		__asm __volatile("csrs " #csr ", %0" :: "r" (val));	\
+#define	csr_clear(csr, val)						\
+		__asm __volatile("csrci " #csr ", %0" :: "i" (val));	\
+	else								\
+		__asm __volatile("csrc " #csr ", %0" :: "r" (val));	\
+#define	csr_read(csr)							\
+({	u_long val;							\
+	__asm __volatile("csrr %0, " #csr : "=r" (val));		\
+	val;								\
+#if __riscv_xlen == 32
+#define	csr_read64(csr)							\
+({	uint64_t val;							\
+	uint32_t high, low;						\
+	__asm __volatile("1: "						\
+			 "csrr t0, " #csr "h\n"				\
+			 "csrr %0, " #csr "\n"				\
+			 "csrr %1, " #csr "h\n"				\
+			 "bne t0, %1, 1b"				\
+			 : "=r" (low), "=r" (high)			\
+			 : "t0");					\
+	val = (low | ((uint64_t)high << 32));				\
+	val;								\
+#else
+#define	csr_read64(csr)		((uint64_t)csr_read(csr))
+#endif
+#endif /* !_MACHINE_RISCVREG_H_ */
diff --git a/rtemsbsd/include/machine/_bus.h b/freebsd/sys/sparc/include/machine/_bus.h
similarity index 100%
rename from rtemsbsd/include/machine/_bus.h
rename to freebsd/sys/sparc/include/machine/_bus.h
diff --git a/rtemsbsd/include/machine/bus.h b/freebsd/sys/sparc/include/machine/bus.h
rename from rtemsbsd/include/machine/bus.h
rename to freebsd/sys/sparc/include/machine/bus.h
diff --git a/freebsd/sys/sparc/include/machine/cpufunc.h b/freebsd/sys/sparc/include/machine/cpufunc.h
index 00000000..e69de29b
diff --git a/freebsd/sys/sparc64/include/machine/_bus.h b/freebsd/sys/sparc64/include/machine/_bus.h
index 00000000..55496461
--- /dev/null
+++ b/freebsd/sys/sparc64/include/machine/_bus.h
@@ -0,0 +1,41 @@
+ * are met:
+ *    distribution.
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef SPARC64_INCLUDE__BUS_H
+#define SPARC64_INCLUDE__BUS_H
+typedef struct bus_space_tag *bus_space_tag_t;
+#endif /* SPARC64_INCLUDE__BUS_H */
diff --git a/freebsd/sys/sparc64/include/machine/bus.h b/freebsd/sys/sparc64/include/machine/bus.h
index 00000000..e36c6863
--- /dev/null
+++ b/freebsd/sys/sparc64/include/machine/bus.h
@@ -0,0 +1,852 @@
+ * are met:
+ * Copyright (c) 1997-1999 Eduardo E. Horvath. All rights reserved.
+ * are met:
+ *	from: NetBSD: bus.h,v 1.58 2008/04/28 20:23:36 martin Exp
+ *	and
+ *	from: FreeBSD: src/sys/alpha/include/bus.h,v 1.9 2001/01/09
+ * $FreeBSD$
+#ifdef BUS_SPACE_DEBUG
+#include <sys/ktr.h>
+#endif
+#include <machine/cpufunc.h>
+ * Nexus and SBus spaces are non-cached and big endian
+ * (except for RAM and PROM)
+ * PCI spaces are non-cached and little endian
+#define	NEXUS_BUS_SPACE		0
+#define	SBUS_BUS_SPACE		1
+#define	PCI_CONFIG_BUS_SPACE	2
+#define	PCI_IO_BUS_SPACE	3
+#define	PCI_MEMORY_BUS_SPACE	4
+#define	LAST_BUS_SPACE		5
+extern const int bus_type_asi[];
+extern const int bus_stream_asi[];
+#define	__BUS_SPACE_HAS_STREAM_METHODS	1
+struct bus_space_tag {
+	void		*bst_cookie;
+	int		bst_type;
+ * Bus space function prototypes.
