[PATCH] score: Add and use _Per_CPU_Is_ISR_in_progress()
Fri May 14 20:30:40 UTC 2021
ok
On Fri, May 14, 2021 at 9:36 AM Sebastian Huber
> Add _Per_CPU_Is_ISR_in_progress() as an optimized version of
> _ISR_Is_in_progress().
>  cpukit/include/rtems/score/isr.h      | 12 ------------
>  cpukit/include/rtems/score/isrlevel.h | 11 +++++++++++
>  cpukit/include/rtems/score/percpu.h   | 10 ++++++++++
>  cpukit/score/src/threadrestart.c      |  2 +-
>  4 files changed, 22 insertions(+), 13 deletions(-)
> diff --git a/cpukit/include/rtems/score/isr.h b/cpukit/include/rtems/score/isr.h
> index 3c6a9f1e2c..47c24f3a72 100644
> --- a/cpukit/include/rtems/score/isr.h
> +++ b/cpukit/include/rtems/score/isr.h
> @@ -147,18 +147,6 @@ void _ISR_Handler_initialization ( void );
>  void _ISR_Handler( void );
> - * @brief Checks if an ISR in progress.
> - * This function returns true if the processor is currently servicing
> - * and interrupt and false otherwise.   A return value of true indicates
> - * that the caller is an interrupt service routine, NOT a thread.
> - * @retval true Returns true when called from an ISR.
> - * @retval false Returns false when not called from an ISR.
> -bool _ISR_Is_in_progress( void );
>  #ifdef __cplusplus
>  #endif
> diff --git a/cpukit/include/rtems/score/isrlevel.h b/cpukit/include/rtems/score/isrlevel.h
> index 3981f2c688..d578a32c48 100644
> --- a/cpukit/include/rtems/score/isrlevel.h
> +++ b/cpukit/include/rtems/score/isrlevel.h
> @@ -144,6 +144,17 @@ typedef uint32_t   ISR_Level;
>      RTEMS_COMPILER_MEMORY_BARRIER();  \
>    } while (0)
> + * @brief Checks if an ISR in progress.
> + * This function returns true, if the processor is currently servicing
> + * and interrupt, and false otherwise.   A return value of true indicates
> + * that the caller is an interrupt service routine, **not** a thread.
> + * @return true Returns true, if called from within an ISR, otherwise false.
> +bool _ISR_Is_in_progress( void );
>  #ifdef __cplusplus
> diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
> index 58a89ec7a9..1aed17ab19 100644
> --- a/cpukit/include/rtems/score/percpu.h
> +++ b/cpukit/include/rtems/score/percpu.h
> @@ -683,6 +683,16 @@ static inline struct _Thread_Control *_Per_CPU_Get_executing(
>    return cpu->executing;
> +static inline bool _Per_CPU_Is_ISR_in_progress( const Per_CPU_Control *cpu )
> +#if CPU_PROVIDES_ISR_IS_IN_PROGRESS == TRUE
> +  (void) cpu;
> +  return _ISR_Is_in_progress();
> +#else
> +  return cpu->isr_nest_level != 0;
> +#endif
>  static inline bool _Per_CPU_Is_processor_online(
> diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
> index 7a1c8e4635..c8f7f7b6b1 100644
> --- a/cpukit/score/src/threadrestart.c
> +++ b/cpukit/score/src/threadrestart.c
> @@ -538,7 +538,7 @@ Status_Control _Thread_Restart(
>    if (
>      the_thread == _Per_CPU_Get_executing( cpu_self ) &&
> -    !_ISR_Is_in_progress()
> +    !_Per_CPU_Is_ISR_in_progress( cpu_self )
>      ignored_life_states = THREAD_LIFE_PROTECTED | THREAD_LIFE_CHANGE_DEFERRED;
>    } else {
> 2.26.2
> devel mailing list
> devel at rtems.org
