[PATCH] score: Fix _Thread_Cancel()
Thu May 20 15:18:17 UTC 2021
The _Thread_Cancel() (in contrast to _Thread_Restart() which used a
similar code block) may have produced ready threads with an active timer
in case the thread to cancel had its thread life protection enabled. The
problem was this code block:
    Priority_Control priority;
    _Thread_Add_life_change_request( the_thread );
    if ( _Thread_Is_life_change_allowed( previous ) ) {
      _Thread_State_release( the_thread, &lock_context );
      _Thread_queue_Extract_with_proxy( the_thread );
      _Thread_Timer_remove( the_thread );
    } else {
      _Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
    priority = _Thread_Get_priority( executing );
    _Thread_Raise_real_priority( the_thread, priority );
    _Thread_Remove_life_change_request( the_thread );
The life change request should only be added/removed if a life change is
allowed (see _Thread_Restart()).  Add
_Thread_Consider_life_change_request() and use it in _Thread_Cancel()
and _Thread_Restart().
Close #4435.
 cpukit/score/src/threadrestart.c | 50 ++++++++++++++++----------------
 1 file changed, 25 insertions(+), 25 deletions(-)
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 933faee61b..58fcd89159 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -403,6 +403,25 @@ static void _Thread_Set_exit_value(
   the_thread->Life.exit_value = exit_value;
+static void _Thread_Consider_life_change_request(
+  Thread_Control    *the_thread,
+  Thread_Life_state  previous,
+  ISR_lock_Context  *lock_context
+  if ( _Thread_Is_life_change_allowed( previous ) ) {
+    _Thread_Add_life_change_request( the_thread );
+    _Thread_State_release( the_thread, lock_context );
+    _Thread_queue_Extract_with_proxy( the_thread );
+    _Thread_Timer_remove( the_thread );
+    _Thread_Remove_life_change_request( the_thread );
+  } else {
+    _Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
 void _Thread_Cancel(
   Thread_Control *executing,
@@ -433,21 +452,13 @@ void _Thread_Cancel(
   } else {
-    _Thread_Add_life_change_request( the_thread );
-    if ( _Thread_Is_life_change_allowed( previous ) ) {
-      _Thread_State_release( the_thread, &lock_context );
-      _Thread_queue_Extract_with_proxy( the_thread );
-      _Thread_Timer_remove( the_thread );
-    } else {
-      _Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
+    _Thread_Consider_life_change_request(
+      the_thread,
+      previous,
+      &lock_context
-    _Thread_Remove_life_change_request( the_thread );
   _Thread_Dispatch_enable( cpu_self );
@@ -559,18 +570,7 @@ Status_Control _Thread_Restart(
     THREAD_LIFE_RESTARTING,
     ignored_life_states
-    _Thread_State_release( the_thread, lock_context );
-  } else {
+  _Thread_Consider_life_change_request( the_thread, previous, lock_context );
   _Thread_queue_Context_initialize( &queue_context );
   _Thread_queue_Context_clear_priority_updates( &queue_context );
2.26.2