+static void bus_space_barrier(bus_space_tag_t, bus_space_handle_t, bus_size_t,
+    bus_size_t, int);
+static int bus_space_subregion(bus_space_tag_t, bus_space_handle_t,
+ * Map a region of device bus space into CPU virtual address space.
+int bus_space_map(bus_space_tag_t tag, bus_addr_t address, bus_size_t size,
+    int flags, bus_space_handle_t *handlep);
+ * Unmap a region of device bus space.
+void bus_space_unmap(bus_space_tag_t tag, bus_space_handle_t handle,
+    bus_size_t size);
+bus_space_barrier(bus_space_tag_t t __unused, bus_space_handle_t h __unused,
+    bus_size_t o __unused, bus_size_t s __unused, int f __unused)
+	 * We have lots of alternatives depending on whether we're
+	 * synchronizing loads with loads, loads with stores, stores
+	 * with loads, or stores with stores.  The only ones that seem
+	 * generic are #Sync and #MemIssue.  We use #Sync for safety.
+	membar(Sync);
+static __inline int
+bus_space_subregion(bus_space_tag_t t __unused, bus_space_handle_t h,
+    bus_size_t o __unused, bus_size_t s __unused, bus_space_handle_t *hp)
+	*hp = h + o;
+	return (0);
+/* flags for bus space map functions */
+#define	BUS_SPACE_MAP_CACHEABLE		0x0001
+#define	BUS_SPACE_MAP_LINEAR		0x0002
+#define	BUS_SPACE_MAP_READONLY		0x0004
+#define	BUS_SPACE_MAP_PREFETCHABLE	0x0008
+/* placeholders for bus functions... */
+#define	BUS_SPACE_MAP_BUS1		0x0100
+#define	BUS_SPACE_MAP_BUS2		0x0200
+#define	BUS_SPACE_MAP_BUS3		0x0400
+#define	BUS_SPACE_MAP_BUS4		0x0800
+/* flags for bus_space_barrier() */
+#define	BUS_SPACE_BARRIER_READ		0x01	/* force read barrier */
+#define	BUS_SPACE_BARRIER_WRITE		0x02	/* force write barrier */
+#define	KTR_BUS				KTR_SPARE2
+#define	__BUS_DEBUG_ACCESS(h, o, desc, sz) do {				\
+	CTR4(KTR_BUS, "bus space: %s %d: handle %#lx, offset %#lx",	\
+	    (desc), (sz), (h), (o));					\
+} while (0)
+#else
+#endif
+static __inline uint8_t
+bus_space_read_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
+	__BUS_DEBUG_ACCESS(h, o, "read", 1);
+	return (lduba_nc((caddr_t)(h + o), bus_type_asi[t->bst_type]));
+static __inline uint16_t
+bus_space_read_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
+	__BUS_DEBUG_ACCESS(h, o, "read", 2);
+	return (lduha_nc((caddr_t)(h + o), bus_type_asi[t->bst_type]));
+static __inline uint32_t
+bus_space_read_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
+	__BUS_DEBUG_ACCESS(h, o, "read", 4);
+	return (lduwa_nc((caddr_t)(h + o), bus_type_asi[t->bst_type]));
+static __inline uint64_t
+bus_space_read_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
+	__BUS_DEBUG_ACCESS(h, o, "read", 8);
+	return (ldxa_nc((caddr_t)(h + o), bus_type_asi[t->bst_type]));
+bus_space_read_multi_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint8_t *a, size_t c)
+	while (c-- > 0)
+		*a++ = bus_space_read_1(t, h, o);
+bus_space_read_multi_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint16_t *a, size_t c)
+	while (c-- > 0)
+		*a++ = bus_space_read_2(t, h, o);
+bus_space_read_multi_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint32_t *a, size_t c)
+	while (c-- > 0)
+		*a++ = bus_space_read_4(t, h, o);
+bus_space_read_multi_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint64_t *a, size_t c)
+	while (c-- > 0)
+		*a++ = bus_space_read_8(t, h, o);
+bus_space_write_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint8_t v)
+	__BUS_DEBUG_ACCESS(h, o, "write", 1);
+	stba_nc((caddr_t)(h + o), bus_type_asi[t->bst_type], v);
+bus_space_write_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint16_t v)
+	__BUS_DEBUG_ACCESS(h, o, "write", 2);
