[PATCH 4/5] bsps/imxrt: Fix OCRAM, ITCM and DTCM sizes
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed May 12 09:48:21 UTC 2021
The sizes are configurable via fuses or per software via some registers.
At the moment the registers are not changed. Changing the registers
destroys data stored in the RAM areas (like application code or data).
So either the fuses or some bootloader should be used to set them before
the application starts.
This also adds an OCRAM only linker command file.
Update #4180
bsps/arm/imxrt/include/imxrt/memory.h | 4 ++++
bsps/arm/imxrt/start/linkcmds.ocram | 23 +++++++++++++++++++
bsps/arm/imxrt/start/mpu-config.c | 6 +++++
spec/build/bsps/arm/imxrt/bspimxrt.yml | 9 ++++++++
spec/build/bsps/arm/imxrt/linkcmdsmemory.yml | 11 ++++++---
spec/build/bsps/arm/imxrt/optlinkcmds.yml | 3 ++-
spec/build/bsps/arm/imxrt/optmemdtcmsz.yml | 17 ++++++++++++++
spec/build/bsps/arm/imxrt/optmemitcmsz.yml | 17 ++++++++++++++
.../bsps/arm/imxrt/optmemocramnocachesz.yml | 16 +++++++++++++
spec/build/bsps/arm/imxrt/optmemocramsz.yml | 17 ++++++++++++++
10 files changed, 119 insertions(+), 4 deletions(-)
create mode 100644 bsps/arm/imxrt/start/linkcmds.ocram
create mode 100644 spec/build/bsps/arm/imxrt/optmemdtcmsz.yml
create mode 100644 spec/build/bsps/arm/imxrt/optmemitcmsz.yml
create mode 100644 spec/build/bsps/arm/imxrt/optmemocramnocachesz.yml
create mode 100644 spec/build/bsps/arm/imxrt/optmemocramsz.yml
diff --git a/bsps/arm/imxrt/include/imxrt/memory.h b/bsps/arm/imxrt/include/imxrt/memory.h
index 5a6b457aa6..8185f713cc 100644
--- a/bsps/arm/imxrt/include/imxrt/memory.h
+++ b/bsps/arm/imxrt/include/imxrt/memory.h
@@ -48,6 +48,10 @@ extern char imxrt_memory_ocram_begin[];
extern char imxrt_memory_ocram_end[];
extern char imxrt_memory_ocram_size[];
+extern char imxrt_memory_ocram_nocache_begin[];
+extern char imxrt_memory_ocram_nocache_end[];
+extern char imxrt_memory_ocram_nocache_size[];
extern char imxrt_memory_peripheral_begin[];
extern char imxrt_memory_peripheral_end[];
extern char imxrt_memory_peripheral_size[];
diff --git a/bsps/arm/imxrt/start/linkcmds.ocram b/bsps/arm/imxrt/start/linkcmds.ocram
new file mode 100644
index 0000000000..6df3c917b1
--- /dev/null
+++ b/bsps/arm/imxrt/start/linkcmds.ocram
@@ -0,0 +1,23 @@
+INCLUDE linkcmds.memory
+REGION_ALIAS ("REGION_START", OCRAM);
+REGION_ALIAS ("REGION_VECTOR", OCRAM);
+REGION_ALIAS ("REGION_TEXT", OCRAM);
+REGION_ALIAS ("REGION_TEXT_LOAD", OCRAM);
+REGION_ALIAS ("REGION_RODATA", OCRAM);
+REGION_ALIAS ("REGION_RODATA_LOAD", OCRAM);
+REGION_ALIAS ("REGION_DATA", OCRAM);
+REGION_ALIAS ("REGION_DATA_LOAD", OCRAM);
+REGION_ALIAS ("REGION_FAST_TEXT", OCRAM);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", OCRAM);
+REGION_ALIAS ("REGION_FAST_DATA", OCRAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", OCRAM);
+REGION_ALIAS ("REGION_BSS", OCRAM);
+REGION_ALIAS ("REGION_WORK", OCRAM);
+REGION_ALIAS ("REGION_STACK", OCRAM);
+REGION_ALIAS ("REGION_NOCACHE", OCRAM_NOCACHE);
