[PATCH] c-user: Add task priority glossary terms
Joel Sherrill
joel at rtems.org
Wed May 12 14:50:04 UTC 2021
Looks good.
On Wed, May 12, 2021 at 8:07 AM Sebastian Huber <
> c-user/glossary.rst | 41 ++++++++++++++++++++++++++++++++++++++---
> 1 file changed, 38 insertions(+), 3 deletions(-)
> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> index b3527a7..5a06c10 100644
> --- a/c-user/glossary.rst
> +++ b/c-user/glossary.rst
> @@ -194,6 +194,14 @@ Glossary
> This term is an acronym for Cathode Ray Tube. Normally used in
> reference to
> the man-machine interface.
> + current priority
> + The current priority of a :term:`task` is the :term:`task
> priority` with
> + respect to the :term:`home scheduler` of the task. It is an
> aggregation of
> + the :term:`real priority` and temporary priority adjustments due
> to locking
> + protocols, the rate-monotonic period objects on some schedulers
> such as EDF,
> + and the :term:`POSIX` sporadic server. The current priority is an
> + :term:`eligible priority`.
> deadline
> A fixed time limit by which a task must have completed a set of
> actions.
> Beyond this point, the results are of reduced value and may even
> be
> @@ -246,6 +254,12 @@ Glossary
> `Executable and Linkable Format <
> https://en.wikipedia.org/wiki/Executable_and_Linkable_Format>`_.
> + eligible priority
> + An eligible priority of a :term:`task` is the :term:`task
> priority` with
> + respect to the corresponding :term:`eligible scheduler` of the
> task. An
> + eligible priority is either the :term:`current priority` and a
> + :term:`helping priority` of a task.
> eligible scheduler
> An eligible scheduler of a :term:`task` is a :term:`scheduler`
> which can be
> used by the task to allocate a processor for the task.
> @@ -366,6 +380,11 @@ Glossary
> dispatch is marked as necessary, then the next thread dispatch
> will make
> the heir task the executing task.
> + helping priority
> + A helping priority of a :term:`task` is the :term:`task priority`
> with
> + respect to the corresponding :term:`helping scheduler` of the
> task. A
> + helping priority is an :term:`eligible priority`.
> helping scheduler
> A helping scheduler of a :term:`task` is a :term:`scheduler`
> which is a
> :term:`eligible scheduler` and which is not the :term:`home
> scheduler` of
> @@ -632,9 +651,9 @@ Glossary
> another task.
> priority
> - A mechanism used to represent the relative importance of an
> element in a
> - set of items. RTEMS uses priority to determine which task should
> - execute.
> + The priority is a mechanism used to represent the relative
> importance of an
> + element in a set of items. RTEMS uses :term:`task priorities
> <task priority>` to determine
> + which :term:`task` should execute.
> priority boosting
> A simple approach to extend the priority inheritance protocol for
> @@ -686,6 +705,14 @@ Glossary
> decided that other tasks are currently more important. A task
> that is
> ready to execute and has a processor assigned is called scheduled.
> + real priority
> + Each :term:`task` has exactly one real priority. The real
> priority is
> + always with respect to the :term:`home scheduler` of a task. It
> is defined
> + during task initialization. It may be changed by directives such
> as
> + :c:func:`rtems_task_set_priority` and
> + :c:func:`rtems_task_set_scheduler`. The real priority is the
> foundation
> + of the :term:`current priority`.
> real-time
> A term used to describe systems which are characterized by
> requiring
> deterministic response times to external stimuli. The external
> stimuli
> @@ -959,6 +986,14 @@ Glossary
> Task migration happens in case a task stops execution on one
> processor
> and resumes execution on another processor.
> + task priority
> + A task priority of a :term:`task` determines its importance with
> respect to
> + other tasks. The scheduler use task priorities to determine which
> + :term:`ready task` gets a processor allocated. The
> + :term:`eligible priorities <eligible priority>` of a task define
> the position of the task in a
> + :term:`wait queue` which uses the priority discipline. Each task
> has at
> + least the :term:`real priority`.
> task processor affinity
> The set of processors on which a task is allowed to execute.
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210512/995033db/attachment.html>