+	stha_nc((caddr_t)(h + o), bus_type_asi[t->bst_type], v);
+bus_space_write_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint32_t v)
+	__BUS_DEBUG_ACCESS(h, o, "write", 4);
+	stwa_nc((caddr_t)(h + o), bus_type_asi[t->bst_type], v);
+bus_space_write_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint64_t v)
+	__BUS_DEBUG_ACCESS(h, o, "write", 8);
+	stxa_nc((caddr_t)(h + o), bus_type_asi[t->bst_type], v);
+bus_space_write_multi_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint8_t *a, size_t c)
+	while (c-- > 0)
+		bus_space_write_1(t, h, o, *a++);
+bus_space_write_multi_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint16_t *a, size_t c)
+	while (c-- > 0)
+		bus_space_write_2(t, h, o, *a++);
+bus_space_write_multi_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint32_t *a, size_t c)
+	while (c-- > 0)
+		bus_space_write_4(t, h, o, *a++);
+bus_space_write_multi_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint64_t *a, size_t c)
+	while (c-- > 0)
+		bus_space_write_8(t, h, o, *a++);
+bus_space_set_multi_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint8_t v, size_t c)
+	while (c-- > 0)
+		bus_space_write_1(t, h, o, v);
+bus_space_set_multi_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint16_t v, size_t c)
+	while (c-- > 0)
+		bus_space_write_2(t, h, o, v);
+bus_space_set_multi_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint32_t v, size_t c)
+	while (c-- > 0)
+		bus_space_write_4(t, h, o, v);
+bus_space_set_multi_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint64_t v, size_t c)
+	while (c-- > 0)
+		bus_space_write_8(t, h, o, v);
+bus_space_read_region_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint8_t *a, bus_size_t c)
+	for (; c; a++, c--, o++)
+		*a = bus_space_read_1(t, h, o);
+bus_space_read_region_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint16_t *a, bus_size_t c)
+	for (; c; a++, c--, o += 2)
+		*a = bus_space_read_2(t, h, o);
+bus_space_read_region_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint32_t *a, bus_size_t c)
+	for (; c; a++, c--, o += 4)
+		*a = bus_space_read_4(t, h, o);
+bus_space_read_region_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint64_t *a, bus_size_t c)
+	for (; c; a++, c--, o += 8)
+		*a = bus_space_read_8(t, h, o);
+bus_space_write_region_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint8_t *a, bus_size_t c)
+		bus_space_write_1(t, h, o, *a);
+bus_space_write_region_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint16_t *a, bus_size_t c)
+		bus_space_write_2(t, h, o, *a);
+bus_space_write_region_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint32_t *a, bus_size_t c)
+		bus_space_write_4(t, h, o, *a);
+bus_space_write_region_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint64_t *a, bus_size_t c)
+		bus_space_write_8(t, h, o, *a);
+bus_space_set_region_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint8_t v, bus_size_t c)
+	for (; c; c--, o++)
+bus_space_set_region_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint16_t v, bus_size_t c)
+	for (; c; c--, o += 2)
+bus_space_set_region_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint32_t v, bus_size_t c)
+	for (; c; c--, o += 4)
+bus_space_set_region_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    const uint64_t v, bus_size_t c)
+	for (; c; c--, o += 8)
+bus_space_copy_region_1(bus_space_tag_t t, bus_space_handle_t h1,
+    bus_size_t o1, bus_space_handle_t h2, bus_size_t o2, bus_size_t c)
+	for (; c; c--, o1++, o2++)
+	    bus_space_write_1(t, h1, o1, bus_space_read_1(t, h2, o2));
+bus_space_copy_region_2(bus_space_tag_t t, bus_space_handle_t h1,
