[PATCH] c-user: Add task priority glossary terms
Gedare Bloom
gedare at rtems.org
Wed May 12 16:54:50 UTC 2021
On Wed, May 12, 2021 at 8:50 AM Joel Sherrill <joel at rtems.org> wrote:
> Looks good.
> On Wed, May 12, 2021 at 8:07 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> c-user/glossary.rst | 41 ++++++++++++++++++++++++++++++++++++++---
>> 1 file changed, 38 insertions(+), 3 deletions(-)
>> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
>> index b3527a7..5a06c10 100644
>> --- a/c-user/glossary.rst
>> +++ b/c-user/glossary.rst
>> @@ -194,6 +194,14 @@ Glossary
>> This term is an acronym for Cathode Ray Tube. Normally used in reference to
>> the man-machine interface.
>> + current priority
>> + The current priority of a :term:`task` is the :term:`task priority` with
>> + respect to the :term:`home scheduler` of the task. It is an aggregation of
>> + the :term:`real priority` and temporary priority adjustments due to locking
>> + protocols, the rate-monotonic period objects on some schedulers such as EDF,
>> + and the :term:`POSIX` sporadic server. The current priority is an
>> + :term:`eligible priority`.
>> deadline
>> A fixed time limit by which a task must have completed a set of actions.
>> Beyond this point, the results are of reduced value and may even be
>> @@ -246,6 +254,12 @@ Glossary
>> `Executable and Linkable Format <https://en.wikipedia.org/wiki/Executable_and_Linkable_Format>`_.
>> + eligible priority
>> + An eligible priority of a :term:`task` is the :term:`task priority` with
>> + respect to the corresponding :term:`eligible scheduler` of the task. An
>> + eligible priority is either the :term:`current priority` and a
"and" should be "or" ?
>> + :term:`helping priority` of a task.
>> eligible scheduler
>> An eligible scheduler of a :term:`task` is a :term:`scheduler` which can be
>> used by the task to allocate a processor for the task.
>> @@ -366,6 +380,11 @@ Glossary
>> dispatch is marked as necessary, then the next thread dispatch will make
>> the heir task the executing task.
>> + helping priority
>> + A helping priority of a :term:`task` is the :term:`task priority` with
>> + respect to the corresponding :term:`helping scheduler` of the task. A
>> + helping priority is an :term:`eligible priority`.
>> helping scheduler
>> A helping scheduler of a :term:`task` is a :term:`scheduler` which is a
>> :term:`eligible scheduler` and which is not the :term:`home scheduler` of
>> @@ -632,9 +651,9 @@ Glossary
>> another task.
>> priority
>> - A mechanism used to represent the relative importance of an element in a
>> - set of items. RTEMS uses priority to determine which task should
>> - execute.
>> + The priority is a mechanism used to represent the relative importance of an
>> + element in a set of items. RTEMS uses :term:`task priorities <task priority>` to determine
>> + which :term:`task` should execute.
>> priority boosting
>> A simple approach to extend the priority inheritance protocol for
>> @@ -686,6 +705,14 @@ Glossary
>> decided that other tasks are currently more important. A task that is
>> ready to execute and has a processor assigned is called scheduled.
>> + real priority
>> + Each :term:`task` has exactly one real priority. The real priority is
>> + always with respect to the :term:`home scheduler` of a task. It is defined
>> + during task initialization. It may be changed by directives such as
>> + :c:func:`rtems_task_set_priority` and
>> + :c:func:`rtems_task_set_scheduler`. The real priority is the foundation
>> + of the :term:`current priority`.
>> real-time
>> A term used to describe systems which are characterized by requiring
>> deterministic response times to external stimuli. The external stimuli
>> @@ -959,6 +986,14 @@ Glossary
>> Task migration happens in case a task stops execution on one processor
>> and resumes execution on another processor.
>> + task priority
>> + A task priority of a :term:`task` determines its importance with respect to
>> + other tasks. The scheduler use task priorities to determine which
>> + :term:`ready task` gets a processor allocated. The
>> + :term:`eligible priorities <eligible priority>` of a task define the position of the task in a
>> + :term:`wait queue` which uses the priority discipline. Each task has at
>> + least the :term:`real priority`.
>> task processor affinity
>> The set of processors on which a task is allowed to execute.
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
