Spidev different ioctl structure
Sebastian Huber
Wed May 12 12:57:56 UTC 2021
Hello Andre,
being compatible to Linux is the goal. If this doesn't work, then this
is a bug. You can add a ticket for this and fix the issues.
On 12/05/2021 08:36, Andre.Nahrwold at dlr.de wrote:
> I discovered that the Spidev include (linux/spi/spidev.h) contains different implementations of the ioctl structure when comparing rtems and linux.
> I used the mode value of the structure and wanted to compile the application for rtems and linux, that is where I got some errors.
> A few further value names differ also: cs, word_delay_usecs, pad.
I don't think the "pad" member should be used by an application.
> Does anybody now why there is this difference?
> Or is it not necessary to use the mode value for the ioctl commands?
> On rtems it looks like this:
> struct spi_ioc_transfer {
> void *rx_buf;
> const void *tx_buf;
Maybe use uintptr_t instead of void *.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
