[PATCH] rtems-bsp-builder: Change to waf build system
Thu May 20 13:21:33 UTC 2021
The BSP Builder builds multiple BSPs at the same time. At one point, I
thought waf had a problem with that. Has that been resolved.
Are the config files and build directories sufficiently unique
(BSP only isn't unique enough I think) for this to work with waf?
This is a step in the right direction but still might have issues with
concurrency. Just asking.
--joel
On Thu, May 20, 2021 at 12:13 AM Chris Johns <chrisj at rtems.org> wrote:
> Looks fine (on my phone)
> Thanks for this
> > On 20 May 2021, at 1:25 am, Ryan Long <ryan.long at oarcorp.com> wrote:
> > Closes #4124
> > config/rtems-bsps.ini | 28 ++++++++++++++--------------
> > tester/rt/check.py    | 35 ++++++++++++++++++++++++++---------
> > 2 files changed, 40 insertions(+), 23 deletions(-)
> > diff --git a/config/rtems-bsps.ini b/config/rtems-bsps.ini
> > index 93156fb..d5de667 100644
> > --- a/config/rtems-bsps.ini
> > +++ b/config/rtems-bsps.ini
> > @@ -156,23 +156,23 @@ smp-network-debug = config:base, config:smp,
> config:network, config:debug
> > # Base set of configure options every build needs.
> > -base = --target=@ARCH at -rtems@RTEMS_VERSION@
> > -       --enable-rtemsbsp=@BSP@
> > -       --prefix=@PREFIX@
> > +base = --prefix=@PREFIX@
> > +       --top=@RTEMS@
> > +       --rtems-config=config- at ARCH@- at BSP@- at BUILD@.ini
> > # Tests.
> > -tests = --enable-tests
> > +tests = BUILD_TESTS=True
> > # The options for each varations.
> > -debug             = --enable-rtems-debug
> > -no-debug          = --disable-rtems-debug
> > -profiling         = --enable-profiling
> > -no-profiling      = --disable-profiling
> > -smp               = --enable-smp
> > -no-smp            = --disable-smp
> > -posix             = --enable-posix
> > -no-posix          = --disable-posix
> > -network           = --enable-networking
> > -no-network        = --disable-networking
> > +debug             = RTEMS_DEBUG=True
> > +no-debug          = RTEMS_DEBUG=False
> > +profiling         = RTEMS_PROFILING=True
> > +no-profiling      = RTEMS_PROFILING=False
> > +smp               = RTEMS_SMP=True
> > +no-smp            = RTEMS_SMP=False
> > +posix             = RTEMS_POSIX_API=True
> > +no-posix          = RTEMS_POSIX_API=False
> > +network           = RTEMS_NETWORKING=True
> > +no-network        = RTEMS_NETWORKING=False
> > diff --git a/tester/rt/check.py b/tester/rt/check.py
> > index 2a38d99..95fa47e 100755
> > --- a/tester/rt/check.py
> > +++ b/tester/rt/check.py
> > @@ -906,7 +906,9 @@ class build_jobs:
> >             remove += [b for b in self.builds if e in b.split('-')]
> >         self.builds = [b for b in self.builds if b not in remove]
> >         self.build_set = { }
> > -        exclude_options = ' ' + config.exclude_options(self.arch,
> self.bsp)
> > +        exclude_options = config.exclude_options(self.arch, self.bsp)
> > +        if exclude_options != '':
> > +            exclude_options = ' ' + exclude_options
> >         for build in self.builds:
> >             self.build_set[build] = config.build_options(build) +
> exclude_options
> > @@ -938,9 +940,7 @@ class builder:
> >                                  'BSP'     : '.*libbsp/.*',
> >                                  'LibCPU'  : '.*libcpu/.*',
> >                                  'Shared'  : '.*shared/.*' })
> > -        if not path.exists(path.join(rtems, 'configure')) or \
> > -           not path.exists(path.join(rtems, 'Makefile.in')) or \
> > -           not path.exists(path.join(rtems, 'cpukit')):
> > +        if not path.exists(path.join(rtems, 'waf')):
> >             raise error.general('RTEMS source path does not look like
> RTEMS')
> >     def _bsps(self, arch):
> > @@ -952,15 +952,30 @@ class builder:
> >         job_index = 1
> >         for job in jobs:
> >             tag = '%*d/%d' % (max_job_size, job_index, len(jobs))
> > +            commands = self._commands(job, build_job_count)
> > +            self._create_config(job, commands)
> >             build_jobs += [arch_bsp_builder(self.results,
> >                                             job,
> > -                                            self._commands(job,
> build_job_count),
> > +                                            commands,
> >                                             self.build_dir,
> >                                             tag)]
> >             job_index += 1
> >         set_max_build_label(build_jobs)
> >         return build_jobs
> > +    def _create_config(self, job, commands):
> > +        filename = 'config-%s-%s-%s.ini' % (job.arch, job.bsp,
> job.build)
> > +        cfg_file = open(path.join(self.rtems, filename),'w+')
> > +        cfg_file.write('[%s/%s]' + os.linsep() % (job.arch, job.bsp))
> > +        new_cfg_cmds = []
> > +        for option in commands['configure'].split():
> > +            if 'waf' in option or '--' in option or 'configure' in
> option:
> > +                new_cfg_cmds += [option]
> > +            else:
> > +                cfg_file.write(option + os.linesep())
> > +        commands['configure'] = ' '.join(new_cfg_cmds)
> > +        cfg_file.close()
> >     def _commands(self, build, build_jobs):
> >         commands = { 'dry-run'  : self.options['dry-run'],
> >                      'no-clean' : self.options['no-clean'],
> > @@ -968,16 +983,18 @@ class builder:
> >                      'build'    : None }
> >         cmds = build.build_config.split()
> >         cmds += self.config.bspopts(build.arch, build.bsp)
> > -        cmd = [path.join(self.rtems, 'configure')]
> > +        cmd = [path.join(self.rtems, 'waf') + ' configure']
> >         for c in cmds:
> >             c = c.replace('@PREFIX@', self.prefix)
> > -            c = c.replace('@RTEMS_VERSION@', str(self.rtems_version))
> >             c = c.replace('@ARCH@', build.arch)
> >             c = c.replace('@BSP@', build.bsp)
> > +            c = c.replace('@RTEMS@', self.rtems)
> > +            c = c.replace('@BUILD@', build.build)
> >             cmd += [c]
> >         commands['configure'] = ' '.join(cmd)
> > -        cmd = 'make -j %s' % (build_jobs)
> > -        commands['build'] = cmd
> > +        commands['build'] = path.join(self.rtems, 'waf')
> > +        commands['build'] += ' --top %s' % (self.rtems)
> > +        commands['build'] += ' -j %s' % (build_jobs)
> >         return commands
> >     def _update_file_counts(self, counts):
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210520/77753a2d/attachment.html>
