[PATCH] score: Add and use _Per_CPU_Is_ISR_in_progress()
Fri May 14 15:36:08 UTC 2021
Add _Per_CPU_Is_ISR_in_progress() as an optimized version of
_ISR_Is_in_progress().
 cpukit/include/rtems/score/isr.h      | 12 ------------
 cpukit/include/rtems/score/isrlevel.h | 11 +++++++++++
 cpukit/include/rtems/score/percpu.h   | 10 ++++++++++
 cpukit/score/src/threadrestart.c      |  2 +-
 4 files changed, 22 insertions(+), 13 deletions(-)
diff --git a/cpukit/include/rtems/score/isr.h b/cpukit/include/rtems/score/isr.h
index 3c6a9f1e2c..47c24f3a72 100644
--- a/cpukit/include/rtems/score/isr.h
+++ b/cpukit/include/rtems/score/isr.h
@@ -147,18 +147,6 @@ void _ISR_Handler_initialization ( void );
 void _ISR_Handler( void );
- * @brief Checks if an ISR in progress.
- * This function returns true if the processor is currently servicing
- * and interrupt and false otherwise.   A return value of true indicates
- * that the caller is an interrupt service routine, NOT a thread.
- * @retval true Returns true when called from an ISR.
- * @retval false Returns false when not called from an ISR.
-bool _ISR_Is_in_progress( void );
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/include/rtems/score/isrlevel.h b/cpukit/include/rtems/score/isrlevel.h
index 3981f2c688..d578a32c48 100644
--- a/cpukit/include/rtems/score/isrlevel.h
+++ b/cpukit/include/rtems/score/isrlevel.h
@@ -144,6 +144,17 @@ typedef uint32_t   ISR_Level;
     RTEMS_COMPILER_MEMORY_BARRIER();  \
   } while (0)
+ * @brief Checks if an ISR in progress.
+ * This function returns true, if the processor is currently servicing
+ * and interrupt, and false otherwise.   A return value of true indicates
+ * that the caller is an interrupt service routine, **not** a thread.
+ * @return true Returns true, if called from within an ISR, otherwise false.
+bool _ISR_Is_in_progress( void );
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index 58a89ec7a9..1aed17ab19 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -683,6 +683,16 @@ static inline struct _Thread_Control *_Per_CPU_Get_executing(
   return cpu->executing;
+static inline bool _Per_CPU_Is_ISR_in_progress( const Per_CPU_Control *cpu )
+#if CPU_PROVIDES_ISR_IS_IN_PROGRESS == TRUE
+  (void) cpu;
+  return _ISR_Is_in_progress();
+#else
+  return cpu->isr_nest_level != 0;
+#endif
 static inline bool _Per_CPU_Is_processor_online(
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 7a1c8e4635..c8f7f7b6b1 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -538,7 +538,7 @@ Status_Control _Thread_Restart(
   if (
     the_thread == _Per_CPU_Get_executing( cpu_self ) &&
-    !_ISR_Is_in_progress()
+    !_Per_CPU_Is_ISR_in_progress( cpu_self )
     ignored_life_states = THREAD_LIFE_PROTECTED | THREAD_LIFE_CHANGE_DEFERRED;
   } else {
2.26.2
