[PATCH] score: Fix _Thread_Cancel()
Thu May 20 15:30:56 UTC 2021
Is there a test case for this situation?
On Thu, May 20, 2021 at 10:18 AM Sebastian Huber <
> The _Thread_Cancel() (in contrast to _Thread_Restart() which used a
> similar code block) may have produced ready threads with an active timer
> in case the thread to cancel had its thread life protection enabled. The
> problem was this code block:
>     Priority_Control priority;
>     _Thread_Add_life_change_request( the_thread );
>     if ( _Thread_Is_life_change_allowed( previous ) ) {
>       _Thread_State_release( the_thread, &lock_context );
>       _Thread_queue_Extract_with_proxy( the_thread );
>       _Thread_Timer_remove( the_thread );
>     } else {
>       _Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
>     priority = _Thread_Get_priority( executing );
>     _Thread_Raise_real_priority( the_thread, priority );
>     _Thread_Remove_life_change_request( the_thread );
> The life change request should only be added/removed if a life change is
> allowed (see _Thread_Restart()).  Add
> _Thread_Consider_life_change_request() and use it in _Thread_Cancel()
> and _Thread_Restart().
> Close #4435.
>  cpukit/score/src/threadrestart.c | 50 ++++++++++++++++----------------
>  1 file changed, 25 insertions(+), 25 deletions(-)
> diff --git a/cpukit/score/src/threadrestart.c
> b/cpukit/score/src/threadrestart.c
> index 933faee61b..58fcd89159 100644
> --- a/cpukit/score/src/threadrestart.c
> +++ b/cpukit/score/src/threadrestart.c
> @@ -403,6 +403,25 @@ static void _Thread_Set_exit_value(
>    the_thread->Life.exit_value = exit_value;
> +static void _Thread_Consider_life_change_request(
> +  Thread_Control    *the_thread,
> +  Thread_Life_state  previous,
> +  ISR_lock_Context  *lock_context
> +  if ( _Thread_Is_life_change_allowed( previous ) ) {
> +    _Thread_Add_life_change_request( the_thread );
> +    _Thread_State_release( the_thread, lock_context );
> +    _Thread_queue_Extract_with_proxy( the_thread );
> +    _Thread_Timer_remove( the_thread );
> +    _Thread_Remove_life_change_request( the_thread );
> +  } else {
> +    _Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
>  void _Thread_Cancel(
>    Thread_Control *executing,
> @@ -433,21 +452,13 @@ void _Thread_Cancel(
>    } else {
> -    _Thread_Add_life_change_request( the_thread );
> -    if ( _Thread_Is_life_change_allowed( previous ) ) {
> -      _Thread_State_release( the_thread, &lock_context );
> -      _Thread_queue_Extract_with_proxy( the_thread );
> -      _Thread_Timer_remove( the_thread );
> -    } else {
> -      _Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
> +    _Thread_Consider_life_change_request(
> +      the_thread,
> +      previous,
> +      &lock_context
> -    _Thread_Remove_life_change_request( the_thread );
>    _Thread_Dispatch_enable( cpu_self );
> @@ -559,18 +570,7 @@ Status_Control _Thread_Restart(
>      THREAD_LIFE_RESTARTING,
>      ignored_life_states
> -    _Thread_State_release( the_thread, lock_context );
> -  } else {
> +  _Thread_Consider_life_change_request( the_thread, previous,
> lock_context );
>    _Thread_queue_Context_initialize( &queue_context );
>    _Thread_queue_Context_clear_priority_updates( &queue_context );
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210520/b924e722/attachment-0001.html>
