Incompatible Newlib Bump Approaching
Joel Sherrill
joel at rtems.org
Wed May 19 23:10:23 UTC 2021
Hi
Ryan's patches to add utimensat and futimens support require a minor patch
to newlib to build. This patch is pending on the newlib list and must be
merged there before the RSB can be bumped and then this patch set applied.
https://lists.rtems.org/pipermail/devel/2021-May/067343.html
This is just a heads up that sometime in the next couple of weeks that
there will be a forced bump in tools. When the above patch is merged, if
you haven't updated your tools, then RTEMS will not build.
Early warning.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210519/c0636188/attachment.html>
