[PATCH v2] user/bld/index.rst: removed references to legacy network config options
Vijay Kumar Banerjee vijay at rtems.org
Wed May 12 01:28:24 UTC 2021
Hi Harrison,
This patch looks good. If no one objects by Friday, I'll push this. Thanks.
Best regards,
Vijay
On Tue, May 11, 2021 at 7:16 PM Harrison Edward Gerber
<gerberhe11 at gmail.com> wrote:
>  user/bld/index.rst | 7 -------
>  1 file changed, 7 deletions(-)
> diff --git a/user/bld/index.rst b/user/bld/index.rst
> index ebedf5a..411b3a2 100644
> --- a/user/bld/index.rst
> +++ b/user/bld/index.rst
> @@ -309,10 +309,6 @@ in the configuration file.
>          Set ``RTEMS_MULTIPROCESSING`` to ``True`` or ``False`` in the BSP
>          section of the configuration file.
> -``--enable-networking`` | ``--disable-networking``
> -        Set ``RTEMS_NETWORKING`` to ``True`` or ``False`` in the BSP section of
> -        the configuration file.
>  ``--enable-paravirt`` | ``--disable-paravirt``
>          Set ``RTEMS_PARAVIRT`` to ``True`` or ``False`` in the BSP section of
> @@ -354,9 +350,6 @@ Please have a look at the following example configuration file.
>      # --enable-multiprocessing
>      RTEMS_MULTIPROCESSING = False
> -    # --enable-networking
> -    RTEMS_NETWORKING = True
>      # --disable-paravirt
>      RTEMS_PARAVIRT = False
> 2.25.1
> devel mailing list
> devel at rtems.org