+	for (; c; c--, o1 += 2, o2 += 2)
+	    bus_space_write_2(t, h1, o1, bus_space_read_2(t, h2, o2));
+bus_space_copy_region_4(bus_space_tag_t t, bus_space_handle_t h1,
+	for (; c; c--, o1 += 4, o2 += 4)
+	    bus_space_write_4(t, h1, o1, bus_space_read_4(t, h2, o2));
+bus_space_copy_region_8(bus_space_tag_t t, bus_space_handle_t h1,
+	for (; c; c--, o1 += 8, o2 += 8)
+	    bus_space_write_8(t, h1, o1, bus_space_read_8(t, h2, o2));
+bus_space_read_stream_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
+	__BUS_DEBUG_ACCESS(h, o, "read stream", 1);
+	return (lduba_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type]));
+bus_space_read_stream_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
+	__BUS_DEBUG_ACCESS(h, o, "read stream", 2);
+	return (lduha_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type]));
+bus_space_read_stream_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
+	__BUS_DEBUG_ACCESS(h, o, "read stream", 4);
+	return (lduwa_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type]));
+bus_space_read_stream_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
+	__BUS_DEBUG_ACCESS(h, o, "read stream", 8);
+	return (ldxa_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type]));
+bus_space_read_multi_stream_1(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint8_t *a, size_t c)
+	while (c-- > 0)
+		*a++ = bus_space_read_stream_1(t, h, o);
+bus_space_read_multi_stream_2(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint16_t *a, size_t c)
+	while (c-- > 0)
+		*a++ = bus_space_read_stream_2(t, h, o);
+bus_space_read_multi_stream_4(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint32_t *a, size_t c)
+	while (c-- > 0)
+		*a++ = bus_space_read_stream_4(t, h, o);
+bus_space_read_multi_stream_8(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint64_t *a, size_t c)
+	while (c-- > 0)
+		*a++ = bus_space_read_stream_8(t, h, o);
+bus_space_write_stream_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint8_t v)
+	__BUS_DEBUG_ACCESS(h, o, "write stream", 1);
+	stba_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type], v);
+bus_space_write_stream_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint16_t v)
+	__BUS_DEBUG_ACCESS(h, o, "write stream", 2);
+	stha_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type], v);
+bus_space_write_stream_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint32_t v)
+	__BUS_DEBUG_ACCESS(h, o, "write stream", 4);
+	stwa_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type], v);
+bus_space_write_stream_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+    uint64_t v)
+	__BUS_DEBUG_ACCESS(h, o, "write stream", 8);
+	stxa_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type], v);
+bus_space_write_multi_stream_1(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint8_t *a, size_t c)
+	while (c-- > 0)
+		bus_space_write_stream_1(t, h, o, *a++);
+bus_space_write_multi_stream_2(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint16_t *a, size_t c)
+	while (c-- > 0)
+		bus_space_write_stream_2(t, h, o, *a++);
+bus_space_write_multi_stream_4(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint32_t *a, size_t c)
+	while (c-- > 0)
+		bus_space_write_stream_4(t, h, o, *a++);
+bus_space_write_multi_stream_8(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint64_t *a, size_t c)
+	while (c-- > 0)
+		bus_space_write_stream_8(t, h, o, *a++);
+bus_space_set_multi_stream_1(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint8_t v, size_t c)
+	while (c-- > 0)
+		bus_space_write_stream_1(t, h, o, v);
