[PATCH] rtems-bsp-builder: Change to waf build system
Chris Johns
chrisj at rtems.org
Thu May 20 05:13:08 UTC 2021
Looks fine (on my phone)
Thanks for this
> On 20 May 2021, at 1:25 am, Ryan Long <ryan.long at oarcorp.com> wrote:
> Closes #4124
> config/rtems-bsps.ini | 28 ++++++++++++++--------------
> tester/rt/check.py | 35 ++++++++++++++++++++++++++---------
> 2 files changed, 40 insertions(+), 23 deletions(-)
> diff --git a/config/rtems-bsps.ini b/config/rtems-bsps.ini
> index 93156fb..d5de667 100644
> --- a/config/rtems-bsps.ini
> +++ b/config/rtems-bsps.ini
> @@ -156,23 +156,23 @@ smp-network-debug = config:base, config:smp, config:network, config:debug
> # Base set of configure options every build needs.
> -base = --target=@ARCH at -rtems@RTEMS_VERSION@
> - --enable-rtemsbsp=@BSP@
> - --prefix=@PREFIX@
> +base = --prefix=@PREFIX@
> + --top=@RTEMS@
> + --rtems-config=config- at ARCH@- at BSP@- at BUILD@.ini
> # Tests.
> -tests = --enable-tests
> +tests = BUILD_TESTS=True
> # The options for each varations.
> -debug = --enable-rtems-debug
> -no-debug = --disable-rtems-debug
> -profiling = --enable-profiling
> -no-profiling = --disable-profiling
> -smp = --enable-smp
> -no-smp = --disable-smp
> -posix = --enable-posix
> -no-posix = --disable-posix
> -network = --enable-networking
> -no-network = --disable-networking
> +debug = RTEMS_DEBUG=True
> +no-debug = RTEMS_DEBUG=False
> +profiling = RTEMS_PROFILING=True
> +no-profiling = RTEMS_PROFILING=False
> +smp = RTEMS_SMP=True
> +no-smp = RTEMS_SMP=False
> +posix = RTEMS_POSIX_API=True
> +no-posix = RTEMS_POSIX_API=False
> +network = RTEMS_NETWORKING=True
> +no-network = RTEMS_NETWORKING=False
> diff --git a/tester/rt/check.py b/tester/rt/check.py
> index 2a38d99..95fa47e 100755
> --- a/tester/rt/check.py
> +++ b/tester/rt/check.py
> @@ -906,7 +906,9 @@ class build_jobs:
> remove += [b for b in self.builds if e in b.split('-')]
> self.builds = [b for b in self.builds if b not in remove]
> self.build_set = { }
> - exclude_options = ' ' + config.exclude_options(self.arch, self.bsp)
> + exclude_options = config.exclude_options(self.arch, self.bsp)
> + if exclude_options != '':
> + exclude_options = ' ' + exclude_options
> for build in self.builds:
> self.build_set[build] = config.build_options(build) + exclude_options
> @@ -938,9 +940,7 @@ class builder:
> 'BSP' : '.*libbsp/.*',
> 'LibCPU' : '.*libcpu/.*',
> 'Shared' : '.*shared/.*' })
> - if not path.exists(path.join(rtems, 'configure')) or \
> - not path.exists(path.join(rtems, 'Makefile.in')) or \
> - not path.exists(path.join(rtems, 'cpukit')):
> + if not path.exists(path.join(rtems, 'waf')):
> raise error.general('RTEMS source path does not look like RTEMS')
> def _bsps(self, arch):
> @@ -952,15 +952,30 @@ class builder:
> job_index = 1
> for job in jobs:
> tag = '%*d/%d' % (max_job_size, job_index, len(jobs))
> + commands = self._commands(job, build_job_count)
> + self._create_config(job, commands)
> build_jobs += [arch_bsp_builder(self.results,
> job,
> - self._commands(job, build_job_count),
> + commands,
> self.build_dir,
> tag)]
> job_index += 1
> set_max_build_label(build_jobs)
> return build_jobs
> + def _create_config(self, job, commands):
> + filename = 'config-%s-%s-%s.ini' % (job.arch, job.bsp, job.build)
> + cfg_file = open(path.join(self.rtems, filename),'w+')
> + cfg_file.write('[%s/%s]' + os.linsep() % (job.arch, job.bsp))
> + new_cfg_cmds = []
> + for option in commands['configure'].split():
> + if 'waf' in option or '--' in option or 'configure' in option:
> + new_cfg_cmds += [option]
> + else:
> + cfg_file.write(option + os.linesep())
> + commands['configure'] = ' '.join(new_cfg_cmds)
> + cfg_file.close()
> def _commands(self, build, build_jobs):
> commands = { 'dry-run' : self.options['dry-run'],
> 'no-clean' : self.options['no-clean'],
> @@ -968,16 +983,18 @@ class builder:
> 'build' : None }
> cmds = build.build_config.split()
> cmds += self.config.bspopts(build.arch, build.bsp)
> - cmd = [path.join(self.rtems, 'configure')]
> + cmd = [path.join(self.rtems, 'waf') + ' configure']
> for c in cmds:
> c = c.replace('@PREFIX@', self.prefix)
> - c = c.replace('@RTEMS_VERSION@', str(self.rtems_version))
> c = c.replace('@ARCH@', build.arch)
> c = c.replace('@BSP@', build.bsp)
> + c = c.replace('@RTEMS@', self.rtems)
> + c = c.replace('@BUILD@', build.build)
> cmd += [c]
> commands['configure'] = ' '.join(cmd)
> - cmd = 'make -j %s' % (build_jobs)
> - commands['build'] = cmd
> + commands['build'] = path.join(self.rtems, 'waf')
> + commands['build'] += ' --top %s' % (self.rtems)
> + commands['build'] += ' -j %s' % (build_jobs)
> return commands
> def _update_file_counts(self, counts):
> 1.8.3.1
> devel mailing list
> devel at rtems.org