+REGION_ALIAS ("REGION_NOCACHE_LOAD", OCRAM);
+bsp_vector_table_in_start_section = 1;
+INCLUDE linkcmds.armv7m
diff --git a/bsps/arm/imxrt/start/mpu-config.c b/bsps/arm/imxrt/start/mpu-config.c
index 31c39bc16f..683b26d45b 100644
--- a/bsps/arm/imxrt/start/mpu-config.c
+++ b/bsps/arm/imxrt/start/mpu-config.c
@@ -55,6 +55,12 @@ BSP_START_DATA_SECTION const ARMV7M_MPU_Region_config
.rasr = ARMV7M_MPU_RASR_AP(0x3)
| ARMV7M_MPU_RASR_TEX(0x2)
| ARMV7M_MPU_RASR_ENABLE,
+ .begin = imxrt_memory_ocram_nocache_begin,
+ .end = imxrt_memory_ocram_nocache_end,
+ .rasr = ARMV7M_MPU_RASR_AP(0x3)
+ | ARMV7M_MPU_RASR_TEX(0x2)
+ | ARMV7M_MPU_RASR_ENABLE,
.begin = imxrt_memory_peripheral_begin,
.end = imxrt_memory_peripheral_end,
diff --git a/spec/build/bsps/arm/imxrt/bspimxrt.yml b/spec/build/bsps/arm/imxrt/bspimxrt.yml
index 07f6bcef39..f543a14394 100644
--- a/spec/build/bsps/arm/imxrt/bspimxrt.yml
+++ b/spec/build/bsps/arm/imxrt/bspimxrt.yml
@@ -109,6 +109,7 @@ install:
- destination: ${BSP_LIBDIR}
source:
- bsps/arm/imxrt/start/linkcmds.flexspi
+ - bsps/arm/imxrt/start/linkcmds.ocram
- bsps/arm/imxrt/start/linkcmds.sdram
links:
- role: build-dependency
@@ -123,14 +124,22 @@ links:
uid: optfsledmaemlm
uid: optlinkcmds
+- role: build-dependency
+ uid: optmemdtcmsz
uid: optmemflashcfgsz
uid: optmemflashivtsz
uid: optmemflexspisz
+ uid: optmemitcmsz
uid: optmemnullsz
+ uid: optmemocramsz
+ uid: optmemocramnocachesz
uid: optmemsdrambase
diff --git a/spec/build/bsps/arm/imxrt/linkcmdsmemory.yml b/spec/build/bsps/arm/imxrt/linkcmdsmemory.yml
index 86dc37c3bd..3f7885c589 100644
--- a/spec/build/bsps/arm/imxrt/linkcmdsmemory.yml
+++ b/spec/build/bsps/arm/imxrt/linkcmdsmemory.yml
@@ -2,9 +2,10 @@ build-type: config-file
content: |
MEMORY {
NULL : ORIGIN = 0x00000000, LENGTH = ${IMXRT_MEMORY_NULL_SIZE:#010x}
- ITCM : ORIGIN = ${IMXRT_MEMORY_NULL_SIZE:#010x}, LENGTH = 512k - ${IMXRT_MEMORY_NULL_SIZE:#010x}
- DTCM : ORIGIN = 0x20000000, LENGTH = 512k
- OCRAM : ORIGIN = 0x20200000, LENGTH = 512k
+ ITCM : ORIGIN = ${IMXRT_MEMORY_NULL_SIZE:#010x}, LENGTH = ${IMXRT_MEMORY_ITCM_SIZE:#010x} - ${IMXRT_MEMORY_NULL_SIZE:#010x}
+ DTCM : ORIGIN = 0x20000000, LENGTH = ${IMXRT_MEMORY_DTCM_SIZE:#010x}
+ OCRAM : ORIGIN = 0x20200000, LENGTH = ${IMXRT_MEMORY_OCRAM_SIZE:#010x} - ${IMXRT_MEMORY_OCRAM_NOCACHE_SIZE:#010x}
+ OCRAM_NOCACHE : ORIGIN = 0x20200000 + ${IMXRT_MEMORY_OCRAM_SIZE:#010x} - ${IMXRT_MEMORY_OCRAM_NOCACHE_SIZE:#010x}, LENGTH = ${IMXRT_MEMORY_OCRAM_NOCACHE_SIZE:#010x}
PERIPHERAL : ORIGIN = 0x40000000, LENGTH = 0x20000000
FLEXSPI_CONFIG : ORIGIN = 0x60000000, LENGTH = ${IMXRT_MEMORY_FLASH_CFG_SIZE:#010x}
FLEXSPI_IVT : ORIGIN = 0x60000000 + ${IMXRT_MEMORY_FLASH_CFG_SIZE:#010x}, LENGTH = ${IMXRT_MEMORY_FLASH_IVT_SIZE:#010x}
@@ -30,6 +31,10 @@ content: |
imxrt_memory_ocram_end = ORIGIN (OCRAM) + LENGTH (OCRAM);
imxrt_memory_ocram_size = LENGTH (OCRAM);
+ imxrt_memory_ocram_nocache_begin = ORIGIN (OCRAM_NOCACHE);
