question about posix timer expiration
Chris Johns
chrisj at rtems.org
Wed May 19 08:30:26 UTC 2021
> On 18 May 2021, at 10:02 pm, Gabriel.Moyano at dlr.de wrote:
> From further investigation I’ve found that when a timer expires, _POSIX_Timer_TSR() is called and this uses pthread_kill() to send a signal. Shouldn’t ptimer->inf.sigev_value be used here in order to create a siginfo_t object with the right value?
> Did anyone have to deal with this while using posix timers?
> Thanks!
> Von: devel <devel-bounces at rtems.org> Im Auftrag von Gabriel.Moyano at dlr.de
> Gesendet: Mittwoch, 12. Mai 2021 14:37
> An: devel at rtems.org
> Betreff: question about posix timer expiration
> Hello everyone,
> Currently I am trying to get running ptpd on rtems (following the Chris’ work, thx btw).
> Ptpd uses posix timers and when a timer expires a handler with this signature void(int sig, siginfo_t *info, void *ucontext) is called.
Is this on libbsd? If it is I would have expected kqueue being used so I am not sure where this is happening.
> Unfortunately (*info) doesn’t have the right values, eg. info->si_code should be SI_TIMER but it is SI_USER and also info->si_signo should be the same as sig but it’s not.
> Diving into the code I’ve found where the handler is called (also where *info is created). This is done in the function _POSIX_signals_Check_signal() in the file psignalunblockthread.c. It doesn’t seems that info is updated with the values (I guess) should take from object ptimer, which was created by create_timer().
> My question is: is this handler fully supported? Or maybe I’m missing something else.
> Thanks in advance,
> Gabriel
> Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
> Institute for Software Technology | SC-OSS | Lilienthalplatz 7 | 38108 Braunschweig | Germany
> Gabriel Moyano | Research Scientist in Onboard Software Systems group
> gabriel.moyano at dlr.de
> DLR.de
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210519/48789657/attachment-0001.html>