+bus_space_set_multi_stream_2(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint16_t v, size_t c)
+	while (c-- > 0)
+		bus_space_write_stream_2(t, h, o, v);
+bus_space_set_multi_stream_4(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint32_t v, size_t c)
+	while (c-- > 0)
+		bus_space_write_stream_4(t, h, o, v);
+bus_space_set_multi_stream_8(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint64_t v, size_t c)
+	while (c-- > 0)
+		bus_space_write_stream_8(t, h, o, v);
+bus_space_read_region_stream_1(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint8_t *a, bus_size_t c)
+		*a = bus_space_read_stream_1(t, h, o);
+bus_space_read_region_stream_2(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint16_t *a, bus_size_t c)
+		*a = bus_space_read_stream_2(t, h, o);
+bus_space_read_region_stream_4(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint32_t *a, bus_size_t c)
+		*a = bus_space_read_stream_4(t, h, o);
+bus_space_read_region_stream_8(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, uint64_t *a, bus_size_t c)
+		*a = bus_space_read_stream_8(t, h, o);
+bus_space_write_region_stream_1(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint8_t *a, bus_size_t c)
+		bus_space_write_stream_1(t, h, o, *a);
+bus_space_write_region_stream_2(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint16_t *a, bus_size_t c)
+		bus_space_write_stream_2(t, h, o, *a);
+bus_space_write_region_stream_4(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint32_t *a, bus_size_t c)
+		bus_space_write_stream_4(t, h, o, *a);
+bus_space_write_region_stream_8(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint64_t *a, bus_size_t c)
+		bus_space_write_stream_8(t, h, o, *a);
+bus_space_set_region_stream_1(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint8_t v, bus_size_t c)
+bus_space_set_region_stream_2(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint16_t v, bus_size_t c)
+bus_space_set_region_stream_4(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint32_t v, bus_size_t c)
+bus_space_set_region_stream_8(bus_space_tag_t t, bus_space_handle_t h,
+    bus_size_t o, const uint64_t v, bus_size_t c)
+bus_space_copy_region_stream_1(bus_space_tag_t t, bus_space_handle_t h1,
+	    bus_space_write_stream_1(t, h1, o1, bus_space_read_stream_1(t, h2,
+		o2));
+bus_space_copy_region_stream_2(bus_space_tag_t t, bus_space_handle_t h1,
+	    bus_space_write_stream_2(t, h1, o1, bus_space_read_stream_2(t, h2,
+		o2));
+bus_space_copy_region_stream_4(bus_space_tag_t t, bus_space_handle_t h1,
+	    bus_space_write_stream_4(t, h1, o1, bus_space_read_stream_4(t, h2,
+		o2));
+bus_space_copy_region_stream_8(bus_space_tag_t t, bus_space_handle_t h1,
+	    bus_space_write_stream_8(t, h1, o1, bus_space_read_8(t, h2, o2));
+bus_space_peek_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+	uint8_t *a)
+	__BUS_DEBUG_ACCESS(h, o, "peek", 1);
+	return (fasword8(bus_type_asi[t->bst_type], (caddr_t)(h + o), a));
+bus_space_peek_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+	uint16_t *a)
+	__BUS_DEBUG_ACCESS(h, o, "peek", 2);
+	return (fasword16(bus_type_asi[t->bst_type], (caddr_t)(h + o), a));
+bus_space_peek_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
+	uint32_t *a)
+	__BUS_DEBUG_ACCESS(h, o, "peek", 4);
+	return (fasword32(bus_type_asi[t->bst_type], (caddr_t)(h + o), a));
+#endif /* !_MACHINE_BUS_H_ */
diff --git a/rtemsbsd/include/machine/cpufunc.h b/rtemsbsd/include/machine/cpufunc.h
deleted file mode 100644
index fa882cb5..00000000
--- a/rtemsbsd/include/machine/cpufunc.h
+++ /dev/null
@@ -1 +0,0 @@
-/* empty file */
2.17.1
