[PATCH v2] user/bld/index.rst: removed references to legacy network config options
Vijay Kumar Banerjee
vijay at rtems.org
Sun May 16 16:14:21 UTC 2021
Hi Harrison,
I pushed this patch.
https://git.rtems.org/rtems-docs/commit/?id=1f538688a7f743158e0e9e9bb673abd576307a0c
Thanks,
Vijay
On Tue, May 11, 2021 at 7:28 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hi Harrison,
> This patch looks good. If no one objects by Friday, I'll push this. Thanks.
> Best regards,
> Vijay
> On Tue, May 11, 2021 at 7:16 PM Harrison Edward Gerber
> <gerberhe11 at gmail.com> wrote:
> > user/bld/index.rst | 7 -------
> > 1 file changed, 7 deletions(-)
> > diff --git a/user/bld/index.rst b/user/bld/index.rst
> > index ebedf5a..411b3a2 100644
> > --- a/user/bld/index.rst
> > +++ b/user/bld/index.rst
> > @@ -309,10 +309,6 @@ in the configuration file.
> > Set ``RTEMS_MULTIPROCESSING`` to ``True`` or ``False`` in the BSP
> > section of the configuration file.
> > -``--enable-networking`` | ``--disable-networking``
> > - Set ``RTEMS_NETWORKING`` to ``True`` or ``False`` in the BSP section of
> > - the configuration file.
> > ``--enable-paravirt`` | ``--disable-paravirt``
> > Set ``RTEMS_PARAVIRT`` to ``True`` or ``False`` in the BSP section of
> > @@ -354,9 +350,6 @@ Please have a look at the following example configuration file.
> > # --enable-multiprocessing
> > RTEMS_MULTIPROCESSING = False
> > - # --enable-networking
> > - RTEMS_NETWORKING = True
> > # --disable-paravirt
> > RTEMS_PARAVIRT = False
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