+ imxrt_memory_ocram_nocache_end = ORIGIN (OCRAM_NOCACHE) + LENGTH (OCRAM_NOCACHE);
+ imxrt_memory_ocram_nocache_size = LENGTH (OCRAM_NOCACHE);
imxrt_memory_peripheral_begin = ORIGIN (PERIPHERAL);
imxrt_memory_peripheral_end = ORIGIN (PERIPHERAL) + LENGTH (PERIPHERAL);
imxrt_memory_peripheral_size = LENGTH (PERIPHERAL);
diff --git a/spec/build/bsps/arm/imxrt/optlinkcmds.yml b/spec/build/bsps/arm/imxrt/optlinkcmds.yml
index ba20c3838f..4349ad332e 100644
--- a/spec/build/bsps/arm/imxrt/optlinkcmds.yml
+++ b/spec/build/bsps/arm/imxrt/optlinkcmds.yml
@@ -9,7 +9,8 @@ format: '{}'
links: []
description: |
- The default linker command file. Must be linkcmds.sdram or linkcmds.flexspi.
+ The default linker command file. Must be linkcmds.sdram, linkcmds.ocram or
+ linkcmds.flexspi.
type: build
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemdtcmsz.yml b/spec/build/bsps/arm/imxrt/optmemdtcmsz.yml
index 0000000000..1bd57fac08
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemdtcmsz.yml
@@ -0,0 +1,17 @@
+actions:
+- get-integer: null
+- env-assign: null
+build-type: option
+default: 0x20000
+default-by-variant: []
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_DTCM_SIZE
+description: |
+ Size of the DTCM in bytes. Note that these sizes depend on fuses or software
+ settings done by a bootloader (together with ITCM and OCRAM).
+type: build
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+copyrights:
+- Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
diff --git a/spec/build/bsps/arm/imxrt/optmemitcmsz.yml b/spec/build/bsps/arm/imxrt/optmemitcmsz.yml
index 0000000000..195d519889
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemitcmsz.yml
@@ -0,0 +1,17 @@
+actions:
+- env-assign: null
+build-type: option
+default: 0x20000
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_ITCM_SIZE
+description: |
+ Size of the ITCM in bytes. Note that these sizes depend on fuses or software
+ settings done by a bootloader (together with DTCM and OCRAM).
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemocramnocachesz.yml b/spec/build/bsps/arm/imxrt/optmemocramnocachesz.yml
index 0000000000..8e68a08708
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemocramnocachesz.yml
@@ -0,0 +1,16 @@
+actions:
+- env-assign: null
+build-type: option
+default: 0
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_OCRAM_NOCACHE_SIZE
+description: |
+ Size of the nocache area at the end of the OCRAM in bytes.
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemocramsz.yml b/spec/build/bsps/arm/imxrt/optmemocramsz.yml
index 0000000000..4498435aa6
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemocramsz.yml
@@ -0,0 +1,17 @@
+actions:
+- env-assign: null
+build-type: option
+default: 0x40000
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_OCRAM_SIZE
+description: |
+ Size of the OCRAM in bytes. Note that these sizes depend on fuses or software
+ settings done by a bootloader (together with ITCM and DTCM).
+type: build
+copyrights:
2.26.2
