[GSoC 2021] Beagle BSP USB OTG Support
Ahamed Husni ahamedhusni73 at gmail.com
Sun May 16 14:25:39 UTC 2021
Hi,
I tried the CDC Ethernet in FreeBSD. My Laptop detects an ethernet
<https://dms.uom.lk/s/QrzEsZAiSnWnQdk> interface with an IPv6.
I tried to ping the IPv6, but it didn't work
<https://dms.uom.lk/s/in6R2foWYwFWcdX>. The serial and ethernet works. I'll
check the mass
storage.
--Husni
On Thu, May 13, 2021 at 9:40 AM Ahamed Husni <ahamedhusni73 at gmail.com>
wrote:
> Hi,
> I couldn't set up the JTAG using Launchpad as it requires some adapters.
> While discussing
> <https://www.element14.com/community/groups/embedded/blog/2019/07/09/hardware-debug-jtag-probe-first-steps#comment-279479>
> in the Element14 forum, it seems it would require a lot of
> work to set up JTAG using the Launchpad.
> I can get the standard JTAG hardwares required  by ordering online before
> the coding period begins.
> Until that I did the hardware mod <https://dms.uom.lk/s/8rqygP9qfSGEcAW>
> required for Libdebugger on the BBB
> <https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#debugging-using-libdebugger>
> I don't know how to use the libdebugger. If anyone could point me in the
> right direction, that would be great.
> I tried booting the FreeBSD on BBB. The serial over usb is working.
> Ethernet and mass storage might require some configuration in FreeBSD.
> Best regards,
> Husni Faiz.
> On Mon, May 10, 2021 at 12:04 PM Christian MAUDERER <
> christian.mauderer at embedded-brains.de> wrote:
>> Hello Ahamed,
>> I'm using a J-Link to debug Beagle. I think that it doesn't have a EMU
>> pin either. Only difference: It has an additional TRST. I would suggest
>> to just try it.
>> I think on OpenOCD there are a few options regarding RST. You can have
>> SRST only, TRST only, both connected together and both as separate pins.
>> Best regards
>> Christian
>> Am 10.05.21 um 06:09 schrieb Ahamed Husni:
>> > Hi all,
>> > I need to debug the Beaglebone Black using JTAG. I got a TI LaunchPad
>> > CC1310. Launchpad has a XDS110 debugger with a (ARM - not sure) 10 pin
>> > JTAG out which can be used to debug external targets. The Beaglebone
>> has
>> > a cTI 20 pin JTAG interface. Pin layouts for the ARM10 and cTI20 is
>> > given here.
>> http://software-dl.ti.com/ccs/esd/documents/xdsdebugprobes/emu_jtag_connectors.html#connector-information
>> > Can we map the pins, point to point without adapters to debug the BBB
>> > using Launchpads's XDS110?
>> > Following is what I came up with just refering the above given pin
>> layouts.
>> > *ARM10 to cTI20*
>> > 1==5     (VTRef/VCC)
>> > 2==1     (SWDIO/TMS)
>> > 3==8    (GND)
>> > 4==9      (SWCLK/TCLK) SWDCLK(9) and TCK(11) are separate in cTI
>> > 5==10  (GND)
>> > 6==7    (SWO/TDO)
>> > 7 KEYED
>> > 8==3     (NC/TDI)
>> > 9==12   (GNDDetect)
>> > 10==15  (nRESET)
>> > Will this work? (EMU pins are not used here)
>> > Also I found a discussion in TI' forum which says,
>> > "Controlling the EMU0 and EMU1 signals, which are mandatory to place
>> the
>> > AM335x in debug mode."
>> https://e2e.ti.com/support/processors-group/processors/f/processors-forum/777331/am3358-how-to-evaluate-if-a-jtag-chain-works-correctly
>> > Also the hardware Mod for libdebugger in RTEMS connects the SWO/TDO(7)
>> > to the EMU0(13).
>> > My Project Proposal:
>> https://docs.google.com/document/d/1CN3ri7g6NJeFPb5h8y4smr1aziGWyXbiiXUsFMhdUu4/edit?usp=sharing
>> > Best regards,
>> > Husni Faiz.
>> embedded brains GmbH
>> Herr Christian MAUDERER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> phone: +49-89-18 94 741 - 18
>> fax:   +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210516/796bfc60/attachment.html>
