[PATCH] user/bld/index.rst: removed references to legacy network config options
Tue May 11 06:24:13 UTC 2021
ignore this patch, I spoke with Harrison on Discord and he will send
another in the next few days
On Sat, May 8, 2021 at 8:13 PM Harrison Edward Gerber
<gerberhe11 at gmail.com> wrote:
> From: Harrison <hgerber at uccs.edu>
>  user/bld/index.rst | 7 -------
>  1 file changed, 7 deletions(-)
> diff --git a/user/bld/index.rst b/user/bld/index.rst
> index ebedf5a..411b3a2 100644
> --- a/user/bld/index.rst
> +++ b/user/bld/index.rst
> @@ -309,10 +309,6 @@ in the configuration file.
>          Set ``RTEMS_MULTIPROCESSING`` to ``True`` or ``False`` in the BSP
>          section of the configuration file.
> -``--enable-networking`` | ``--disable-networking``
> -        Set ``RTEMS_NETWORKING`` to ``True`` or ``False`` in the BSP section of
> -        the configuration file.
>  ``--enable-paravirt`` | ``--disable-paravirt``
>          Set ``RTEMS_PARAVIRT`` to ``True`` or ``False`` in the BSP section of
> @@ -354,9 +350,6 @@ Please have a look at the following example configuration file.
>      # --enable-multiprocessing
>      RTEMS_MULTIPROCESSING = False
> -    # --enable-networking
> -    RTEMS_NETWORKING = True
>      # --disable-paravirt
>      RTEMS_PARAVIRT = False
> 2.25.1
> devel mailing list
> devel at rtems.org
