[GSoC 2021] Beagle BSP USB OTG Support
Ahamed Husni
ahamedhusni73 at gmail.com
Thu May 13 04:10:39 UTC 2021
Hi,
I couldn't set up the JTAG using Launchpad as it requires some adapters.
While discussing
<https://www.element14.com/community/groups/embedded/blog/2019/07/09/hardware-debug-jtag-probe-first-steps#comment-279479>
in the Element14 forum, it seems it would require a lot of
work to set up JTAG using the Launchpad.
I can get the standard JTAG hardwares required by ordering online before
the coding period begins.
Until that I did the hardware mod <https://dms.uom.lk/s/8rqygP9qfSGEcAW>
required for Libdebugger on the BBB
<https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#debugging-using-libdebugger>
I don't know how to use the libdebugger. If anyone could point me in the
right direction, that would be great.
I tried booting the FreeBSD on BBB. The serial over usb is working.
Ethernet and mass storage might require some configuration in FreeBSD.
Best regards,
Husni Faiz.
On Mon, May 10, 2021 at 12:04 PM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Hello Ahamed,
> I'm using a J-Link to debug Beagle. I think that it doesn't have a EMU
> pin either. Only difference: It has an additional TRST. I would suggest
> to just try it.
> I think on OpenOCD there are a few options regarding RST. You can have
> SRST only, TRST only, both connected together and both as separate pins.
> Best regards
> Christian
> Am 10.05.21 um 06:09 schrieb Ahamed Husni:
> > Hi all,
> > I need to debug the Beaglebone Black using JTAG. I got a TI LaunchPad
> > CC1310. Launchpad has a XDS110 debugger with a (ARM - not sure) 10 pin
> > JTAG out which can be used to debug external targets. The Beaglebone has
> > a cTI 20 pin JTAG interface. Pin layouts for the ARM10 and cTI20 is
> > given here.
> http://software-dl.ti.com/ccs/esd/documents/xdsdebugprobes/emu_jtag_connectors.html#connector-information
> > Can we map the pins, point to point without adapters to debug the BBB
> > using Launchpads's XDS110?
> > Following is what I came up with just refering the above given pin
> layouts.
> > *ARM10 to cTI20*
> > 1==5 (VTRef/VCC)
> > 2==1 (SWDIO/TMS)
> > 3==8 (GND)
> > 4==9 (SWCLK/TCLK) SWDCLK(9) and TCK(11) are separate in cTI
> > 5==10 (GND)
> > 6==7 (SWO/TDO)
> > 7 KEYED
> > 8==3 (NC/TDI)
> > 9==12 (GNDDetect)
> > 10==15 (nRESET)
> > Will this work? (EMU pins are not used here)
> > Also I found a discussion in TI' forum which says,
> > "Controlling the EMU0 and EMU1 signals, which are mandatory to place the
> > AM335x in debug mode."
> https://e2e.ti.com/support/processors-group/processors/f/processors-forum/777331/am3358-how-to-evaluate-if-a-jtag-chain-works-correctly
> > Also the hardware Mod for libdebugger in RTEMS connects the SWO/TDO(7)
> > to the EMU0(13).
> > My Project Proposal:
> https://docs.google.com/document/d/1CN3ri7g6NJeFPb5h8y4smr1aziGWyXbiiXUsFMhdUu4/edit?usp=sharing
> > Best regards,
> > Husni Faiz.
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210513/e1cd35a3/attachment-0001.html>
