[PATCH v1 0/2] [libbsd] Install correct machine include headers
Gedare Bloom
gedare at rtems.org
Mon May 10 20:54:55 UTC 2021
I can't review these currently, just want to put a note out there.
Hopefully someone else gets to it. Otherwise ping it in a week or two
and I might have more time to look myself..
On Mon, May 10, 2021 at 11:26 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> Hello,
> This is a follow-up on this discussion regarding the installed header files
> in libbsd: https://lists.rtems.org/pipermail/devel/2021-April/066211.html
> The current situation is, that for example for all machines the bus.h is installed from
> within the rtemsbsd directory (https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/include/machine/bus.h).
> According to the file docu it originates from the amd64 version of this file.
> It also has the following section in it which we ran into when compiling Chris' ptpd2 archive:
> #ifdef __i386__
> #error "your include paths are wrong"
> #endif
> This patchset does the following:
> - Add the target dependent machine include directory to 'header-paths' in libbsd.py
> - Import (mostly) '_bus.h', 'bus.h' and 'cpufunc.h' for the targets from freebsd-org
> - Remove those header files from rtemsbsd directory
> As a result the matching versions for machine dependent header files are now installed
> for each BSP.
> Would this be an acceptable solution?
> So far I compiled some BSPs for i386, arm, aarch64, powerpc, riscv, sparc and sparc64 to check that they still compile after the changes.
> Are there any other architectures which should be included?
> I ran into one problem regarding the compilation of rtemsbsd/sys/dev/dw_mmc/dw_mmc.c:105
> > return (bus_space_read_4(0, sc->bushandle, off));
> The first parameter creates an error for riscv (I think because dereferencing a NULL pointer).
> Are there any suggestion how to solve it (I am not familiar with the bus space and there is a lot of macro magic going on)?
> Also, I am not sure if I always added the header files in the right
> module in libbsd.py. Any suggestions where to put them instead would be welcome.
> Best regards,
> Jan
> Jan Sommer (2):
> rtemsbd: Remove machine dependent files and use the ones from freebsd
> machine: Add machine dependent header files to libbsd.py
> freebsd/sys/arm/include/machine/_bus.h | 47 +
> freebsd/sys/arm/include/machine/bus.h | 769 ++++++++++++++++
> freebsd/sys/arm64/include/machine/_bus.h | 46 +
> freebsd/sys/arm64/include/machine/bus.h | 469 ++++++++++
> freebsd/sys/powerpc/include/machine/_bus.h | 50 +
> freebsd/sys/powerpc/include/machine/bus.h | 467 ++++++++++
> freebsd/sys/riscv/include/machine/_bus.h | 46 +
> freebsd/sys/riscv/include/machine/bus.h | 469 ++++++++++
> freebsd/sys/riscv/include/machine/cpufunc.h | 135 +++
> freebsd/sys/riscv/include/machine/riscvreg.h | 246 +++++
> .../sys/sparc}/include/machine/_bus.h | 0
> .../sys/sparc}/include/machine/bus.h | 0
> freebsd/sys/sparc/include/machine/cpufunc.h | 0
> freebsd/sys/sparc64/include/machine/_bus.h | 41 +
> freebsd/sys/sparc64/include/machine/bus.h | 852 ++++++++++++++++++
> libbsd.py | 26 +-
> rtemsbsd/include/machine/cpufunc.h | 1 -
> waf_libbsd.py | 2 -
> 18 files changed, 3660 insertions(+), 6 deletions(-)
> create mode 100644 freebsd/sys/arm/include/machine/_bus.h
> create mode 100644 freebsd/sys/arm/include/machine/bus.h
> create mode 100644 freebsd/sys/arm64/include/machine/_bus.h
> create mode 100644 freebsd/sys/arm64/include/machine/bus.h
> create mode 100644 freebsd/sys/powerpc/include/machine/_bus.h
> create mode 100644 freebsd/sys/powerpc/include/machine/bus.h
> create mode 100644 freebsd/sys/riscv/include/machine/_bus.h
> create mode 100644 freebsd/sys/riscv/include/machine/bus.h
> create mode 100644 freebsd/sys/riscv/include/machine/cpufunc.h
> create mode 100644 freebsd/sys/riscv/include/machine/riscvreg.h
> rename {rtemsbsd => freebsd/sys/sparc}/include/machine/_bus.h (100%)
> rename {rtemsbsd => freebsd/sys/sparc}/include/machine/bus.h (100%)
> create mode 100644 freebsd/sys/sparc/include/machine/cpufunc.h
> create mode 100644 freebsd/sys/sparc64/include/machine/_bus.h
> create mode 100644 freebsd/sys/sparc64/include/machine/bus.h
> delete mode 100644 rtemsbsd/include/machine/cpufunc.h
> 2.17.1
> devel mailing list
> devel at rtems.org
