[PATCH 5/5] bsps/imxrt: Enable DMA clock
Wed May 12 16:49:55 UTC 2021
the patch set is fine with the minor nit.
On Wed, May 12, 2021 at 3:49 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> The EDMA is intialized so make sure the the clock is initialized too.
> Update #4180
>  bsps/arm/imxrt/start/bspstarthooks.c | 3 +++
>  1 file changed, 3 insertions(+)
> diff --git a/bsps/arm/imxrt/start/bspstarthooks.c b/bsps/arm/imxrt/start/bspstarthooks.c
> index 2b6b59f66b..b8149691e7 100644
> --- a/bsps/arm/imxrt/start/bspstarthooks.c
> +++ b/bsps/arm/imxrt/start/bspstarthooks.c
> @@ -48,4 +48,7 @@ BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>    /* Reduce frequency for I2C */
>    CLOCK_SetDiv(kCLOCK_Lpi2cDiv, 5);
> +  /* Enable EDMA clock. We initialize the EDMA so we need the clock. */
> +  CLOCK_EnableClock(kCLOCK_Dma);
> 2.26.2
> devel mailing list
> devel at rtems.org
