[PATCH] rtems-bsp-builder: Change to waf build system
Ryan Long
ryan.long at oarcorp.com
Wed May 19 13:25:26 UTC 2021
Closes #4124
config/rtems-bsps.ini | 28 ++++++++++++++--------------
tester/rt/check.py | 35 ++++++++++++++++++++++++++---------
2 files changed, 40 insertions(+), 23 deletions(-)
diff --git a/config/rtems-bsps.ini b/config/rtems-bsps.ini
index 93156fb..d5de667 100644
--- a/config/rtems-bsps.ini
+++ b/config/rtems-bsps.ini
@@ -156,23 +156,23 @@ smp-network-debug = config:base, config:smp, config:network, config:debug
# Base set of configure options every build needs.
-base = --target=@ARCH at -rtems@RTEMS_VERSION@
- --enable-rtemsbsp=@BSP@
- --prefix=@PREFIX@
+base = --prefix=@PREFIX@
+ --top=@RTEMS@
+ --rtems-config=config- at ARCH@- at BSP@- at BUILD@.ini
# Tests.
-tests = --enable-tests
+tests = BUILD_TESTS=True
# The options for each varations.
-debug = --enable-rtems-debug
-no-debug = --disable-rtems-debug
-profiling = --enable-profiling
-no-profiling = --disable-profiling
-smp = --enable-smp
-no-smp = --disable-smp
-posix = --enable-posix
-no-posix = --disable-posix
-network = --enable-networking
-no-network = --disable-networking
+debug = RTEMS_DEBUG=True
+no-debug = RTEMS_DEBUG=False
+profiling = RTEMS_PROFILING=True
+no-profiling = RTEMS_PROFILING=False
+smp = RTEMS_SMP=True
+no-smp = RTEMS_SMP=False
+posix = RTEMS_POSIX_API=True
+no-posix = RTEMS_POSIX_API=False
+network = RTEMS_NETWORKING=True
+no-network = RTEMS_NETWORKING=False
diff --git a/tester/rt/check.py b/tester/rt/check.py
index 2a38d99..95fa47e 100755
--- a/tester/rt/check.py
+++ b/tester/rt/check.py
@@ -906,7 +906,9 @@ class build_jobs:
remove += [b for b in self.builds if e in b.split('-')]
self.builds = [b for b in self.builds if b not in remove]
self.build_set = { }
- exclude_options = ' ' + config.exclude_options(self.arch, self.bsp)
+ exclude_options = config.exclude_options(self.arch, self.bsp)
+ if exclude_options != '':
+ exclude_options = ' ' + exclude_options
for build in self.builds:
self.build_set[build] = config.build_options(build) + exclude_options
@@ -938,9 +940,7 @@ class builder:
'BSP' : '.*libbsp/.*',
'LibCPU' : '.*libcpu/.*',
'Shared' : '.*shared/.*' })
- if not path.exists(path.join(rtems, 'configure')) or \
- not path.exists(path.join(rtems, 'Makefile.in')) or \
- not path.exists(path.join(rtems, 'cpukit')):
+ if not path.exists(path.join(rtems, 'waf')):
raise error.general('RTEMS source path does not look like RTEMS')
def _bsps(self, arch):
@@ -952,15 +952,30 @@ class builder:
job_index = 1
for job in jobs:
tag = '%*d/%d' % (max_job_size, job_index, len(jobs))
+ commands = self._commands(job, build_job_count)
+ self._create_config(job, commands)
build_jobs += [arch_bsp_builder(self.results,
job,
- self._commands(job, build_job_count),
+ commands,
self.build_dir,
tag)]
job_index += 1
set_max_build_label(build_jobs)
return build_jobs
+ def _create_config(self, job, commands):
+ filename = 'config-%s-%s-%s.ini' % (job.arch, job.bsp, job.build)
+ cfg_file = open(path.join(self.rtems, filename),'w+')
+ cfg_file.write('[%s/%s]' + os.linsep() % (job.arch, job.bsp))
+ new_cfg_cmds = []
+ for option in commands['configure'].split():
+ if 'waf' in option or '--' in option or 'configure' in option:
+ new_cfg_cmds += [option]
+ else:
+ cfg_file.write(option + os.linesep())
+ commands['configure'] = ' '.join(new_cfg_cmds)
+ cfg_file.close()
def _commands(self, build, build_jobs):
commands = { 'dry-run' : self.options['dry-run'],
'no-clean' : self.options['no-clean'],
@@ -968,16 +983,18 @@ class builder:
'build' : None }
cmds = build.build_config.split()
cmds += self.config.bspopts(build.arch, build.bsp)
- cmd = [path.join(self.rtems, 'configure')]
+ cmd = [path.join(self.rtems, 'waf') + ' configure']
for c in cmds:
c = c.replace('@PREFIX@', self.prefix)
- c = c.replace('@RTEMS_VERSION@', str(self.rtems_version))
c = c.replace('@ARCH@', build.arch)
c = c.replace('@BSP@', build.bsp)
+ c = c.replace('@RTEMS@', self.rtems)
+ c = c.replace('@BUILD@', build.build)
cmd += [c]
commands['configure'] = ' '.join(cmd)
- cmd = 'make -j %s' % (build_jobs)
- commands['build'] = cmd
+ commands['build'] = path.join(self.rtems, 'waf')
+ commands['build'] += ' --top %s' % (self.rtems)
+ commands['build'] += ' -j %s' % (build_jobs)
return commands
def _update_file_counts(self, counts):
1.8.3.1
