[PATCH 1/3] ppc-irq-legacy.c: Use rtems_malloc() instead of malloc().
Fri May 21 21:35:43 UTC 2021
Closes #4438.
 bsps/powerpc/shared/irq/ppc-irq-legacy.c | 21 +++++++++++----------
 1 file changed, 11 insertions(+), 10 deletions(-)
diff --git a/bsps/powerpc/shared/irq/ppc-irq-legacy.c b/bsps/powerpc/shared/irq/ppc-irq-legacy.c
index 931a9c6074..982ef5d115 100644
--- a/bsps/powerpc/shared/irq/ppc-irq-legacy.c
+++ b/bsps/powerpc/shared/irq/ppc-irq-legacy.c
@@ -1,18 +1,19 @@
+ * @file PIC-independent implementation of the functions described in irq.h
+ * Copyright (C) 1998, 1999 valette at crf.canon.fr
- *  This file contains the PIC-independent implementation of the functions described in irq.h
- *  Copyright (C) 1998, 1999 valette at crf.canon.fr
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <stdlib.h>
+#include <rtems/malloc.h>
 #include <rtems/bspIo.h> /* for printk */
 #include <libcpu/spr.h>
 #include <bsp/irq_supp.h>
@@ -85,8 +86,8 @@ int BSP_install_rtems_shared_irq_handler  (const rtems_irq_connect_data* irq)
       return 0;
-	/* pre-allocate memory outside of critical section */
-    vchain = (rtems_irq_connect_data*)malloc(sizeof(rtems_irq_connect_data));
+    /* pre-allocate memory outside of critical section */
+    vchain = (rtems_irq_connect_data*) rtems_malloc(sizeof(rtems_irq_connect_data));
     rtems_interrupt_disable(level);
2.24.4
